hotsauce2007
Been running on this firmware for the last couple of days without any issue. (RT-AC88U).
one more here, with ac86u, no problem at all...
I've notice a potential memory leak on the alpha and also beta (AC68U). I started beta with 118MB of memory used and 6 days later I'm at 129MB. Maybe this higher usage can be attributed to log, traffic analyzer or other data.
I'm not sure but the memory usage is growing daily.Are you certain it's not just the way linux uses memory as it sees fit? ie.. disk caching, buffers, etc?
The "used memory" number reported by the router is misleading at best; memory usage is more complicated than that. Memory that is "used" but can be overwritten immediately is included in the total of "used memory". Is that memory really used? There are a number of ways to get a better idea of the "true" amount of readily available memory, starting with "cat /proc/meminfo" in an ssh session. There are many articles online discussing "free" memory in Linux.I've found this on my RT-AC68 since 382 was first released.
I installed 384.5 33 days ago. After the reboot it was using around 42% of memory. I haven't rebooted since, and now I'm up to 76% of memory used.
I've not yet left the router long enough to see if it hits 100%, or if it eventually stabilizes. But it seems to go up around 1% a day.
Please in english....N17U modeli için merlin desteğini mi düşünüyorsunuz? Gelecekte destekleyecekler mi?
Sorry. Will support for the Asus N17U model come? are we waiting?
If it's just cached/buffers growing (in the output of "free" after ssh-ing into the router) then sure it's not a problem... but the memory management feature is usually enabled (IIRC) by default and that is constantly trying to free those caches... if those aren't what's growing, but the free space continues to drop (or utlization grows) then it's not a case of linux DTRT, but a clear leak somewhere.The "used memory" number reported by the router is misleading at best; memory usage is more complicated than that. Memory that is "used" but can be overwritten immediately is included in the total of "used memory". Is that memory really used? There are a number of ways to get a better idea of the "true" amount of readily available memory, starting with "cat /proc/meminfo" in an ssh session. There are many articles online discussing "free" memory in Linux.
Welcome to the forum.
Supported devices here:
https://github.com/RMerl/asuswrt-merlin/wiki/Supported-Devices
Welcome To SNBForums
