Diversion Diversion - the Router Ad-Blocker
Well, I've pushed another minor update for Diversion, still no version change
- Fix for the last entry in the blocking list not having a space at the end.
- Re-added omitted dot (.) escape line for the temporary whitelist, thanks @Dabombber for making me double check.
- Removes eventual orphaned blocking IP line from the blocking list, thanks @Dabombber for the observation
I hope this is it with the domain count and whitelist saga.
Note: Before doing any whitelisting with el before the blocking list update day, update the blocking list manually with bu.
The format has slightly changed for the desired count accuracy.
Use u to update.
It works as-is. Bare host lists were supported by Diversion somewhat recently.
Cool :cool:
 downloading Custom blocking list, 2 file(s)
 using 192.168.50.2 as blocking IP, adding "::" as IPv6 blocking IP
 processing file 1 of 2
 no local file: getting new file
 https://blocklist.cyberthreatcoalition.org/vetted/domain.txt
######################################################################################################################################################################################################################################################### 100.0%
 file is in domains only format
 processing file 1 done
 processing file 2 of 2
 remote file newer: getting new file
 https://raw.githubusercontent.com/StevenBlack/hosts/master/alternates/gambling-porn/hosts
 file is in hosts file format (IP-domain pair)
 processing file 2 done
 removing whitelisted domains in blocking list, sorting file
 writing Custom blocking list
 adding IPv6 blocking entries
 update Custom blocking list complete
Okay, not sure if I never noticed this before or it's something new or __________. I searched (thread & Diversion FAQ) but didn't see anything. Pixelserv IP (192.168.x.3) not accessible by guest machines? Can't ping it, much less download the new ca.crt.
Try to restart it in ep, 4.
Is your Guest Network set to disable Intranet access? The Pixelserv IP would be considered intranet.
Hm. Yes. So that's interesting. I wouldn't want Guest machines to have access to other network resources, but Pixelserv would be useful. And a network printer... :eek: Otherwise what's the point of even having a Guest Network?
Good find.
Folks: Looks like my quick and sloppy adaption is working. No YT ads.
Give me some time to make a beta version, all fully automated of course.
Guess I have switched out the ax11000 for the ax88u. Appreciate getting it integrated with diversion.
Sent from my Pixel 2 XL using Tapatalk
In looking at my logs, I'm getting a number of these kinds of entries:
May 7 13:37:45 RT-AC86U-1BD0 pixelserv-tls[2868]: create_child_sslctx: cannot find or use /opt/var/cache/pixelserv/_.amazon.com
May 7 13:37:45 RT-AC86U-1BD0 pixelserv-tls[2868]: tls_clienthello_cb: fail to create sslctx or cache _.amazon.com
May 7 13:39:44 RT-AC86U-1BD0 pixelserv-tls[2868]: create_child_sslctx: cannot find or use /opt/var/cache/pixelserv/_.samsungcloudsolution.net
May 7 13:39:44 RT-AC86U-1BD0 pixelserv-tls[2868]: tls_clienthello_cb: fail to create sslctx or cache _.samsungcloudsolution.net
Is this an issue with Diversion?
You may have a few or many corrupt certificates. You can either purge all the certificates from within Diversion ep, or check them individually with this command:
openssl x509 -text -noout -in /opt/var/cache/pixelserv/_.amazon.com
If this prints the cert contents, it's OK. If not delete it with the rm command.
If it's a ton of them, just purge them all within Diversion.
This is awesome! Google often do turn April showers golden, as any Android user who has battled triggering Safety Net can attest. Hopefully they are content enough with their ad delivery success rate that fighting fixes isn't worth their effort.
Hi everyone,
Question from a total non-techie (well, almost total): is there anything that either Diversion or SkyNet would be doing that would block my Desktop PC from connecting to my Echo Studio when listening via Spotify? All of a sudden I can't play Spotify through my Echo. I can play SiriusXM no problem. I'm guessing it's a temporary outage somewhere else, because I've been using Diversion and SkyNet for some time without any issues (see my signature below). Still, just checking...
Thanks,
Anton
Its May the 8th.
Spotify is working just fine for me on iPad streaming to HomePod.
Here is a list of domains needed for whitelisting for spotify as well
mobile-ap.spotify.com
apresolve.spotify.com
upgrade.scdn.com
market.spotify.com
spclient.wg.spotify.com
audio-ake.spotify.com.edgesuite.net
Thanks for the list incase I need it in the future.
At the moment, Spotify is working with out issues on iPad while streaming to HomePod.
