[Beta] Asuswrt-Merlin 380.65 Beta is now available
So far Beta 4 running fine on RT-AC3100 (Still same quirks as I have pointed out before though...)
This is most likely the same non-sense that was also breaking IPv6.
IPv6 is still broken. Both under stateless and stateful. Clients lose the link local address (fe80) of the router (RT-AC88U) after extended use.
With the clients no longer having an IPv6 default gateway to leverage, the IPv6 Internet traffic comes crashing down.
@RMerlin
Just upgraded from the latest stable version to beta 3 on the AC-88U. Ever since then, wifi calling is no longer working (WLAN-Call bei der deutschen Telekom). Any idea why that might be? I've already restarted the router but without success.
Make sure you got IPSEC pass-through enabled. I believe most Wifi calling implementations rely on it.
Why no beta 4 for 5300? I have the same problems with scanners and 2.4 band.
Because compiling all 9 models takes over an hour (it used to be close to 1h30 with my previous rig). I just wanted to quickly have the most popular models ready before heading to bed.
That's also why it was just uploaded to the Test Builds folder rather than a formal beta release. That will come once I've completed cleaning up the GPL revert.
Enabling ipsec passthrough fixed the issues (on beta 4). But: I did not have to have passthrough enabled on the last stable version, so something definitely changed here.
Has anything changed with this beta (380.65beta3) in regards to the syslogd? ... i have a script which kills it and replaces it with syslog-ng, but it seems to have restarted. Is there some process relaunching it which i need to deal with?
AC3100 working well with Beta 4. No more erratic client list and disappearing devices. Thank you for reverting 4180 RMerlin. Hopefully Broadcom/Asus can get their code in order.
I ran the beta 3 and now the 4.
Printer is a cheapo Brother totally wireless. works on either beta
That may be due to router models and these issues-+?
Asus might have fixed the passthrough perhaps. In any case, I didn't change anything here, and since Wifi calling requires IPSEC, it makes sense for this feature to require being enabled.
I haven't changed anything there.
Ok thanks Merlin.... the script looks like this
kill_syslogd(){
    if [[ ! -z $(pidof syslogd) ]]; then
        killall syslogd
        cat /tmp/syslog.log >> /opt/var/log/messages
        rm  /tmp/syslog.log /tmp/syslog.log-1
        ln -s /opt/var/log/messages /tmp/syslog.log
    fi
just want to confirm that killall will still work on this version of syslogd ( new busy box version right?)
