Centrifuge
I know the recommended method to update entware packages is through the Diversion "ep" option, but would it cause any problems just to
opkg upgrade
opkg upgrade
Do you have cookies disabled for the site? That will do it.Can someone please help me get rid of this message? (see attached).
I haven't touched anything in Diversion other then update it to the latest version and whitelisting one additional domain. As far as I can see, everything that should be whitelisted for snbforums.com is still whitelisted.
Thanks in advance - it's driving me craaaaaazy![]()
Has anyone come up with a solution to the dslreports page issue (failing to show results). I have followed the usual steps and see nothing being blocked. Anyone else look at this yet...I'm stumped.![]()
I brought this up a day or so ago and was told to add that site to the "whitelist" but unfortunately it did not solve the problem.
Thanks, I will stop trying to come up with resolutions myself....LOLYes, sorry, that was probably me.
I have since seen it myself on multiple systems, with and without Asus + RMerlin routers and/or Diversion installed.
Should pixelserv-tls have an update, it will not start because the startscript gets reset to default. Diversion takes care of that when you update through it.I know the recommended method to update entware packages is through the Diversion "ep" option, but would it cause any problems just toCode:opkg upgrade
OMG that was it. THANK YOU!Do you have cookies disabled for the site? That will do it.![]()
Is Amazon finally fixed in diversion 4.0.8 since the last time I used it, amazon was practically unusable as all the images/html/css was blocked by diversion and apparently the Amazon app couldn't even connect
No version change of Diversion changes the fact that the hosts files you use in your blocking file are determing what gets blocked. You'd have to whitelist the domain(s) that are blocked when using the Amazon app. Search this thread, this has been asked and answered many times.Is Amazon finally fixed in diversion 4.0.8 since the last time I used it, amazon was practically unusable as all the images/html/css was blocked by diversion and apparently the Amazon app couldn't even connect
Possible candidate for the FAQ page?No version change of Diversion changes the fact that the hosts files you use in your blocking file are determing what gets blocked. You'd have to whitelist the domain(s) that are blocked when using the Amazon app. Search this thread, this has been asked and answered many times.
For anyone using amazon seller services, whitelist for getting the app to work is:
fls-na.amazon.com
FYI, I am using the "medium" block files in diversion.
bHow do you change block files in Diversion. Recently installed and still trying to figure it out.
That's a feature, not a bug. Since about three or four versions back.In 4.08, in the listing you get under jffs scripts, the second line ran on without a new line feed, instead of a numbered list like the other categories.
Welcome To SNBForums
