One thing to check when having issues with Google is the DNS configuration. For instance, Google likes to hardcode their own DNS into mobile apps. Make sure you're not doing anything to interfere with that.
What should a user do to not interfere ? I presume that hard-coded DNS in apps overrides router DNS no matter what, whether we use ISP provided DNS or our own settings ?
Using DNSFilter for those specific devices can potentially cause issues... in theory at least. All I know for sure is that Google likes to hardcode 8.8.8.8 in some of their mobile apps. I'm not 100% sure of the impact of this.
Tunnel providers with an enforced DNS server might also cause issues, if they prevent you from reaching 8.8.8.8 for instance.
Changed DNS to Connect to DNS Server automatically.
Turned off router for a few min after a reboot.
Google still hosed. Noting in any logs.
Can you check your WAN ip address and see if it's the same when you connect as you change levels? Maybe the change in code is causing you to connect to a different head end at your ISP, and that is what is having problems.
Wan IP is the same.
G Play works partially. Cached items load fast. I can click on an app, but that page only partially loads. It loads fast. But no graphics, and a lot of the page is missing. If I click install, just get a spinning circle.
A Hangouts message took 20 min to receive that was sent on the same LAN
Wan IP is the same.
Please post up a syslog after a reboot....
@Lotta Cox
Nothing of interest in the syslog other that the fact I don't see any devices requesting an IP address. Do you have DHCP logging turned off?
One thought.....the new wl driver is a pretty significant change. Can you try forgetting then reconnecting the connection on the troublesome devices.
@Lotta Cox
DHCP log is off.
I disconnected from wifi on one phone. Then re-connected. Is that the same?
I am on 28 now. Can't test until 9PM est.
Thanks, but I already found that link. My problem was I bought a used router from AMZ and it did not come with the CD/DVD. So, I could not find the Firmware Restoration program. So a kind person here told me look at some other router that did have the Firmware Restoration for me to D/L.
actually, how do I get the drive to the root?
Edit: NVM, I turned on guest sharing and clients can connect as before.
