Diversion Diversion - the Router Ad-Blocker v4.2.x (see new thread for 4.3.x)
I think you are referring to this.
Which I have checked and this works to either regenerate or purge.
however after running both when I check the it in the router it never updates it.
Previously when I ran that script it would update it here.
I've also tried going to manage to upload the ca.crt and ca.key file but I find it still doesn't change this kinda weird unless i'm doing something wrong.
What advantages does this offer instead of using let’s encrypt?
For those that use pixelserv-tls it is a certificate that's already on the router. No third party involvement necessary.
No, run the ps option in amtm to re-issue the WebUI certificate.
thanks i'm updated now.
Is the ps command an hidden option as I don't see it listed
Sorry I thought it was there, on that screen though you can just type in ps and It will start running it.
That's what I did to update it just thought it would be listed in the menu maybe we can have it added :)
Is pixelserv-tls installed?
Enter which pixelserv-tls into the terminal.
ps would be an available option in i if /opt/bin/pixelserv-tls is found.
