I guess you are right, it is not like your router could suffer from an ntp amplification attack.Exactly it’s BS, time is a timestamp pulse, to set your local time, depending on the interval it can touch your lan as little as once a month.
And DDOS? your router drops those packets. Again I don’t see ANY real world use for us prosumers, other than “because we can”
If it was just released, how could anyone possibly know if it is reliable. By definition, something new is not reliable.They just released a new NTP service at time.cloudflare.com
It's really fast and reliable.
If it was just released, how could anyone possibly know if it is reliable. By definition, something new is not reliable.![]()
a little bit of healthy competition is good, especially in the case of the behemoth the Alphabet companies are.Cloudflare's really trying to mimick google.
When two computers are talking to each other, to ensure smooth and accurate flow of data between them, their two clocks must agree as to how long the base period of time is (seconds, ms, us, ns) and align to achieve synchronization or as close to it as technically possible.I would really like to know what accuracy means for a router, ms, s, min, hour, day???
We often seen routers nev
The less of a ping you have to a time server, the less work the router will have to do to ensure the data moves correctly: offsets eat processing cycles, and that bottlenecks your network connection speed.
While I don’t wish to cross swords with you, sir, I disagree. A few ms here and there add up, causing leap seconds, minutes..
Every aspect of this post is pure fantasy.When two computers are talking to each other, to ensure smooth and accurate flow of data between them, their two clocks must agree as to how long the base period of time is (seconds, ms, us, ns) and align to achieve synchronization or as close to it as technically possible.
The less of a ping you have to a time server, the less work the router will have to do to ensure the data moves correctly: offsets eat processing cycles, and that bottlenecks your network connection speed. Same goes on your home network - you'll achieve closer to maximum theoretical speeds (both wired and wirelessly) consistently if you ensure your devices follow the clock pulse transmitted by your router.
I am very willing to believe you, only thing I dont understand whats the matter with VPN or other security apps and wrong time set to router.Every aspect of this post is pure fantasy.
No what is fantasy is that the average home user needs to "buyin" to every new aspect of internet in order to enjoy the aspects of the services available to everyone.Every aspect of this post is pure fantasy.
You should at least have roughly accurate time to prevent discrepancies between protocols you may be using. For example if you are using privacy protocols like DoT. That doesn't mean you need the greatest and or latest servers to do so.I am very willing to believe you, only thing I dont understand whats the matter with VPN or other security apps and wrong time set to router.
How accurate has it to be to have it running?
Would it be enough lets say 5 min or even a day difference to get it up?
Is there an exact or defined time frame within it would work?
This will all get quite interesting once quantum processing is more accessible to consumers...
delta-t 6546.37 seconds
delta-o 352.9 useconds
slope 0.0539078 ppm
old frequency -1653728 ( -25.2339 ppm)
new frequency -1650196 ( -25.18 ppm)
And absolutely none of that has anything to do with the date and time being set by NTP.Not so sure about that - WiFi needs to actually have a fair amount of accuracy, or it stops working... Consider the framing time between the AP and the Client Station, and this is all time division duplex... the client STA and AP need to keep sync'ed or frames start to show up as errors as the start time will drift.
TDD - the AP and Clients need to be aligned and synced - the AP is easy enough, but it's going to be running in it's own perspective of time - the client is going to run off it's host clock, so Beacon keeps things honest between the two - back to the future so to speak.
3G is even more stringent here...
Thread starter | Title | Forum | Replies | Date |
A | CloudFlare Proxied DNS, can't login to Asus router | Asuswrt-Merlin | 10 | |
L | Cloudflare custom DDNS - In-A-Dyn | Asuswrt-Merlin | 11 | |
E | Cloudflare ddns-start script | Asuswrt-Merlin | 6 | |
J | Cloudflare DDNS 388.6 | Asuswrt-Merlin | 4 |
Welcome To SNBForums
