[Beta] Asuswrt-Merlin 384.11 Beta is now available
sorry, it's not available. only dig from bind-dig package
the only time i run into issues with dig is if i try the
-6 (use IPv6 query transport only)
option -it hangs trying to do these test
Correction if i tell it which @ address to test at it then will work giving a response.
I just wish i knew why i get no response with dig -6 ipv6.google.com
dig -6 www.google.com
^Cdighost.c:4184: INSIST(current_lookup == ((void *)0)) failed.
Aborted
dig -4 www.google.com
; <<>> DiG 9.12.3-P4 <<>> -4 www.google.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 62266
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;www.google.com.                        IN      A
;; ANSWER SECTION:
www.google.com.         139     IN      A       172.217.1.100
;; Query time: 1 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Thu May 02 16:20:38 UTC 2019
;; MSG SIZE  rcvd: 59
drill -6 www.google.com
Error: error sending query: No (valid) nameservers defined in the resolver
I take it that drill is telling me that it cannot act solely on ipv6 alone.
 drill -6 www.google.com @::1
;; ->>HEADER<<- opcode: QUERY, rcode: NOERROR, id: 19518
;; flags: qr rd ra ; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; www.google.com.      IN      A
;; ANSWER SECTION:
www.google.com. 200     IN      A       172.217.3.132
;; AUTHORITY SECTION:
;; ADDITIONAL SECTION:
;; Query time: 720 msec
;; EDNS: version 0; flags: do ; udp: 1452
;; SERVER: ::1
;; WHEN: Thu May  2 16:34:40 2019
;; MSG SIZE  rcvd: 73
drill -4 www.google.com
;; ->>HEADER<<- opcode: QUERY, rcode: NOERROR, id: 30424
;; ANSWER SECTION:
www.google.com. 65      IN      A       172.217.3.132
;; WHEN: Thu May  2 16:36:55 2019
;; MSG SIZE  rcvd: 48
drill -6 www.google.com @127.0.1.1
drill -4 www.google.com @127.0.1.1
;; ->>HEADER<<- opcode: QUERY, rcode: NOERROR, id: 1397
;; ANSWER SECTION:
www.google.com. 214     IN      A       172.217.2.196
;; Query time: 33 msec
;; SERVER: 127.0.1.1
;; WHEN: Thu May  2 16:39:28 2019
not valid. 127.0.1.1 is not ipv6 address, do not use -6 transport option.
"a" address type is not the same as -4 transport to get it, same as "aaaa" address is different from ipv6 -6 transport.
examples:
dig -4 a google.com @127.0.0.1
dig -4 aaaa google.com @127.0.0.1
dig -6 a google.com @::1
dig -6 aaaa google.com @::1
i understand that miron i was simply seeing what could be hindering -6 from working
Using your suggestions..
; <<>> DiG 9.12.3-P4 <<>> -6 a google.com @::1
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 45127
;google.com.                    IN      A
;; ANSWER SECTION:
google.com.             80      IN      A       172.217.1.110
;; SERVER: ::1#53(::1)
;; WHEN: Thu May 02 17:21:45 UTC 2019
;; MSG SIZE  rcvd: 55
; <<>> DiG 9.12.3-P4 <<>> -6 aaaa google.com @::1
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60703
; EDNS: version: 0, flags: do; udp: 1452
;google.com.                    IN      AAAA
;; ANSWER SECTION:
google.com.             130     IN      AAAA    2607:f8b0:4008:813::200e
;; WHEN: Thu May 02 17:21:19 UTC 2019
;; MSG SIZE  rcvd: 77
;; Got answer:
;google.com.                    IN      A
;; ANSWER SECTION:
;; Got answer:
;; ANSWER SECTION:
You can safely bet that drill works too giving "softer" responses
yep, and results are the same with -4 + @127.0.0.1.
this means everything works as expected, and any type of address (a/aaaa - ipv4/ipv6) can be requested via any type of transport (ipv4/ipv6 connection).
p.s it's possible to use +short for less dig output
dig +short aaaa bin.entware.net @127.0.0.1
2606:4700:30::681b:b132
2606:4700:30::681b:b032
I think these test lays it to rest that IPV6 is functioning as it should.
I did not have this behavior before, when no clients are connected on 2GHz id does this Channel shuffles (yes it is on auto - had no issues with it):
May 2 18:21:58 acsd: scan in progress ...
May 2 18:21:59 acsd: scan in progress ...
May 2 18:21:59 acsd: selected channel spec: 0x180a (8l)
May 2 18:21:59 acsd: Adjusted channel spec: 0x180a (8l)
May 2 18:37:00 acsd: scan in progress ...
May 2 18:37:01 acsd: scan in progress ...
May 2 18:37:02 acsd: scan in progress ...
May 2 18:37:03 acsd: selected channel spec: 0x180b (9l)
May 2 18:37:03 acsd: Adjusted channel spec: 0x180b (9l)
May 2 18:52:04 acsd: scan in progress ...
May 2 18:52:05 acsd: scan in progress ...
May 2 18:52:06 acsd: scan in progress ...
May 2 18:52:06 acsd: selected channel spec: 0x180a (8l)
May 2 18:52:06 acsd: Adjusted channel spec: 0x180a (8l)
May 2 19:07:07 acsd: scan in progress ...
And as soon as some client connects, it stops..?
May  2 13:54:40 acsd: selected channel spec: 0x100a (10)
May  2 13:54:40 acsd: Adjusted channel spec: 0x100a (10)
May  2 14:04:12 acsd: selected channel spec: 0xe19b (153/80)
May  2 14:04:12 acsd: Adjusted channel spec: 0xe19b (153/80)
is some that i've had
note there is nothing more suspicious when cloudflare and your isp both have servers in your home town...
Cloudflare has a datacenter 3 blocks from me, but Spectrum (my ISP) backhauls all internet customers in Charlotte over 145 miles to Raleigh before they peer with the rest of the internet, so I connect to Cloudflare in Virginia instead of NC. Still I get a ping of less than 10ms to Cloudflare DNS.
yea so cloudflare and my ISP both have servers here where I am. Ping is relatively the same one may be a couple of milliseconds off from the other at all times. now if i use quad9 my servers are then located in Miami which is 348 miles away. the difference in ping in those is about maybe 8~10 milliseconds and google follows shortly behind. Google servers are all the way in north carolina and texas---Imagine the distance on those.
