[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
Hi everyone.
@AndreyPopov regarding the 5GHz issue; have you already tried to contact Shibby20 from the Tomato project? It seems that he managed to fix this problem a while back. (I don't know if I can post external links, but if you google "wl_high module finally compiled" the first result will take you to the page I mean
Hi everyone.
Module compiled. And loaded.
Problem in upping second wifi interface.
In code upping second wifi interface is
sprintf(insmod_arg, "instance_base=%d", maxunit + 1);
modprobe("wl_high", insmod_arg);
Instance_base - what value and what mod probe syntax?
Sorry, I don't have the technical knowledge to further help you :(
If you need another tester I can gladly do it.
I just noted that NFS page wont load
I am using the last modded version since it was published, but just now I noted that the asp page for NFS in my RT-N16.
¿Im I missing something?
Appart from that, I was wondering if you are going to release an m7d, because in the merlin thread for the .48 there have been updates and a post-release 376.48_1.
Thanks in advance
Thanks in advance
I check if NFS page inside firmware. please provide your content ls /www
no mod7d - may be mod8 ;)
I'm waiting until RMerlin merge last ASUS GPL 376.3602(376.3628)
Here it is:
ASUSWRT-Merlin RT-N16_3.0.0.4 Thu Nov  6 04:09:31 UTC 2014
admin@XXXXXXXX:/tmp/home/root# ls /www
APP_Installation.asp                  aidisk
Advanced_ACL_Content.asp              aidisk.asp
Advanced_APPList_Content.asp          ajax.js
Advanced_ASUSDDNS_Content.asp         ajax_coretmp.asp
Advanced_AiDisk_NFS.asp               ajax_ddnscode.asp
Advanced_AiDisk_ftp.asp               ajax_dms_status.asp
Advanced_AiDisk_samba.asp             ajax_openvpn_server.asp
Advanced_AiDisk_webdav.asp            ajax_qos_default.asp
Advanced_BasicFirewall_Content.asp    ajax_status.xml
Advanced_DHCP_Content.asp             ajax_wlc_state.asp
Advanced_Exposed_Content.asp          alttxt.js
Advanced_Firewall_Content.asp         api.asp
Advanced_Firewall_IPv6_Content.asp    aplist.asp
Advanced_FirmwareUpgrade_Content.asp  app_installation.css
Advanced_GWStaticRoute_Content.asp    apps_test.asp
Advanced_IPTV_Content.asp             apscan.asp
Advanced_IPv6_Content.asp             automac.asp
Advanced_KeywordFilter_Content.asp    calendar
Advanced_LAN_Content.asp              client1.ovpn
Advanced_Modem_Content.asp            client2.ovpn
Advanced_NATPassThrough_Content.asp   client_function.js
Advanced_OpenVPNClient_Content.asp    cloud_main.asp
Advanced_OperationMode_Content.asp    cloud_router_sync.asp
Advanced_PortTrigger_Content.asp      cloud_settings.asp
Advanced_QOSUserPrio_Content.asp      cloud_status.asp
Advanced_QOSUserRules_Content.asp     cloud_sync.asp
Advanced_SNMP_Content.asp             cloud_syslog.asp
Advanced_SettingBackup_Content.asp    cmdRet_check.htm
Advanced_SwitchCtrl_Content.asp       cpu_status.asp
Advanced_System_Content.asp           detect.js
Advanced_URLFilter_Content.asp        detectWAN.asp
Advanced_VPNAdvanced_Content.asp      detect_firmware.asp
Advanced_VPNClient_Content.asp        detect_timezone.js
Advanced_VPNStatus.asp                device-map
Advanced_VPN_Content.asp              disk_fsck.xml
Advanced_VirtualServer_Content.asp    disk_functions.js
Advanced_WANPort_Content.asp          disk_msg.js
Advanced_WAN_Content.asp              disk_scan.asp
Advanced_WAdvanced_Content.asp        diskmon_test.asp
Advanced_WMode_Content.asp            dropbox_callback.htm
Advanced_WSecurity_Content.asp        error_page.htm
Advanced_WWPS_Content.asp             ext
Advanced_Wireless_Content.asp         form.js
Advanced_Wireless_Survey.asp          form_style.css
BR.dict                               general.js
CN.dict                               get_webdavInfo.asp
CZ.dict                               getdhcpLeaseInfo.xml
DA.dict                               getfoldertree.asp
DDNS_info.asp                         getsharelink.asp
DE.dict                               getsl.asp
DNSFilter.asp                         gettree.asp
EN.dict                               gotoHomePage.htm
ES.dict                               help.js
FI.dict                               help_content.js
FR.dict                               httpd_check.htm
Guest_network.asp                     images
HU.dict                               index.asp
Home_Security.asp                     index_style.css
IT.dict                               iui
JP.dict                               jquery.js
Lang_Hdr                              jquery.xdomainajax.js
Lang_Hdr.txt                          manifest.appcache
Logout.asp                            manifest.asp
MS.dict                               md5.js
Main_AdmStatus_Content.asp            mediaserver.asp
Main_Analysis_Content.asp             menu_style.css
Main_ConnStatus_Content.asp           merlin.js
Main_DHCPStatus_Content.asp           multi_vts_rule.asp
Main_IPTStatus_Content.asp            offline.htm
Main_IPV6Status_Content.asp           other.css
Main_LogStatus_Content.asp            popup.js
Main_Netstat_Content.asp              proxy.pac
Main_RouteStatus_Content.asp          pwdmeter.css
Main_TrafficMonitor_daily.asp         qis
Main_TrafficMonitor_devdaily.asp      ram_status.asp
Main_TrafficMonitor_devmonthly.asp    remote.asp
Main_TrafficMonitor_devrealtime.asp   remote.js
Main_TrafficMonitor_last24.asp        require
Main_TrafficMonitor_monthly.asp       result_of_get_changed_status_QIS.asp
Main_TrafficMonitor_realtime.asp      setting_lan.htm
Main_WOL_Content.asp                  start_apply.htm
Main_WStatus_Content.asp              start_apply2.htm
NM_style.css                          start_autodet.asp
NO.dict                               state.js
Nologin.asp                           status.asp
PIE.htc                               svg.js
PL.dict                               svghtc
ParentalControl.asp                   switch_AiDisk_app.asp
ParentalControl.css                   switcherplugin
PrinterServer.asp                     tm.svg
QIS_wizard.htm                        tmcal.js
QIS_wizard_m.htm                      tmhist.js
QoS_EZQoS.asp                         tmmenu.css
RO.dict                               tmmenu.js
RU.dict                               update_IPv6state.asp
Restarting.asp                        update_applist.asp
SITE_info.asp                         update_appstate.asp
SV.dict                               update_clients.asp
TH.dict                               update_cloudstatus.asp
TR.dict                               update_diskinfo.asp
TW.dict                               ure_success.htm
Tools_OtherSettings.asp               ureip.asp
Tools_RunCmd.asp                      user
Tools_Sysinfo.asp                     userRpm
UK.dict                               usp_style.css
UpdateError.asp                       validation.js
Updating.asp                          wcdma_list.js
UploadError.asp                       wds_aplist_2g.asp
Uploading.asp                         wds_aplist_5g.asp
WAN_info.asp                          wds_aplist_5g_2.asp
WPS_info.asp                          wlconn_apply.htm
aicloud_qis.asp                       wpad.dat
if you use RT-N16-xxxx-m7c-webkit than really this bug exist.
but if you use usb flash you can put Advanced_AiDisk_NFS.asp to /opt/ext/www
Where to get that .asp
I do have a hard drive connected to USB and entware installed, that is the reason I im trying to use NFS.
If I understand well, it means that if I not use de webkit version (and pick the other one) the NFS asp page will be there.
If not. Where I can get the NFS file that correspond with your version of RT-N16 firmware, so I can copy it to /opt/ext/www?
Thanks in advance
I put file in mod7c dir.
P.S. NFS page for RT-N16 must be inside firmware for all variants. error in firmware build script :(
But the file exist... only it is almost empty
I just to note that the file exist in /www, but it only have 33 bytes, and is marked in color red when looking the directory in midnight commander.
I will try the /opt/ext/www method anyway.
Thanks!
UPDATE:
That red 33 bytes file is, in fact, a link to /jffs/www/ where the real file is located :| and it wont work.
The other strange thing I just discovered is that jffs now contains a big number of files (some versions of the firmware ago, it was almost empty with scripts and config folder only)
- mod7b, 28.10.2014
- in JFFS during initial format prepare folder structure, create startup scripts files and symlinks for external web kit
- SSH if JFFS used store keys there
33 bytes - is symlink
red - if symlink point to wrong position
what file system on your usb drive?
It is ext3
admin@xxxxxxxx:/tmp/mnt/OPTWARE/entware# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /tmp/mnt/OPTWARE type ext3 (rw,nodev,noatime,data=ordered)
Its working!
:D Yes, I can access now to NFS page, and I have sucessfully mounted the export on the PC.
Thanks a lot!
Hi there @Andrey, any news on the 5GHz Radio for the n53 series?
I would like to help you out by donating some money. Do you have a Paypal account?
firmware compiled with wl_high (5G) module but it not want start.
I ask Shibby about this problem
http://www.linksysinfo.org/index.php?threads/wl_high-module-finally-compiled.48626/#post-253319
but not enough help to solve problem.
now merge Merlin's last changes and prepare to make mod8.
and than try again RT-N53 5g.
for donation please use PayPal account
[email protected]
THANKS!
Hi Andrey, any more progress with the 5ghz n53? I'm currently running your b version and the performance started to degrade...from ~10MBps to ~5 MBps on the 2.4. I want to flash something:P
