Morpheus2020
Dirty upgrade of RT-AX86U from 386.3_2 to 386.4.
1. Every time the router is turned on, the previous syslog will disappear. And the new syslog starts at a strange location, instead of "May 5 13:05:08 syslogd started: BusyBox v1.25.1".
2. Strange timestamps often appear in syslog.
Does anyone else have similar problems?
Thank you, RMerlin.
Jan 1 00:00:02 kernel: ubi2: attaching mtd10
Jan 1 00:00:02 kernel: ubi2: scanning is finished
Jan 1 00:00:02 kernel: ubi2: attached mtd10 (name "misc1", size 8 MiB)
Jan 1 00:00:02 kernel: ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Jan 1 00:00:02 kernel: ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Jan 1 00:00:02 kernel: ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
Jan 1 00:00:02 kernel: ubi2: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Jan 1 00:00:02 kernel: ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
Jan 1 00:00:02 kernel: ubi2: max/mean erase counter: 95/35, WL threshold: 4096, image sequence number: 1725884149
Jan 1 00:00:02 kernel: ubi2: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Jan 1 00:00:02 kernel: ubi2: background thread "ubi_bgt2d" started, PID 411
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): background thread "ubifs_bgt2_0" started, PID 426
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name "nvram"
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): reserved for root: 0 bytes (0 KiB)
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): media format: w4/r0 (latest is w4/r0), UUID 4B2A44DD-417E-46D8-97CE-24D278768884, small LPT model
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): un-mount UBI device 2
Jan 1 00:00:03 kernel: UBIFS (ubi2:0): background thread "ubifs_bgt2_0" stops
Jan 1 00:00:03 kernel: ubi2: detaching mtd10
Jan 1 00:00:03 kernel: ubi2: mtd10 is detached
Jan 1 00:00:03 kernel: init (1): drop_caches: 1
Jan 1 00:00:03 get_ext_phy_id: 0/1/0/0
Jan 1 00:00:03 jffs2: getting the information of jffs2
Jan 1 00:00:03 jffs2: mounting jffs2
Thank you, RMerlin.
