That's the one...Did you mean NAT acceleration? Turned it of and seems to have fixed it.
Turning it off definetly fixed itThat's the one...
CTF acceleration == HW acceleration == NAT acceleration (terms are used interchangeably)
Thanks for verifying it....working on a fix now.Turning it off definetly fixed it![]()
Hot off the presses! Alpha updated to V29A8 which includes the KRACK fix for the AC68 series.
Driver version wl0: Nov 29 2017 14:54:27 version 6.37.14.126 (r561982)
If anyone is using the AC68 as a Repeater/Media Bridge, would appreciate it if they could give this code a try.
It also includes backported fixes for 3 Samba CVEs (thanks Merlin)
That leaves only the AC56U...Asus activity on that has been rather quiet, so we'll need to wait and see. A reminder that the N16 will not receive the KRACK fix.
ALPHA RELEASE: Update-29A8 for the AC66U, N66U and AC68U
2-December-2017
Merlin fork 374.43_29A8j9527
Download https://1drv.ms/f/s!Ainhp1nBLzMJlW1TnFp4Sh2wvQva
SHA256
Code:(Default Build - All supported routers - Alpha for 'E' Builds) 3986b8e3413abd2c4b4f5dab6a1db8524832b17701ed7153fc15594775dfe39b RT-N16_374.43_29A8j9527.trx 15510bf5db56c2c29082cc7d94ab195d0b18756f43ce640ea629cd84534456ac RT-AC66U_374.43_29A8j9527.trx ed11d7e6455c55259ca53c1aced11f7c80de5c107543529e45e534415455a8b4 RT-N66U_374.43_29A8j9527.trx af1733d33fd0a22321fb70ff05515e574c25bc7e58d23df15051e1fcbe87d8db RT-AC68U_374.43_29A8j9527.trx 3f0c2f34a68df53b167fa162d6cdc2f7d8ad6a14cf398b1cf110299cab404776 RT-AC56U_374.43_29A8j9527.trx
Thanks for the offer to help out. I'd just like someone with a stable setup to verify it keeps working, so nothing special to test.@john9527
I currently have a AC68U configured in Media Bridge mode Using ASUS's 382_18881 and am willing to give your alpha build a try, however I noticed later in the thread you are working on a CTF fix. Should I wait for the next update?
And, is there something specific you would like tested from the Media Bridge mode?
Likely the same bug with CTF....watch for the next update.but when I tried it on my AC68U it has some quirky issues, not all sure what it was but the whole fam had issues with webpages loading, page stalling, loaded back 28E2 for now make them all happy.
It's already supported in the gui....Thanks very much for continuing to support our Asus routers with your outstanding releases. I was just wondering if you could update OpenVpn to allow AES-256-GCM ciphers on the Gui. It ( Aes-256-GCM ) is supported on OpenVpn 2.4 and beyond.
Transparent to the user when running in Repeater or Media Bridge modes.....nothing you need to do.By the way, is there any thing that we need to do in order to enable Krack protection or is it working out of the box?
The Cipher Negotiation and Negotiable ciphers fields are for OpenVPN 2.4.....it is there you specify the GCM ciphers (You need to type them in....there currently isn't a construct for selecting multiple pulldown items). If you are connecting to a VPN server 2.3 or earlier, it will then fall back to use the Legacy cipher (or not connect if you set Cipher Negotiation to just Enable)
Thanks for the kind words......appreciated.
Depending on when you last did it, there was a change to move the save location on jffs to be compatible with Merlin builds. The code should handle it, but just to double check....I'm assuming a recent change has made them no longer work for me.
rm -rf /jffs/ssl
rm -rf /jffs/https
1c49d6da5628d4add6258fe1cdabdd445d8d1afed702a50669b081d15d9a3878 RT-AC56U_374.43_29A9j9527.trx
e83a10f8817cdc781e664564b6a846fc02921b945f267870012a23204affd9cd RT-AC66U_374.43_29A9j9527.trx
bf16a48fe2863afed424a926fbc695ff204e5589fc0a5e9a6d169eff505d61dd RT-AC68U_374.43_29A9j9527.trx
6911683f75995dea62f26632df522f49aa46b40c4afffeb4af1cd5c64a77263b RT-N16_374.43_29A9j9527.trx
d208d460454105c78be9194f73bdaebebc6fe2e2dd945aa89dd2406f176c63b7 RT-N66U_374.43_29A9j9527.trx
John's link is wrong. It takes you to the previous alpha. If you follow that link, click TestBuilds at the top, then click on Update-29A9 and proceed from there.Same symptoms as the previous alpha with NAT accel enabled.
Flashed, turned off the router. Rebooted modem, started modem and let boot, boot router, enable nat, forget wifi, and exactly the same as before
Welcome To SNBForums
