M
M@rco
Guest
What other things can I istall with entware now installed? And what is Skynet?
Oh, tons of things. Too much to discuss here, as I already went off-topic at least once this week
Thanks again ... cool ... new things to learn and install. I love it lolOh, tons of things. Too much to discuss here, as I already went off-topic at least once this week. Google for 'entware-ng repository' to see what packages are available on Github. As for Skynet, that's another must-have (if you'd ask me). More info in this thread: https://www.snbforums.com/threads/s...mic-malware-country-manual-ip-blocking.16798/
1. Add domain
2. Delete domain
3. Process whitelist
4. Sort and verify whitelist
5. Restore whitelist from backup
6. Set domain active/inactive (#! )
Select what to do [1-6 e=Exit] 1
____________________________________________________
Add domain like so: example.com or www.example.com
An explanatory comment can be added after this step
Enter domain [e=Exit] www.reddit.com
no exact match found in blocking file for
www.reddit.com
no need to add it to the whitelist
no near matches found either
! match(es) will be removed from file(s)
when added to whitelist.
Add it to whitelist? [1=Yes 2=No] 2 <<==== No, thank you, I don't want you to.
www.reddit.com
was not found in the blocking file or blacklist
If you add it anyway, it may have no effect unless
you select a larger blocking file.
The domain will be marked #(forced-entry) and is
not re-added to the blocking file if you remove it.
Add it to whitelist anyway? [1=Yes 2=No] 2 <<==== No, I'm absolutely sure, I don't want you to. Thank you.
how can I properly reinstall pixelserv-tls?
Tackled in a different way, it is brought up by the S80pixelser-tls itself.I remember in AB-solution there was a delay built in to make sure the pixelserv ip was up and running before starting pixelserv itself. is that functionality still there in Diversion or have you tackled it in a different way?
Are you absolutely sure, because if you are I might look into it. Confirm here.It's a like a frickin' Micro$oft product asking me to confirm twice whether I'm really sure I don't want to do something![]()
I believe the user in question uses a firmware version and a router that is not supported on this board.It's me again...seems like you bump into me easily regardless where you ask. lol. Let me try again in this way..
I don't think reinstalling pixelserv-tls will solve the suspected crash problem because from the perspective of configuration on disk, pixelserv-tls is very simple. Reinstall of itself is unlikely to help. You shall try the log LEVEL 5 I told you earlier. That gives people a chance to get to the bottom of the issue and/or help me to improve the stability and robustness of pixelserv-tls (that btw is very good already IMO).
If you like a shortcut that seems to help quite a few people from my observation, the real question to ask is "how to reinstall everything". And the steps according to users here are roughly: 1) format the USB stick 2) install Diversion 3) install pixelserv-tls.![]()
Now all you need to do is link your Microsoft account to Diversion and provide valid payment details for the new low-cost subscription model!Yes, I'm absolutely sureConsider it confirmed
Please... don't give him any ideasNow all you need to do is link your Microsoft account to Diversion and provide valid payment details for the new low-cost subscription model!
@Thank you Kvic. I will keep a close eye on the logs and post the results when I come upon them. @thelonelycoder that was in response to my question of why pixelserv-tls is crashing. I'm using Asuswrt AC66U B1 with AC68U Merlin firmware, the latest alpha 3, will be bumping up to beta 1 soon.I believe the user in question uses a firmware version and a router that is not supported on this board.
Now that I switched from Standard to Medium the German Amazon site (amazon.de) is blocked.
How can I found which source list is responsible for this?
... in its state right now, is full of false-positives and merely updated months ago. Monthly updates is good (same case with MVPs Hosts file) but if it takes more than that, no.
I remember seeing the code in the AB3 S80pixelserv file but i don't see it in the diversion S80 file... thats why i asked... just curiosity, and wondering if the had something to so with the issue ppl are having with pixelserv not starting.Tackled in a different way, it is brought up by the S80pixelser-tls itself.
Welcome To SNBForums
