Beta Asuswrt-Merlin 386.1 Beta is now available
Works fine with beta 2 and ax88u coming from 384.19, but I just figured out that skynet is offline.
When I try to run "firewall" I get this. I cant recognise the usb that was there before?
Skynet: [*] USB Not Found - Sleeping For 10 Seconds ( Attempt 1 Of 10 )
Last week I purchased an AC86U router so I could use my two AC66u-B1 routers as aimesh-nodes. First I installed the lastest Merlin firmware on all of them. That resultated in a bootloop and the only way out was to revert back. So i reverted al the routers back to the latest stock firmware of ASUS and bind the AC66 agian as an Aimeshnode. The router is very buggy, if i only do a restart it boots several times and i'm afraid to get again in bootloop. Also the protocol 0800 is buggy message is in my log. My configuration is an Ziggo Modem bridged to AC86U -> an TP link switch and two AC66u B1 nodes. I hope anyone van tell me the trick and i can solve this because before the AC66U was my router and rock stable!
I have an issue with 5Ghz wifi in Beta 2.
If I choose to Enable 160 Mhz and Control Channel: Auto, the channel 100 is on and all seems to be working. However, if I set the channel 100 manually, 5Ghz is off and doesn't present in Air. The same problem with other manually set up channels, 112, 116 etc.
It can take several minuts to get 5Ghz up and working.
I've seen "internet disconnected" four times, requiring router reboot to restore internet connection (Motorola modem did not need rebooting): happened three times after hitting Apply settings in NordVPNManager to apply a second VPN client; once during the night for reasons unknown.
Yesterday I flashed 386.1 Beta 2 onto a new RT-AX86U, followed by a factory reset and manual settings - duplicating an existing RT-AC66U_B1 on Merlin 384.18: e.g.: VPN server and two VPN clients, FlexQos, USB drive, Skynet, Diversion, NordVPNManager.
Example in the log at 07:11:00 where apply NordVPNManager settings leads to internet disconnected.
Dec 28 07:10:36 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=46.148.233.53 DST=xxx LEN=40 TOS=0x00 PREC=0x20 TTL=227 ID=15269 PROTO=TCP SPT=58355 DPT=16306 SEQ=3691414351 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Dec 28 07:10:47 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=46.148.233.50 DST=xxx LEN=40 TOS=0x00 PREC=0x20 TTL=228 ID=35637 PROTO=TCP SPT=58508 DPT=17848 SEQ=3992996309 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Dec 28 07:10:48 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=46.148.233.44 DST=xxx LEN=40 TOS=0x00 PREC=0x20 TTL=224 ID=41593 PROTO=TCP SPT=57563 DPT=8960 SEQ=1662191137 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Dec 28 07:10:48 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=193.27.229.207 DST=xxx LEN=40 TOS=0x00 PREC=0x20 TTL=226 ID=45300 PROTO=TCP SPT=41126 DPT=8299 SEQ=2525042631 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Dec 28 07:10:50 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=45.129.33.56 DST=xxx LEN=40 TOS=0x00 PREC=0x20 TTL=231 ID=56467 PROTO=TCP SPT=48840 DPT=32077 SEQ=1824859782 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Dec 28 07:10:58 rc_service: httpd 1501:notify_rc start_vpnmgr
Dec 28 07:10:58 custom_script: Running /jffs/scripts/service-event (args: start vpnmgr)
Dec 28 07:10:58 custom_script: Running /jffs/scripts/service-event-end (args: start vpnmgr)
Dec 28 07:10:58 vpnmgr: Updated settings from WebUI found, merging into /jffs/addons/vpnmgr.d/config
Dec 28 07:10:59 vpnmgr: Merge of updated settings from WebUI completed successfully
Dec 28 07:10:59 vpnmgr: Configuring scheduled update for VPN client 2
Dec 28 07:10:59 vpnmgr: Scheduled update created for VPN client 2
Dec 28 07:10:59 vpnmgr: Retrieving recommended VPN server using NordVPN API with below parameters
Dec 28 07:10:59 vpnmgr: Protocol: UDP - Type: Standard - Country: United States - City: San Francisco
Dec 28 07:11:00 vpnmgr: Updating VPN client 2 to NordVPN server
Dec 28 07:11:00 rc_service: service 7336:notify_rc restart_vpnclient2
Dec 28 07:11:00 custom_script: Running /jffs/scripts/service-event (args: restart vpnclient2)
Dec 28 07:11:00 vpnmgr: VPN client 2 updated successfully (US6510 Standard UDP)
Dec 28 07:11:00 ovpn-client2[3050]: event_wait : Interrupted system call (code=4)
Dec 28 07:11:00 ovpn-client2[3050]: SIGTERM received, sending exit notification to peer
Dec 28 07:11:01 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=46.148.233.45 DST=xxx LEN=40 TOS=0x00 PREC=0x20 TTL=227 ID=53402 PROTO=TCP SPT=57961 DPT=9262 SEQ=1796961260 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Dec 28 07:11:01 ovpn-client2[3050]: vpnrouting.sh tun12 1500 1584 10.8.0.6 255.255.255.0 init
Dec 28 07:11:01 openvpn-routing: Configuring policy rules for client 2
Dec 28 07:11:01 openvpn-routing: Tunnel down - VPN client access blocked
Dec 28 07:11:02 ovpn-client2[3050]: Closing TUN/TAP interface
Dec 28 07:11:02 ovpn-client2[3050]: net_addr_v4_del: 10.8.0.6 dev tun12
Dec 28 07:11:02 lldpd[1367]: removal request for address of 10.8.0.6%38, but no knowledge of it
Dec 28 07:11:02 ovpn-client2[3050]: ovpn-down 2 client tun12 1500 1584 10.8.0.6 255.255.255.0 init
Dec 28 07:11:02 ovpn-client2[3050]: SIGTERM[soft,exit-with-notification] received, process exiting
Dec 28 07:11:02 ovpn-client2[7578]: --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Dec 28 07:11:02 ovpn-client2[7578]: OpenVPN 2.5.0 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Dec 14 2020
Dec 28 07:11:02 ovpn-client2[7578]: library versions: OpenSSL 1.1.1i  8 Dec 2020, LZO 2.08
Dec 28 07:11:02 custom_script: Running /jffs/scripts/service-event-end (args: restart vpnclient2)
Dec 28 07:11:02 ovpn-client2[7579]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Dec 28 07:11:02 ovpn-client2[7579]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Dec 28 07:11:02 ovpn-client2[7579]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Dec 28 07:11:02 ovpn-client2[7579]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Dec 28 07:11:02 ovpn-client2[7579]: TCP/UDP: Preserving recently used remote address: [AF_INET]209.58.128.96:1194
Dec 28 07:11:02 ovpn-client2[7579]: Socket Buffers: R=[524288->1048576] S=[524288->1048576]
Dec 28 07:11:02 ovpn-client2[7579]: UDP link local: (not bound)
Dec 28 07:11:02 ovpn-client2[7579]: UDP link remote: [AF_INET]209.58.128.96:1194
Dec 28 07:11:02 ovpn-client2[7579]: TLS: Initial packet from [AF_INET]209.58.128.96:1194, sid=372b52a8 6f2a6399
Dec 28 07:11:02 ovpn-client2[7579]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Dec 28 07:11:02 ovpn-client2[7579]: VERIFY OK: depth=1, C=PA, O=NordVPN, CN=NordVPN CA5
Dec 28 07:11:02 ovpn-client2[7579]: VERIFY KU OK
Dec 28 07:11:02 ovpn-client2[7579]: Validating certificate extended key usage
Dec 28 07:11:02 ovpn-client2[7579]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Dec 28 07:11:02 ovpn-client2[7579]: VERIFY EKU OK
Dec 28 07:11:02 ovpn-client2[7579]: VERIFY OK: depth=0, CN=us6510.nordvpn.com
Dec 28 07:11:02 ovpn-client2[7579]: Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Dec 28 07:11:02 ovpn-client2[7579]: [us6510.nordvpn.com] Peer Connection Initiated with [AF_INET]209.58.128.96:1194
Dec 28 07:11:03 ovpn-client2[7579]: SENT CONTROL [us6510.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Dec 28 07:11:03 ovpn-client2[7579]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 103.86.96.100,dhcp-option DNS 103.86.99.100,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,comp-lzo no,route-gateway 10.8.3.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.8.3.9 255.255.255.0,peer-id 5,cipher AES-256-GCM'
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: timers and/or timeouts modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: explicit notify parm(s) modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: compression parms modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Dec 28 07:11:03 ovpn-client2[7579]: Socket Buffers: R=[1048576->1048576] S=[1048576->1048576]
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: --ifconfig/up options modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: route options modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: route-related options modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: peer-id set
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: adjusting link_mtu to 1656
Dec 28 07:11:03 ovpn-client2[7579]: OPTIONS IMPORT: data channel crypto options modified
Dec 28 07:11:03 ovpn-client2[7579]: Data Channel: using negotiated cipher 'AES-256-GCM'
Dec 28 07:11:03 ovpn-client2[7579]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 28 07:11:03 ovpn-client2[7579]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 28 07:11:03 ovpn-client2[7579]: net_route_v4_best_gw query: dst 0.0.0.0
Dec 28 07:11:03 ovpn-client2[7579]: net_route_v4_best_gw result: via 25.0.8.1 dev tun11
Dec 28 07:11:03 ovpn-client2[7579]: TUN/TAP device tun12 opened
Dec 28 07:11:03 ovpn-client2[7579]: TUN/TAP TX queue length set to 1000
Dec 28 07:11:03 ovpn-client2[7579]: net_iface_mtu_set: mtu 1500 for tun12
Dec 28 07:11:03 ovpn-client2[7579]: net_iface_up: set tun12 up
Dec 28 07:11:03 ovpn-client2[7579]: net_addr_v4_add: 10.8.3.9/24 dev tun12
Dec 28 07:11:03 ovpn-client2[7579]: ovpn-up 2 client tun12 1500 1584 10.8.3.9 255.255.255.0 init
Dec 28 07:11:03 openvpn: Forcing 192.168.50.49 to use DNS server 103.86.96.100
Dec 28 07:11:05 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=3c:7c:3f:6a:24:f8:00:01:5c:63:2c:46:08:00 SRC=162.142.125.64 DST=xxx LEN=44 TOS=0x00 PREC=0x20 TTL=34 ID=63280 PROTO=TCP SPT=65519 DPT=8845 SEQ=1107300190 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000 [/FONT][/SIZE]
UPDATE: just saw on another thread this may be related to running two VPN clients - I'll remove one client and try that, e.g.:
Saw the known issue not to use the first guest network with 386.1 Beta 2. Still I'd like to run two guest networks: on the second and third guest network slots. The third guest network shows "Default setting by Alexa/IFTTT". Anyone know what this means? Trying to maintain an Alexa free household here (I hope my new AX-86U does not have a microphone :)).
To have no problems with 160MHz BW, I manually set the channel to 36 and all works fine.
I just did a build fresh copy from GitHub. Getting the following error with skynet. I did a force update from the command line. Did not fix it.
Router Model;
Skynet Version; (01/12/2020) (358a0e65e85afa8425897a993eb84b8c)
iptables v1.4.15 - (eth0 @ 192.168.1.1)
ipset v7.6, protocol version: 7
IP Address;
FW Version; 386.1_beta3-gb24eb3c656 (Dec 28 2020) (4.1.51)
Install Dir; /tmp/mnt/sda1/skynet (50.7G / 56.2G Space Available)
/jffs/scripts/firewall: line 1: arithmetic syntax error
admin@RT-AX88U-5918:/jffs/scripts#
lol. If you connect the router to Alexa (alexa based device such as echo, etc) and then tell the smart speaker "turn on guest wifi" or "turn off guest wifi", it will target the third one.
Good for you and all your neighbours using the same 36-40 channels.
The correct answer comes straight after my question. I should wait for 10 minutes.
I have the luck to live in a area with no 5GHz neighbours.
386.1 Beta 3 is now available.
Note that the RT-AX86U build is a Frankenbuild containing pieces from four different releases...
Changes since beta 2:
1b79675d07 Updated documentation
e39ec6d7a4 amas-utils: update RT-AX86U components from 386_41157
1f605b7e5f SDK 5.02: Update addvtoken tool for RT-AC86U
ff2a2d09d7 bwdpi: update RT-AX86U components from 384_41157 FW image
809348cdf6 SDK 5.02p1: add wl_server_socket retrieved from 386_41156 RT-AX86U FW image
04dc297351 Add missing binary blobs for RT-AX56U and RT-AX58U
e07bac6faf Refresh 386_41350 binary blobs for RT-AC68U/RT-AC86U/RT-AC88U/RT-AC5300 from GPL tarballs
380955f012 httpd: delete backed up cert when generating a new cert was requested by the user
1a7ee5b918 build: added addvtoken to copy-prebuilt
d56beb5779 Merge 386_41350 binary blobs for GT-AC2900
b24eb3c656 Merge HND5.02 SDK from 386_41350
94adc38000 build: remove exception that disabled Ookla speedtest on RT-AX56U/RT-AX58U
9fc204773a httpd: implement runner status report for RT-AC86U/GT-AC2900; fix unknown status report
8848e1dc18 webui: add Wifi Radar images to RT-AX56U sysdeps
a1d0a960e4 openvpn: use iproute2 instead of netlink for all platforms
e80b4095e4 others: remove legacy entware-setup.sh symlink
33964aba35 build: disable RSAv2 key usage
96aec67417 Bumped revision to beta 3
8b34a6ff41 Updated documentation
37f085dca2 build: updated copy-prebuilt: handle both GPL and prebuilt archives, removed cloudcheck
488dd205e9 Merge 386_41350 SDK + binary blobs for RT-AX56U and RT-AX58U
7e4c6049c9 Merge 386_41350 binary blobs for RT-AC86U
101cfdadbc Merge 386_41350 binary blobs for RT-AC3100
5eb87e84b6 Merge 386_41350 binary blobs for RT-AC5300
cc7bc87f3f Merge 386_41350 binary blobs for RT-AC88U
1df62e60ec Merge 386_41350 SDK + binary blobs for RT-AX88U
db2cd91504 webui: switched to Asus's own clientid/vendorid WAN fields; fixed JS error due to missing element IDs
c9a308469a inadyn: resync with Asus's code
a87997fce3 Merge 386_41350 binary blobs for RT-AC68U
8a6519445b Merge with GPL 386_41350 (from RT-AX88U)
I thought you didn't want to do more of this and keep it simple?
It's out of necessity, not by choice. Asus has been working on that model's GPL for almost two weeks now, and I didn't want to delay any longer just for that model. Beside, those components are still compatible with the newer GPL code in use, and didn't require any special kludge or separate code branching.
A rare occurrence...a firmware from @RMerlin that is ahead of the Beta releases from Asus. Nice, can't wait to try it out.
Edit: It's looking like we might (nearly?) get to a final 386.1 release close to the end of this year, as I joked/asked of @RMerlin way back in July when the first 386 RC2 Beta appeared over on the "official" side of the forum.
Upgraded 3 APs to Beta 3 tonight... no issues during that process. Will give them all a 2nd power cycle in a bit. We'll see what tomorrow brings.
Cheers to @RMerlin as always.
Having issues accessing cameras via OPENVPN Server on AX-86U on both Beta 2 and Beta 3. This is from OVPN client on Iphone. The logs from OPENVPN and SYSLOG follow. Anyone else having issues with OPENVPN Server on AX-86U?
Dec 29 14:08:25 RT-AX86U-AC30 ovpn-server2[3021]: client/1.129.110.41:19678 SIGTERM[soft,remote-exit] received, client-instance exiting
Dec 29 14:08:39 RT-AX86U-AC30 ovpn-server1[2734]: Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Dec 29 14:08:39 RT-AX86U-AC30 ovpn-server1[2734]: Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Dec 29 14:08:39 RT-AX86U-AC30 ovpn-server1[2734]: TCP connection established with [AF_INET]1.129.110.41:1714
Dec 29 14:08:39 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 TLS: Initial packet from [AF_INET]1.129.110.41:1714, sid=b24fb0c1 bef02c69
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=RT-AX86U, emailAddress=me@asusrouter.lan
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=client, emailAddress=me@asusrouter.lan
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_VER=3.git::2952f561
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_PLAT=ios
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_NCP=2
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_TCPNL=1
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_PROTO=2
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_IPv6=0
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_GUI_VER=net.openvpn.connect.ios_3.2.2-3507
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_SSO=openurl
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 peer info: IV_BS64DL=1
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 TLS: Username/Password authentication succeeded for username 'joescian'
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 2048 bit RSA
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: 1.129.110.41:1714 [client] Peer Connection Initiated with [AF_INET]1.129.110.41:1714
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 MULTI_sva: pool returned IPv4=10.8.0.2, IPv6=(Not enabled)
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 MULTI: Learn: 10.8.0.2 -> client/1.129.110.41:1714
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 MULTI: primary virtual IP for client/1.129.110.41:1714: 10.8.0.2
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 Data Channel: using negotiated cipher 'AES-256-GCM'
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 PUSH: Received control message: 'PUSH_REQUEST'
Dec 29 14:08:40 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.2.0 255.255.255.0 vpn_gateway 500,dhcp-option DOMAIN RT-AX86U-DOMAIN,dhcp-option DNS 192.168.2.242,redirect-gateway def1,route-gateway 10.8.0.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.8.0.2 255.255.255.0,peer-id 0,cipher AES-256-GCM' (status=1)
Dec 29 14:10:31 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 Connection reset, restarting [0]
Dec 29 14:10:31 RT-AX86U-AC30 ovpn-server1[2734]: client/1.129.110.41:1714 SIGUSR1[soft,connection-reset] received, client-instance restarting
Dec 29 14:10:33 RT-AX86U-AC30 ovpn-server2[3021]: 1.129.110.41:14158 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Dec 29 14:10:33 RT-AX86U-AC30 ovpn-server2[3021]: 1.129.110.41:14158 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Dec 29 14:10:33 RT-AX86U-AC30 ovpn-server2[3021]: 1.129.110.41:14158 TLS: Initial packet from [AF_INET]1.129.110.41:14158, sid=06b57b9f dd8734ca
Dec 29 14:10:34 RT-AX86U-AC30 ovpn-server2[3021]: 1.129.110.41:14158 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=RT-AX86U, emailAddress=me@asusrouter.lan
Dec 29 14:10:34 RT-AX86U-AC30 ovpn-server2[3021]: 1.129.110.41:14158 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=client, emailAddress=me@asusrouter.lan
D
Dec 29 14:07:51 RT-AX86U-AC30 kernel: CONSOLE: 077364.104 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:08:51 RT-AX86U-AC30 kernel: CONSOLE: 077423.796 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:09:51 RT-AX86U-AC30 kernel: CONSOLE: 077483.489 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:10:51 RT-AX86U-AC30 kernel: CONSOLE: 077543.182 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:11:51 RT-AX86U-AC30 kernel: CONSOLE: 077602.874 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:12:51 RT-AX86U-AC30 kernel: CONSOLE: 077662.568 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:13:51 RT-AX86U-AC30 kernel: CONSOLE: 077722.262 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:14:42 RT-AX86U-AC30 kernel: wl0: random key value: FF71090D3A1EEA3215BE004E8EA680869EEBAF29E5FB0C3BA5C3CDB7FF6A67CB
Dec 29 14:14:42 RT-AX86U-AC30 hostapd: eth6: STA 04:d4:c4:45:f4:41 IEEE 802.11: disassociated
Dec 29 14:14:42 RT-AX86U-AC30 kernel: wl0: set timeout 5 secs to wait dev reg finish
Dec 29 14:14:42 RT-AX86U-AC30 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 0
Dec 29 14:14:42 RT-AX86U-AC30 kernel: br0: port 11(wds0.0.1) entered disabled state
Dec 29 14:14:42 RT-AX86U-AC30 kernel: br0: port 10(wds0.0.1.0) entered disabled state
Dec 29 14:14:42 RT-AX86U-AC30 kernel: br1: port 9(wds0.0.1.501) entered disabled state
Dec 29 14:14:42 RT-AX86U-AC30 kernel: device wds0.0.1 left promiscuous mode
Dec 29 14:14:42 RT-AX86U-AC30 kernel: [0;33;41m[ERROR vlan] vlanIoctl ,657: Failed to delete VLAN device wds0.0.1.501[0m
Dec 29 14:14:42 RT-AX86U-AC30 kernel: [0;33;41m[ERROR vlan] vlanIoctl ,657: Failed to delete VLAN device wds0.0.1.0[0m
Dec 29 14:14:51 RT-AX86U-AC30 kernel: CONSOLE: 077781.957 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy
Additional logs from syslog - seems to be a kernel crash? This is beta 3 on AX-86U- Wonder if these failed status messages and crash are related to OPenVPN server?
Dec 29 14:16:51 RT-AX86U-AC30 kernel: CONSOLE: 077901.346 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:17:51 RT-AX86U-AC30 kernel: CONSOLE: 077961.039 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:18:51 RT-AX86U-AC30 kernel: CONSOLE: 078020.734 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:19:51 RT-AX86U-AC30 kernel: CONSOLE: 078080.426 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:20:51 RT-AX86U-AC30 kernel: CONSOLE: 078140.117 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:21:51 RT-AX86U-AC30 kernel: CONSOLE: 078199.810 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:22:29 RT-AX86U-AC30 kernel: wl0: PSM microcode watchdog fired at 2306 (seconds). Resetting.
Dec 29 14:22:29 RT-AX86U-AC30 kernel: wl0: reason = psm watchdog at 2306 seconds. corerev 131 ucode revision 1570.159 features 0x3106
Dec 29 14:22:29 RT-AX86U-AC30 kernel: psmdebug 0x01ff000c phydebug 0x0 macctl 0x84160403 maccmd 0x4
Dec 29 14:22:29 RT-AX86U-AC30 kernel: psm_brc 0x0080 psm_brc_1 0x0240 M_UCODE_DBGST 0x2
Dec 29 14:22:29 RT-AX86U-AC30 kernel: brwk_0 0x058b brwk_1 0x0014 brwk_2 0x2a80 brwk_3 0x0ff0 brwk_4 0x0006
Dec 29 14:22:29 RT-AX86U-AC30 kernel: ifsstat      0xaf   ifsstat1     0xff   txectl       0x4992 txestat      0x405
Dec 29 14:22:29 RT-AX86U-AC30 kernel: rxestat1     0x481  rxestat2     0x80   rcv_frmcnt   0x0    rxe_rxcnt    0x0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: wepctl       0x35
Dec 29 14:22:29 RT-AX86U-AC30 kernel: aqmf_ready0  0x0    aqmf_ready1  0x10   aqmf_ready2  0x0    aqmf_ready3  0x0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: aqmf_ready4  0x0    wepstat      0x8000 wep_ivloc    0x1a   wep_psdulen  0x0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: rxe_errval   0x80   rxe_errmask  0x20f  rxe_status3  0x20a  txe_status2  0x405
Dec 29 14:22:29 RT-AX86U-AC30 kernel: dbg_bmc_status 0x0    psm_chk0_err 0x0    psm_chk1_err 0x0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: PC :
Dec 29 14:22:29 RT-AX86U-AC30 kernel: R0: 0x1860     0x1860     0x1860     0x1860
Dec 29 14:22:29 RT-AX86U-AC30 kernel: psm stack_status : 0x8000
Dec 29 14:22:29 RT-AX86U-AC30 kernel: psm stack_entries:
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x1860
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x1965
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x1dff
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x1ab0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x36cb
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x0299
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x10f0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0x0afd
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 0) usr_count = 0, schedid = 0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 1) usr_count = 0, schedid = 0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 2) usr_count = 0, schedid = 0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: 3) usr_count = 0, schedid = 0
Dec 29 14:22:29 RT-AX86U-AC30 kernel: wl0: fatal error, reinitializing, total count of reinit's[1]
Dec 29 14:22:51 RT-AX86U-AC30 kernel: CONSOLE: 078259.505 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
Dec 29 14:23:52 RT-AX86U-AC30 kernel: CONSOLE: 078319.199 wl1: wlc_ampdu_recv_addba_resp: 54:60:09:7c:93:9e: Failed. status 37 wsize 16 policy 1
