jorhett
Everything works just fine with a self-signed certificate.
Certainly MitM is easiier
Does Let's Encrypt work with custom ddns providers? Using a cloudflare custom script, and Let's encrypt is stuck at "authorizing". However, running /sbin/le_acme runs fine and generated all the certificates. UI still stuck at "authorizing".
Nothing about acme or Let's Encrypt in the logs.
The MTU would be set as empty, which would stop all internet access.
I ran this command and my temps dropped immediately from 95C to 85C. A little warmer than the 80C with Beta2.Running the command "pwr config --wait on" has re-enabled the CPU wait state.
Temps are slowly dropping towards 90 degrees now.
Thanks for the root cause analysis @RMerlin. Will keep an eye on temps. No concerns on my two RT-AC86U's yet. Summer time will be an issue for the one in my garage though as the ambient temps get up there. Maybe I'll have a new router by then... heh.As I suspected, this was a deliberate change by Asus in a recent GPL merge.
Code:@@ -3613,6 +3701,9 @@ void init_others(void) #ifdef GTAC2900 update_cfe_ac2900(); #endif +#if defined(RTAC86U) || defined(GTAC2900) + system("pwr config --wait off"); +#endif #if defined(RTAX88U) || defined(RTAX92U) if(nvram_match("HwVer", "1.0")) { system("pwr config --cpuwait off");
No idea why, I can only assume it was to address a specific problem, like how they already do the same on earlier revisions of the RT-AX88U.
If your router is hitting the 100C threshold following this change, then it means it was already running hotter than it should. Make sure you do have some airflow around it (and that it's not in an enclosed cabinet), maybe give it a good dusting just to be sure.
If you still run into CPU throttling, I recommend you test again running Asus's stock 386_41535 firmware, reproduce the issue, then use the Feedback form to notify them.
cooking beta 4 now.....
Ok, I have left my router in this state for most of the day, but as of 11pm, I have been gaming and watching videos etc, which has been keeping the router busy (with Cake QoS enabled), and temps were up at about 97 again even with the CPU wait state enabled.Would guess that command could be run in a startup script on an AC86U pending a fix? Keep us posted on your Temps, please.
As I was checking the stats and logs, I saw the CPU go into thermal overload, and only the one working core was showing on the main page CPU utilisation meter.
Doors are closed, so even though it is evening, I would say the room may still be around 30 degrees ambient. The router is sitting on a desk by a window, so the ventilation can't get much better.
I have had to roll back to beta 2, and immediately my temps are down at 90 degrees and falling. It appears that enabling the CPU wait state is not enough to offset the additional heat that beta 3 has introduced.
You mean the rest of the developed world?RE AC86 Temps
Until now the only temperature issue my ac86u experienced is the setting is stuck on Canadian and won't stay on Foreigner![]()
Certainly MitM is easiier![]()
The big question is why did Asus feel the need to deliberately disable these CPU wait states on this firmware (presumably with full knowledge of the effect on CPU temps). Odd.Back on 386 beta 3. Did a services-start script file to run "pwr config --wait on" and the CPU temp is holding at 83-84 C. Cooling fan on order...
Err..well, if you define "normal" as within operating specification, OK, yes that is true. However, these RT-AC86U units are definitely running at least 6-12C (or more) higher than on previous firmware releases.On 386.1 Beta 3 and RT-AC86U for most customers: temperatures haven't changed. 86C 'normal'. No fans needed. With many being in operation for a year or more.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
