Diversion Diversion - the Router Ad-Blocker
You have an IPv4 and IPv6 entry for each blocked domain on that router, hence double the amount. It's slightly misleading in terms of "domains" blocked, but it's correct for your setup.
It's indeed misleading, they are the same domains for IPv4 and IPv6. I probably should prevent the double count.
now it makes sence, but before I just reinstalled jffs partition, I had some other faults and I thought the problem is caused by something else
second thing I've noticed is
amtm command is listed when I press tab on router no 1 and it isn't on router no 2 but both launch script while typing full command
both run on 384.14_2 rt-ac86u
What's the output of this command for both routers:
which amtm
whole file is double sized
toor@bajus:/tmp/home/root# ls -alh /opt/share/diversion/list/blockinglist
-rw-rw-rw-    1 toor     root       32.9M Jan 28 15:08 /opt/share/diversion/list/blockinglist
toor@jadzia:/tmp/home/root# ls -alh /opt/share/diversion/list/blockinglist
-rw-rw-rw-    1 toor     root       65.0M Jan 28 19:49 /opt/share/diversion/list/blockinglist
on first normal path
/opt/bin/amtm
on second nothing
Entware must be installed, or else Diversion would not be there.
Post the output of
find / -name *amtm*
Post the output of
find / -name *amtm*
entware is installed on both, anyway it is being installed during diversion installation
toor@bajus:/tmp/home/root# find / -name *amtm*
/tmp/mnt/uda0/entware/bin/amtm
/jffs/scripts/amtm
/jffs/addons/amtm
/jffs/addons/amtm/.amtm_theme
toor@jadzia:/tmp/home/root# find / -name *amtm*
/tmp/home/root/amtm
/jffs/scripts/amtm
/jffs/addons/amtm
That's strange, post output of for both
which opkg
And now
ls /opt/bin/
toor@jadzia:/tmp/home/root# ls /opt/bin/
YazFi          diversion      islebe         localedef.new  pixelserv-tls  x3mRouting
ash            find           jq             netstat        sh             xargs
column         grep           locale.new     opkg           uiDivStats
toor@bajus:/tmp/home/root# ls /opt/bin
YazFi             connmon           firewall          jq                netstat           persist-tool      spdmerlin         x3mRouting
amtm              diversion         grep              locale.new        ntpmerlin         pixelserv-tls     uiDivStats        xargs
ash               dqtool            htop              localedef.new     opkg              scribe            uiScribe
column            find              islebe            loggen            pdbtool           sh                update-patterndb
Remove amtm with r on the router that does not have amtm in /opt. Then reinstall. It will not remove any third party scripts when doing that.
I feel your pain. I’d rather avoid Telegram entirely as well, but they just make it so easy to use, like the WhatsApp.
I'll consider Telegram the day they don't require my personal phone number.
I've pushed a Diversion update, no version change
- amtm compatibility.
- Moves the shared whitelist to /jffs/addons/shared-whitelists for Skynet compatibility.
Note, you also must update Skynet if installed to the latest version if not already done.
Restart Skynet after the update(s) for it to pick up the moved shared whitelist.
Use u to update Diversion.
For some reason pixelserv-tls can't find the generated domain certificates for blocked domains.
From Diversion menu choose 'ep' , 3 'manage pixelsrv-tls certificates', 1 'Purge pixelserv-tls domain certificates' & 1 to purge. See if that stops the messages
Thanks mate, I upgraded pixelserv and then did the purge. All seems good now
router crashed, rebooted with default settings... ought it be there any usefull logs on usb stick?
Not on the usb device but maybe in /jffs/syslog.log or /jffs/syslog.log-1
