[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
ipkg: not found
admin@RT-N12D1-2200:/tmp/home/root# ipkg update
-sh: ipkg: not found
admin@RT-N12D1-2200:/tmp/home/root# cd /
admin@RT-N12D1-2200:/# find . -name ipkg
./jffs/tmp/ipkg
./jffs/usr/lib/ipkg
admin@RT-N12D1-2200:/# cd /jffs/tmp
admin@RT-N12D1-2200:/jffs/tmp# ls -l
drwxrwxrwx 2 admin root 0 Oct 19 2014 ipkg
./jffs/tmp/ipkg
./jffs/usr/lib/ipkg
/jffs not in path. link /jffs like /opt
wget: short write
http://dlcdnet.asus.com/pub/ASUS/LiveUpdate/Release/Wireless/asus_base_apps.tgz - is ~900KB
when untar ~ 1.8MB
not sure enough space in /jffs for these.[/QUOTE]
admin@RT-N12D1-2200:/jffs/tmp# wget [url]http://dlcdnet.asus.com/pub/ASUS/LiveUpdate/[/url]
Connecting to dlcdnet.asus.com (84.91.171.8:80)
[B]wget: short write[/B]
@RT-N12D1-2200:/jffs/bin# ls -l
drwxr-xr-x    2 admin    root             0 Jan  1  1970 bin
-rwxr-xr-x    1 admin    root        113103 Feb 17  2014 opkg
-rwxrwxrwx    1 admin    root             0 Jan  1 00:17 update-alternatives
admin@RT-N12D1-2200:/jffs/bin# opkg update
opkg: line 2: syntax error: unexpected word (expecting ")")
it´s opkg doing something/working here?
please post mount - if debugfs loaded
modprobe -r -v wl_high.ko
modprobe -v wl_high.ko --show-depends --dump-modversions
please post the exact command for "mount - if debugfs loaded" because i am a little noob in linux:P
here is the output of what i tried... it says --dump-modversions not recognized...without it works :
admin@RT-N53:/tmp/home/root# lsmod
Module Size Used by Tainted: P
wl_high 1051568 0
nf_nat_sip 3808 0
nf_conntrack_sip 7328 1 nf_nat_sip
nf_nat_h323 6240 0
nf_conntrack_h323 38272 1 nf_nat_h323
nf_nat_rtsp 4560 0
nf_conntrack_rtsp 5600 1 nf_nat_rtsp
nf_nat_ftp 2208 0
nf_conntrack_ftp 6816 1 nf_nat_ftp
ip6table_filter 1376 0
ip6table_mangle 1568 0
ohci_hcd 18192 0
jffs2 115136 1
zlib_deflate 19056 1 jffs2
lzo_decompress 2112 1 jffs2
lzo_compress 1984 1 jffs2
zlib_inflate 13120 1 jffs2
nf_nat_pptp 2176 0
nf_conntrack_pptp 4912 1 nf_nat_pptp
nf_nat_proto_gre 1648 1 nf_nat_pptp
nf_conntrack_proto_gre 3360 1 nf_conntrack_pptp
ehci_hcd 37504 0
usbcore 125824 4 wl_high,ohci_hcd,ehci_hcd
wl 2771024 0
igs 17648 2 wl_high,wl
emf 21152 3 wl_high,wl,igs
et 45632 0
ctf 21456 0
admin@RT-N53:/tmp/home/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
admin@RT-N53:/tmp/home/root# modprobe -v wl_high.ko --show-depends
insmod /lib/modules/2.6.22.19//lib/modules/2.6.22.19/kernel/drivers/usb/usbcore.ko
insmod /lib/modules/2.6.22.19//lib/modules/2.6.22.19/kernel/drivers/net/emf.ko
insmod /lib/modules/2.6.22.19//lib/modules/2.6.22.19/kernel/drivers/net/igs.ko
insmod /lib/modules/2.6.22.19//lib/modules/2.6.22.19/kernel/drivers/net/wl_high.ko
I also did tar -xvzf control.tar.gz
Can´t get GNU wget to run:
admin@RT-N12D1-2200:/jffs/opt/bin# ls -l
-rwxr-xr-x    1 admin    root        422544 Feb 18  2012 wget
admin@RT-N12D1-2200:/jffs/opt/bin# wget
BusyBox v1.20.2 (2014-08-02 15:54:00 EEST) multi-call binary.
Usage: wget [-c|--continue] [-s|--spider] [-q|--quiet] [-O|--output-document FILE]
        [--header 'header: value'] [-Y|--proxy on/off] [-P DIR]
        [--no-check-certificate] [-U|--user-agent AGENT] [-T SEC] URL...
Retrieve files via HTTP or FTP
        -s      Spider mode - only check file existence
        -c      Continue retrieval of aborted transfer
        -q      Quiet
        -P DIR  Save to DIR (default .)
        -T SEC  Network read timeout is SEC seconds
        -O FILE Save to FILE ('-' for stdout)
        -U STR  Use STR for User-Agent header
        -Y      Use proxy ('on' or 'off')
admin@RT-N12D1-2200:/jffs/opt/bin# alias wget=`/jffs/opt/bin/wget`
[B]-sh: /jffs/opt/bin/wget: not found[/B]
ASUSWRT-Merlin RT-N53_3.0.0.4 Sun Oct 19 17:45:51 UTC 2014
admin@RT-N53:/tmp/home/root# modprobe -r -v wl_high.ko
wl_high 1051568 0
nf_nat_sip 3808 0
nf_nat_h323 6240 0
nf_nat_rtsp 4560 0
nf_nat_ftp 2208 0
ohci_hcd 18192 0
jffs2 115136 1
nf_nat_pptp 2176 0
ehci_hcd 37504 0
wl 2771024 0
et 45632 0
ctf 21456 0
nothing happened...i still can't change the 5ghz control channel...it's still 0 or auto
Sorry, error in syntax - alias wget="......."
Need double quote
admin@RT-N12D1-2200:/# alias wget="/jffs/opt/bin/wget"
admin@RT-N12D1-2200:/# wget
-sh: [B]/jffs/opt/bin/wget: not found[/B]
admin@RT-N12D1-2200:/# ls -l /jffs/opt/bin/
I also did:
mkdir -p /jffs/etc
cp /rom/etc/profile /jffs/etc/profile
cd /jffs/etc
vi profile
[COLOR="SeaGreen"]#added PATH="/jffs/opt:/jffs/opt/bin:[/COLOR]
cd /jffs/scripts
vi services-start
[COLOR="SeaGreen"]#Added: #!/bin/sh
#	mount --bind /jffs/etc/profile /etc/profile
#	alias wget="/jffs/opt/bin/wget"[/COLOR]
chmod +x services-start
still no results:confused:
I made some preparation to increase from default 100(80)mw power to more.
are you try make Reset to Factory Default because some trouble may be in settings.
P.S по-русски можем общаться на форуме wl500g.info
Thanks, restoring to factory defaults helped me.
Changelog
What is the changelog for your mod 7a vs 7b. I have noted that there is already the b version for RT-N16, and I have the 7a installed.
- mod7b, 28.10.2014
- Based on Merlin 376.48 beta2 (ASUS 3.0.0.4.376_2769) source
- add DNSFilter for all models(for RT-N10U and RT-N15U by external web kit)
- in JFFS during initial format prepare folder structure, create startup scripts files and symlinks for external web kit
- SSH if JFFS used store keys there
(in plans same for OpenVPN)
- for models RT-N10P and all modifications RT-N12* add OpenVPN, SNMP
(need tesed)
CAUTION!!!!!!! according to limitation size of NVRAM NOT RECOMMENDED setup and use all firmware features at same time.
- for USB models - RT-N10U, RT-N15U extended features support by external web kit:
a) https
b) wimax (more modems have internal storage or microSD card-reader)
c) OpenVPN
d) SNMP
e) mediaserver (from asusware is buggy)
f) WebDAV
п) DNSFilter
h) CloudSync (not asusware)
i) cloudsync clients: dropbox client, samba client, ftp client
j) NFS server
- for USB model RT-N14UHP extended features support by external web kit:
a) WebDAV
b) CloudSync (не asusware)
c) cloudsync clients: dropbox client, samba client, ftp client
d) NFS сервер
(all others present in firmware)
- for RT-N16 add cloudsync clients: dropbox client, samba client, ftp client
- for USB models RT-N16 and RT-N14UHP for external disks used Texura drivers for NTFS, HFS+, FAT
- for USB models RT-N10U and RT-N15U used ntfs-3g
to install external web kit:
- connect external USB disk (recommended ext2/ext3)
- on Administration page enable acces by telnet and/or ssh
- enter to route console
- download file prepare_external_kit.sh (wget ftp://78.25.8.242/pub/ASUS/ASUSWRT_MODDED/mod7b/prepare_external_kit.sh)
- make it executable chmod +x prepare_external_kit.sh
- and run ./prepare_external_kit.sh
