Thiago Luttig
Also have a rt-ac3100 ans qos does not work. From past threads and Merlin feedbacks, this is an issue with ASUS coding.
Sent from my D6633 using Tapatalk
From the post #1(maybe its your case)
Note that Traditional QoS is still broken with the newer models
Which router model shows this issues? Without posting the router model it's a useless message...The only strangeness I encountered is typing the routers IP address in initially would not let me into the router with beta 1. I had to powercycle the router, and then i was able to access the GUI and do the update.
One other issue i've been seeing consistently, so I think its an ASUS problem, is that the clients I have running on 5 ghz believe they are getting a strong signal, and run quickly (500+), but when I check things out from the router side it says they are getting very low signal.
Sorry, I was moving a bit too fast. Its the 88u.Which router model shows this issues? Without posting the router model it's a useless message...![]()
I think adaptive is broken or not working very well also
I tried it out for the first time in ages yesterday
Adaptive With Automatic/Games
Idle connection
Buffer bloat goes to C (A if QOS is off)
Active Connection
Device Lowest priority torrent doing 76 mbit down 19 mbit up
Device Highest priority (Xbox Network Test)
5% packet loss
0.2 mbit upload
17 mbit download
Same Scenario with qos off
0% packet loss
14 mbit upload
47 mbit download
A speed test on a pc at speedtest.net
seems to be handled properly by adaptive qos
with said active torrent a speed test
benchmarks 75 mbit down and 17.55 mbit up
AC56u and beta 2 running solid for 48 hrs now. Openvpn, ipv6 & traditional QoS running fine like before. I get F bufferbloat without QoS and A with it on. So far so good.
Actually I'm using the adaptive setting and not traditional as I mispoke earlier. I manually set it to 55/6 (advertised speed 50/5 from TWC) and select the Media Streaming priority if that makes a difference.Which version of QoS are you using? (Just curious).
I too get similar results for buffer bloat and using QoS fixes it.
On my RT-AC68U (same processor hardware as your 'AC56U) I actually get A+ with Adaptive QoS on with 106d/23u manually set for an ISP (fibre) 120d/45u max ISP speeds and 1ms latency on Ookla speedtest with IPv6, 3 OpenVPN clients, 2 OpenVPN servers, AiProtection (all enabled, including OpenDNS family protection; globally set).
I don't see how your setup with the QOS would work because there is a known bug that all VPN traffic shows up as upload.Which version of QoS are you using? (Just curious).
I tried official firmware from Asus but issue is the same. I can't change anything. Can anybody help me?Thanks for you answer!
Unfortunately I can't make any changes in upstream router (it is from my internet provider).
DNS server is not hard coded anywhere (as I wrote before I can't change ANY of settings after initial Setup Wizard). Everything worked fine on previous versions of your firmware (at least last 3-4 years).
I tried to change DNS to 8.8.8.8 and 8.8.4.4 in DNS and WAN but situation is the same.
Do you have any other idea?
I know that there are no Mipsel builds yet, but there's a bug unfixed (maybe known) in .59 with WLAN leds (AC66U) - when router boots up - there's no light for 5GHz radio, only 2.4 GHz, but both radios work. Disabling and re-enabling radio enables that indicator.
Maybe this issue can be fixed in .60
Edit: Pausing & playing movie does not help. Just dropped connection ~30 seconds after pause/play. Seems to be random timing but it is doing consistently, cannot watch a movie like this.
Welcome To SNBForums
