Diversion Diversion - the Router Ad-Blocker
With regards to the YouTube experimental blocking, is there a way I can assist this more?
I guess I should be not using any ad-block on browsers? To be fair the only reason now to use a block on a browser is to remove the mass of white space you get from having no ads on a page after Diversion has blocked it.
Starting yesterday, I can't use Diversion any longer. My RT-AC87U router suddently stopped working, neither LAN nor WiFi worked and I couldn't connect to the WebUI nor SSH to the router.
I managed to get it working again by starting it without the USB drive and started turning features off one by one until I could identify it was Diversion being the culprit.
As soon as I turn Diversion on, dnsmasq locks up using ~50% CPU according to htop. Uninstalling and doing a clean reinstall of Diversion doesn't solve the issue.
Any idea what could be causing this and how I can get Diversion working again?
Try a different USB drive, or at least re-format and re-initialize this one. I'd guess the drive is failing if it's a sudden change.
Did that. No change. :(
Edit: Right now the Entware repo is down so I can't try out Diversion Standard which was what I used previously. Though I do get the exact same error with Diversion Lite.
Does diversion do something to dnsmasq.conf that would explain why the dnsmasq process hangs? I tried both enabling and disabling the custom dnsmasq.conf in Diversion, no luck.
Do you have uiDivStats installed?
When logging is enabled, it needs to write to the USB device. Apart feom that, Diversion adds some stuff for it to work.
I can't find a specific post now, but I remember reading that pixelserve was on the way out, or had one kind or another of technical issue(s). Is it still recommended as ok to use Diversion in Standard mode? I've been using it in Lite with uiDivStats now with great success for some time.
Thanks,
Anton
Thanks,
Anton
From my many, many hours of reading threads on this site my understanding is as follows. I'm sure the experts will chime in and correct my mistakes.
Years ago Diversion in it's formal life as AB-Solution was created to block ads. At some point the ad servers started using https to serve the ads. When a site with https ads was encountered there would be delays for some reason that I don't know the details of. Pixelsrv was created to answer those request thus eliminating the delay. As a bonus, pixelsrv would return a 1 pixel "ad" which would make the site prettier with the absence of a grey box where the ad was. Fast forward to now, I think I read that the delay is no longer present when not using pixelsrv. And with the new rules for certs and it has become more laborious to get all of your devices "compatible" with pixelsrv. So, to make life easy some people are just forgoing pixelsrv and dealing with the grey boxes.
Thanks,
Anton
There is no technical issue with pixelserv-tls usage in Diversion or any other way one uses that software.
Are there any leftovers left somewhere in any .conf file when uninstalling Diversion? It's a mystery to me why everything works, but as soon as I install Diversion or Diversion Lite, I can't even start the router.
In the Diversion new WebUI under the LAN section I have fount "Test ONE" and "Test TWO".
What is the meaning of these tests ?
By the way I love this interface :)
Not that I'm aware of. If one uninstalls through the d menu then all traces are gone.
Mind posting the content of these files, if present:
- /jffs/configs/dnsmasq.conf.add
- /jffs/scripts/dnsmasq.postconf
- /jffs/scripts/post-mount
This is with Diversion now being completely uninstalled using the d menu option.
/jffs/configs/dnsmasq.conf.add said:
dns-forward-max=1000
server=/pool.ntp.org/1.1.1.1
dhcp-option=lan,42,192.168.1.1 # ntpMerlin
/jffs/scripts/dnsmasq.postconf said:
more: /jffs/scripts/dnsmasq.postconf: No such file or directory
/jffs/scripts/post-mount said:
#!/bin/sh
swapon /tmp/mnt/USB256/myswap.swp # Swap file created by amtm
mount -a
service restart_httpd
. /jffs/addons/diversion/mount-entware.div # Added by Diversion
I see no reason why Diversion would not run with your entries.
But do you know why you added these lines? What are the benefits/what for?
- dns-forward-max=1000
- mount -a
- service restart_httpd
Also it could be that your local NTP server comes up late, preventing other things to run on time.
Of interest would be Syslog entries when Diversion fails to start, I'm sure it would tell a clear story of why it happens.
Also, the mount -a and restart httpd will run multiple times if you have more than one USB device and/or multiple partitions on it/them.
