380.59 beta2 "Enable IPTraffic (per IP monitoring)" setting on a AC56 or 68U using custom location " with NAT acceleration "CTF auto" the AC56 or 68U will not recover, must use the WPS or MASTER reset buttons to recover to defaults.... OLD HAT STUFF!
cheers
Thanks cybrnook and RMerlin, also wanted to know if could experiment with bufferbloat reduction on version _58 for an RT-AC68u.Merlin, are these tweaks specific to this beta build, or can these be used on previous releases as well?
Can't confirm that, with native IPv6 I get similar speeds with IPv4.Has anyone else noticed that Traditional QOS seems broken with ipv6 in this build? The download speeds I see with traditional QOS on are 10% of what they should be per the settings (they're pretty close to the upload speeds actually...) This happens no matter which of the 3 schedulers I choose.
For people who want to experiment even further in bufferbloat reduction, try reducing your network interface queue lengths on your router:
Code:echo "8" > /sys/class/net/eth0/tx_queue_len echo "40" > /sys/class/net/eth1/tx_queue_len echo "40" > /sys/class/net/eth2/tx_queue_len
These would work for any router models.
admin@RT-AC87U:/tmp/home/root# cat /sys/class/net/eth1/tx_queue_len
1000
admin@RT-AC87U:/tmp/home/root# cat /sys/class/net/eth0/tx_queue_len
1000
admin@RT-AC87U:/tmp/home/root# cat /sys/class/net/eth2/tx_queue_len
cat: can't open '/sys/class/net/eth2/tx_queue_len': No such file or directory
if you don`t have 2.4Ghz clients you can safely disable 2.4Ghz network.....i have three 5Ghz clients and i disabled 2.4Ghz network.....all working fine....I'm seeing some frequent disconnects of the 2.4GHz, i.e. 1 every 30-90 seconds. Stats:
Anybody else seeing this behaviour on 2.4 GHz? the 5GHz seems a lot more stable
tntfs: disagrees about version of symbol generic_file_splice_read
tntfs: Unknown symbol generic_file_splice_read (err -22)
tntfs: disagrees about version of symbol generic_file_splice_write
tntfs: Unknown symbol generic_file_splice_write (err -22)
tntfs: disagrees about version of symbol kernel_recvmsg
tntfs: Unknown symbol kernel_recvmsg (err -22)
tntfs: disagrees about version of symbol unregister_sysctl_table
tntfs: Unknown symbol unregister_sysctl_table (err -22)
tntfs: disagrees about version of symbol register_sysctl_table
tntfs: Unknown symbol register_sysctl_table (err -22)
tfat: disagrees about version of symbol generic_file_splice_read
tfat: Unknown symbol generic_file_splice_read (err -22)
tfat: disagrees about version of symbol generic_file_splice_write
tfat: Unknown symbol generic_file_splice_write (err -22)
tfat: disagrees about version of symbol kernel_recvmsg
tfat: Unknown symbol kernel_recvmsg (err -22)
tfat: disagrees about version of symbol unregister_sysctl_table
tfat: Unknown symbol unregister_sysctl_table (err -22)
tfat: disagrees about version of symbol register_sysctl_table
tfat: Unknown symbol register_sysctl_table (err -22)
Model
RT-AC68U
Firmware Version
380.59_beta2
Driver version
wl0: Apr 12 2016 13:03:45 version 6.37.14.126 (r561982)
Features
mssid 2.4G 5G update usbX2 switchctrl manual_stb pwrctrl WIFI_LOGO nandflash ipv6 dualwan pptpd openvpnd printer appnet snmp tor diskutility HTTPS ssh vpnc repeater psta wl6 optimize_xbox wifi_tog_btn nfsd dnssec user_low_rssi sparse bcmfa rog tcode usericon stainfo reboot_schedule
IPSEC=y
MEDIASRV=n
MODEM=n
MODEMPIN=n
PARENTAL2=n
WEBDAV=n
CLOUDSYNC=n
EMAIL=n
DROPBOXCLIENT=n
TIMEMACHINE=n
MDNS=n
JFFS2LOG=n
BWDPI=n
SWEBDAVCLIENT=n
BCM5301X_TRAFFIC_MONITOR=n
CLOUDCHECK=n
DNSFILTER=n
On my AC68u there is no such trouble. Works fine like before.Anybody else seeing this behaviour on 2.4 GHz? the 5GHz seems a lot more stable
unfortunately I need both..if you don`t have 2.4Ghz clients you can safely disable 2.4Ghz network.....i have three 5Ghz clients and i disabled 2.4Ghz network.....all working fine....![]()
Was the AC66 binary updated to 2695 or is that still not available? They have the beta firmware up on https://www.asus.com/support/Download/11/2/0/84/LzShv8ma7TrQB4eO/30/
Awesome. Merlin only said for the AC58 and N66 so was wondering if the AC66 was included.The relevant binary blobs from an Asus 2695 GPL code were included
https://github.com/RMerl/asuswrt-merlin/commit/c984bfa78083b82f3dec9c47b28951fcacd0870b
What are the new dependencies for the Tuxera filesystem drivers, tntfs.ko and tfat.ko, in the RT-AC68U Asuswrt-Merlin firmware 380.59? See the log.
Welcome To SNBForums
