Skeptical.me
Grudgingly, market pressure can be a convincing mind changer. Just as a hammer is![]()
Are there any disadvantages of adding a list in this format?
I'm not asking anymore for log files. You seem unwilling to provide anything that helps me track this down.On my router they do... (at least 4 times so far)
Might be caused by having NextDNS installed, as some other user here suggested?
No, not that I'm aware of any.Are there any disadvantages of adding a list in this format?
Why do you use NextDNS on your router when we have a perfect solution called Diversion? It does a much better job at eliminating online ads and now with support for pihole lists it's an even better tool protecting your router from giving access to malicious sites.On my router they do... (at least 4 times so far)
I’m sorry you feel that way, because I want to help, but since logs get cleared during the reboot I have no (useful) logs to show.I'm not asking anymore for log files. You seem unwilling to provide anything that helps me track this down.
Diversion is great, but it only runs on my home network.Why do you use NextDNS on your router when we have a perfect solution called Diversion?
Is this what you’re after?What's the procedure for backing up the Diversion USB Drive? I've lost it twice before I think I better (finally) back this one up?
Assuming you have amtm and diversion this is all contolled with post-mount. And services-stop/unmount. Keep in mind those are designed different in some aspects vs the old way it was done, @thelonelycoder improved all of this for user simplicity straight down to the timing. If you mess with the wrong stuff you may break it to the point of needing to factory reset or wipe your memory/jffsIn the mean time, where can I read more about how Entware gets mounted/started during boot, so can I do some more investigation from my side?
Another poster thought the same.Nextdns is what is breaking you.
The Syslog is stored in four files, the /tmp is the most current but after a reboot you'll find the last entries before reboot in /jffs.Another poster thought the same.
That’s why I will uninstall NextDNS before the next reboot (the 384.15 Beta 1 update) tonight and see what happens.
Do you know what exactly breaks it and how we could fix this?
Looks pristine. Wait with a reboot until I had the chance to test a theory in half an hour.Currently NextDNS is installed.
Code:admin@ac86u:/tmp/home/root# cat /jffs/scripts/post-mount #!/bin/sh swapon /tmp/mnt/usb/myswap.swp # Skynet Firewall Addition . /jffs/scripts/post-mount.div # Added by Diversion
That would be OK, I think?
OK, I have to contain my anger I feel at the moment, let me haveCurrently NextDNS is installed.
Welcome To SNBForums
