dave14305
Part of the Furniture
Working from home too much can do that to people.I’m an idiot. I confused it with work at home.
thanks for showing me my error
Consider that $20 bill pocketed... I confess in your early alpha phase of flexqos I wandered across to the easy eats "cake" table and had my fill on the "light" side
Now fully content to be back on the "heavy" side with infinitely tweak-able FlexQos giving me Triple A+ ratings and solid speeds from my 100/50 Fibre.
Best of all, unlike Cake, I am back to full HW Acceleration - for both Runner and Flow Cache. {Double Thumbs Up}.
Great job so far @dave14305.
You can always disable it manually at LAN - Switch Control.
130053 is “iasd”, which I’ve never heard of. How often does this show up in the list of connections?
Oh, sorry for my false answer, at my 68U the option is there. No idea why the 86U doesn't have it. But may I ask, why do you even want to disable it?
I am experiencing drops when using wifi calling if I walk from my house to my music room outside while on a call if I run any of the Asus QoS solutions. ( Asus Qos, FreshJR or Flexqos. Cell coverage is real bad at my location. If I uninstall any of those “built in” solutions and install cake, which disables HW Acceleration, my wifi calls do not drop. I have 2 RT-AC68U in an AiMesh system connected wirelessly. The node 86U is in my music room.
I need some help! I live at a place where maximum Upload speed is 1Mbps (practical around 800Kbps).
Problem starts when iPhones try to backup photos to the icloud. They take over all upload bandwidth leaving no space for other devices to properly communicate with the Internet. What kind of configuration would you suggest to solve this issue?
I always have this in mind, the backup happens when you typically charge your device and we don't always charge at night.Since your upload is so low.
Do the cloud backup in the middle of the night when everyone is asleep.
I don't think you will have many options here.
I had the same connection for 8 month here last year after I moved (10mbit/s down 0.9mbit/s up on a good day). I used FreshJR at that time and could not get it to work well with the low upload. I had used it before on a 100/35 connection with no problems and am now using FlexQoS on a 115/18 connection with no problem. There probably is a limit of what any QoS can do - especially on very slow asymmetrical upload...I always have this in mind, the backup happens when you typically charge your device and we don't always charge at night.
Looks cool actually but will it really make sense?
Cos if the higher priority categories are not being used, then file transferring can take all of it up, and go past its ceiling (>100%), right? (Not 100% on the terminology).
Does it need to be more like the resource meter bar?
Edit: Idea! Maybe draw a 100% vertical line in as well, and it can go past it, then we can see that its gone over and beyond!
This is a mock-up of new meters that will show how much of the allocated bandwidth per class is in use. It will be the rate as shown in the Rate column as a percentage of the ceiling (the max download or upload bandwidth). I'd love any developer hints on how to mark the rate value (i.e. minimum bandwidth per class) with a vertical line perhaps to show when each class is exceeding its guaranteed bandwidth.
Each meter is 100px wide. I'd really like to draw a vertical bar at the pixel that represents the minimum bandwidth. So for Work-From-Home, I have 20% minimum bandwidth, so at pixel 20 I want to draw a white vertical bar that is visible as the bar may go above or beyond that 20% value. Not sure how to do it yet since I just stole this code from Merlin. The commit is in the develop branch for anyone with ideas.
Welcome To SNBForums
