ColinTaylor
Part of the Furniture
That's not what I said. I said do a factory reset after uploading the new firmware.I did do a reset and nvram reset before the actual firmware uplaod to in the recovery "mini web server" ...
In which case use this command:.. in fact it wouldn't make sense otherwise since the previous was actually "1 2 3 4 8*"
nvram set vlan1ports="1 2 3 4 8*"
I have no idea what "trick" you're talking about. You don't need any tricks to press the reset button on the router.... also the nvmram tirck does not work after reboot!
