Diversion Diversion - the Router Ad-Blocker v4.2.x (see new thread for 4.3.x)
Router: AX58U
I downloaded Putty and went on amtm to the format disk (fd) to ext4
This is my log:
user@Users-Air ~ % diskutil list
/dev/disk0 (internal):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                         251.0 GB   disk0
   1:             Apple_APFS_ISC ⁨⁩                        524.3 MB   disk0s1
   2:                 Apple_APFS ⁨Container disk3⁩         245.1 GB   disk0s2
   3:        Apple_APFS_Recovery ⁨⁩                        5.4 GB     disk0s3
/dev/disk3 (synthesized):
   0:      APFS Container Scheme -                      +245.1 GB   disk3
                                 Physical Store disk0s2
   1:                APFS Volume ⁨Macintosh HD⁩            15.3 GB    disk3s1
   2:              APFS Snapshot ⁨com.apple.os.update-...⁩ 15.3 GB    disk3s1s1
   3:                APFS Volume ⁨Preboot⁩                 462.5 MB   disk3s2
   4:                APFS Volume ⁨Recovery⁩                804.6 MB   disk3s3
   5:                APFS Volume ⁨Data⁩                    207.3 GB   disk3s5
   6:                APFS Volume ⁨VM⁩                      1.1 GB     disk3s6
/dev/disk4 (external, physical):
   0:      GUID_partition_scheme                        *15.6 GB    disk4
   1:                        EFI ⁨EFI⁩                     209.7 MB   disk4s1
   2:       Microsoft Basic Data ⁨SanDisk⁩                 15.4 GB    disk4s2
user@Users-Air ~ % diskutil unmountDisk disk4
Unmount of all volumes on disk4 was successful
user@Users-Air ~ % sudo $(brew --prefix e2fsprogs)/sbin/mkfs.ext2 /dev/disk4s2
Password:
mke2fs 1.46.4 (18-Aug-2021)
/dev/disk4s2 contains a exfat file system labelled 'SanDisk'
Proceed anyway? (y,N) y
Creating filesystem with 3764480 4k blocks and 942080 inodes
Filesystem UUID: dd9547ee-79a1-4bf6-8ad2-8ff3635ec63a
Superblock backups stored on blocks:
    32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
And then when I try to install Diversion, I get this
I've been using this mac terminal function to format the drive to ext2, 3 and 4
Essentially my biggest hurdle is fixing this error:
No compatible plugged in USB storage device(s) found to format
How do you configure diversion with unbound? I am using AdGuard and haven’t used diversion in awhile, and want to tinker.
also before i was having an issue with diversion not blocking https quires, is this still an issue?
Notice the careful clarification above. Let diversion do the blocking, and let unbound be the recursive lookup but do not use its blocking feature and don't run another blocker on the router. Install diversion, then install unbound. It should just work.
Diversion blocks the queries fine. Pixelserv won't always respond as it did because the admakers do additional checks.
Hello. It's my first post. I have some problem on my RT-AC86U router, with AsusWRT-Merlin 386.7, latest amtm, diversion 4.3.0.
After updating the hosts file (standard version), the router "locks up", it is impossible to log into the administration page (after entering the login and password, the page loads indefinitely), the MESH connection stops working. The SSH connection is always open and working, but restarting via SSH is not always successful. After restarting the router, everything returns to normal. And so every time I update the hosts file manually. The problem has already appeared in the previous Merlin issue and the previous divesion. Has anyone had a similar problem?
Router: AX58U
This is my log:
Password:
Use amtm fd command to format the disk to ext*
Create a swap file in Diversion or amtm if not already done.
What happened to my router (AC86U, Merlin 386.7, 1.5GB swap) is that after upgrade to Diversion 4.3 dn-vnStat stopped working.
To be more precise, the web interface stopped working. As soon as I try to open the vnstat page, httpd takes 100% and the web UI of the router can't load.
I uninstalled AdGuard home, installed diversion, restarted unbound. All of that works great! However I ameeing this: did I set up something wrong? It looks like the domain is being blocked that uses HTTP but then it being allowed as HTTPS or am I reading It wrong?
This is my MacBook and DNS is showing as my router IP. 192.168.50.1
2022-07-04 09:00metrics-dra.dt.hicloud.com192.168.50.34type=65Allowed
2022-07-04 09:00metrics-dra.dt.hicloud.com192.168.50.34ABlocked (blocking list)
This how I've been dong it for a while now without issue. Diversion's blocking works better than unbound's too, IMO.
Copy paste from the amtm thread...
So I downloaded amtm and diversion onto my USB that's plugged into my router but I'm still seeing ads on Youtube. I went on Putty and went into diversion and everything is enabled.
What am I doing wrong?
Have you done these steps? I may be wrong but I believe that feature is hit or miss.
Is there anything reliable out there as an alternative?
For YouTube apps installed on iOS devices there’s nothing you can do. In a browser that supports addons one can use that.
Diversion cannot block YT video ads.
