Sorry, I have been too busy to test this today. I hope to find time later this week.If you remove your DNSCrypt setup do resolutions start working properly again?
Just installed this beta. I only have 2.4GHz enabled, because I don't use 5GHz.
However now I can't select 2.4GHz anymore in the dropdown list. It displays only 5GHz, but the settings refer to the only enabled 2.4GHz. Very strange.
Must be something specific to your RT-AC56U. I'm running an RT-AC87R and I'm not having that issue. Did you do a factory reset AFTER you upgraded or did you just let it ride? If you didn't do a factory reset then that's what I would suggest at this point and see if that fixes it.
However now I can't select 2.4GHz anymore in the dropdown list. It displays only 5GHz.
same here.
both bands enabled, but only 5GHz shows.
this is on AC66U
I went back to .47 for now
same here.
this is on AC66U
I'm not currently using disk sharing and though I had anything related to SMB disabled through the GUI, but I get this message in my System Log with 48 Beta 1.
Oct 21 06:20:42 smbd[871]: [2014/10/21 06:20:42.963109, 0] ../lib/util/charset/codepoints.c:319(get_conv_handle)
Oct 21 06:20:42 smbd[871]: dos charset 'CP850' unavailable - using ASCII
I'm guessing it isn't a big deal, but I thought I'd share in case it helped you fix something minor.
Thanks for this release. So far, I've been happy about stability with 48 Beta 1 and my System Log is much quieter.
Re-installed 376.48 Beta 1 to test this today, but now my (unmodified) DNSCrypt configuration seems to be working...Sorry, I have been too busy to test this today. I hope to find time later this week.
nslookup forums.smallnetbuilder.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 216.14.113.203
nslookup on the router works:
Code:nslookup forums.smallnetbuilder.com Server: 127.0.0.1 Address 1: 127.0.0.1 localhost.localdomain Name: forums.smallnetbuilder.com Address 1: 216.14.113.203
And https://dnsleaktest.com reports 176.56.237.171 (resolver1.dnscrypt.eu) as the only DNS server.
Wasn't there a recent outage with the DNSCrypt servers (in addition to the Google DNS outage in Asia about a week or two ago)?
Welcome To SNBForums
