lzkill
Hi folks. I have two RT-AC68R in a mesh setup (386.1_2). My Internet connection is a symmetrical 100 Mbps fiber. On the main router I've enabled QoS and FlexQoS 1.2.2 (amtm). The configuration is adaptative, bandwidth manually set to 90 Mbps, fq_codel selected. The traffic classes are ordered as suggested by the FlesQoS docs (File downloads with the lowest priority).
I can confirm the ping to 8.8.8.8 keeps low on the main router even when someone is downloading a file or making a speed test. What I don't understand is why dslreports give me a bad bufferbloat grade when I run its test from a 2.4 Ghz device. If a run the site's test using the 5GHz band the result is always A+. What am I missing here? The speeds I get on 5GHz is 90 Mbps and 60 Mbps on 2.4 GHz.
I've done all the tests connected to the main router, so I can ignore any latency added by the AiMesh node. I must also add that my ISP does chat, so my main router is not fully exposed to the Internet.
Thanks guys!
Thanks guys!
