Cloudflare inadyn stopped working
Had to troubleshoot a similar problem where inadyn with Cloudflare was previous working for me and broke with a router firmware update. In my case the main cause was the newer inadyn version changing the function of the "username" field to actually want the domain name (previously it was the email address of the Cloudflare account).
The minimal config that works for me is in /jffs/inadyn.conf: -
provider default@cloudflare.com {
        username = mydomain.com
        password = CLOUDFLARE_API_TOKEN
        hostname = myhost.mydomain.com
CLOUDFLARE_API_TOKEN is a custom API token that you create for the zone from Cloudflare's control panel, which must have the permissions Zone.Zone -> Read, Zone.DNS -> Edit
In /jffs/scripts/ddns-start (must have execute permission): -
#!/bin/sh
inadyn --once -f "/jffs/inadyn.conf" -e "/sbin/ddns_custom_updated 1" --continue-on-error "/sbin/ddns_custom_updated 1"
I use the router's inadyn to dnsomatic (in the WebUI) and then dnsomatic pushes to cloudflare. No fiddling required :)
Can you provide an example of your setup in router settings, dnsomatic, and cloudflare?
I'm having issues getting mine setup properly.
PM if you prefer.
