Diversion Diversion - the Router Ad-Blocker
Temporarily whitelist it and try again.
Okay, I've done that, but this took my surprise. If this domain isn't in the blocking list then how is it being blocked?
star.c10r.facebook.com
 was not found in blocking list(s)
This is with Diversion switched off this evening
cccdeb070e668b72f3a312fc620dc5c1.plist
That's exactly like mine
Sent from my iPhone using Tapatalk Pro
Forgive my ignorance lads; I've FINALLY got Diversion and a whole bunch of other scripts working on my device just how I want it but stupidly I've put it on an older USB drive. I've got a brand new one here ready to go, is there any way for me to back up or clone the drive I'm currently using to make it a seamless transfer to my new drive? I'd rather not go through the whole process of setting it up again
When it came time for me to upgrade my USB stick, I started afresh with the new USB drive and installed my scripts from the ground up. There's likely a way to clone one via some Unix-based or other tool, but I'm not a techie and am running a Windows 10 PC so there was no obvious path for me. On the other hand, it was 1/2-hour or so of pleasurable script re-installation, so I have no regrets. With the new USB stick, everything's running perfectly with no lag, sluggishness, or abnormal CPU load.
I've found a cloning tool so I'll give that a go and see how it works. Worst case, reinstall haha
Change "wc" to "wildcard" and add some flashing disco lights, then it might get the necessary attention. [emoji1787][emoji1787]
There is a blink command for the shell. But I was never the flashy type, just orderly...
Forgive me for asking so many questions today.
One last issue I've noticed is that I after updating UiDivStats and trying to enable
1.    Update Diversion Statistics (daily only)
I receive the following:
Choose an option:    1
uiDivStats: Diversion logging not enabled!
uiDivStats: Open Diversion and use option l to enable logging
Press enter to continue...
But as you can see it is enabled and working:
Choose an option:    1
When you follow the logfile, does it show the log?
If not toggle logging off/on.
I had a lot of issues with Diversion becoming slow and failing to load every couple of days. A re-plugging of the USB2 2gb drive often solved the problem, although sometimes the drive had to be reformatted. At other times I had to reinstall Diversion. Other scripts, including SkyNet were not affected.
I replaced the USB flash drive, with a USB2 8gb, and the issues now seem to have been "permanently' resolved.
This actually happened to me a few weeks back and I had to re-install Diversion. I've done as you say, and although on the Diversion menu it shows logging is enabled when I try to follow the log I receive this error
 Error  logging is disabled, enable it first.
As you can see in this thread, earlier today I was able to see the log (and copied and pasted into a comment).
Maybe to save the others here the hassle I ought to just re-install again?
