Not sure if this is related to my problems with the new release, but anyone seeing this in their logs over and over?
Dec 27 09:37:33 dnsmasq-dhcp[23479]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 0s)
here's what the disk usage looks like after a reboot since the router appear locked up...
admin@RT-AC68P-F9A0:/# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 28928 28928 0 100% /
devtmpfs 127752 0 127752 0% /dev
tmpfs 127856 1100 126756 1% /tmp
/dev/mtdblock4 64256 4640 59616 7% /jffs
admin@RT-AC68P-F9A0:/# du -s * | sort -nr | head
45066 usr
14999 www
11276 lib
9497 jffs
5593 rom
1658 bin
1132 sbin
1100 tmp
0 var
0 sysroot
And before that it looks like i'm getting these errors over and over...
Feb 14 10:29:59 smbd[21443]: [2016/02/14 10:29:59.410426, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Feb 14 10:29:59 smbd[21443]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Feb 14 10:30:01 smbd[21444]: [2016/02/14 10:30:01.657103, 0] smbd/sesssetup.c:1355(reply_sesssetup_and_X)
Feb 14 10:30:01 smbd[21444]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negotiated.
Feb 14 14:27:16 miniupnpd[690]: upnp_event_recv: recv(): Connection reset by peer
Feb 14 15:36:08 miniupnpd[690]: upnp_event_recv: recv(): Connection reset by peer
Feb 14 16:41:44 miniupnpd[690]: upnp_event_recv: recv(): Connection reset by peer
In case this helps anyone else, for some reason after the upgrade SMB sharing became enabled - even though I did not enable it or have a hard drive/additional memory installed in the RT-AC68P. At this point my best guess is that the log files were filling up /tmp with SPNEGO errors leading somehow to a system crash. (I thought Linux automatically cleared out the /tmp directory when it runs low on disk space?) I disabled the smb sharing and have been watching the disk usage, the problem has not reappeared. A watched pot never boils
On a side note, can rstat-speed.gz be deleted without any adverse effects? It's the biggest file in the tmp directory right now.
