[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
Edited topic title to better identify it and made it sticky.
Make an updated 374.35_4 sdk5 merlin build, please.
It be cool if there was both versions of the firmware fully updated.
Merlin, would it take a lot of time to fully update the sdk 5 firmware?
It would be awesome if you kept 1 version of sdk 5 and also sdk 6. I believe that would satisfy everyone.
It's a lot of work, which is why I stopped doing it. Every single additional FW increases my workload. I'm trying to cut down on it, not to increase it.
not working on n14uhp
i've tested the m4c on my n14uhp, and it is not working as expected, the router was able to connect to the internet, but not with the client, client are isolated on internal network and unable to connect to the internet.
thanks
thanks
wired or wireless clients?
wireless:
- are you made Restore to Factory Default after upgrade firmware?
- what security are you use WAP, WAP2 etc.
- what IP protocol clients use IPv4 or IPv6
problem source found, the problem occur when i use security on wireless. i hope you can fix it on the next update
this is what happen, when i use security on wireless
udp 192.168.1.197:41072 8.8.8.8:53 UNREPLIED
udp 192.168.1.115:57782 113.52.148.37:123 UNREPLIED
udp 192.168.1.7:60960 8.8.8.8:53 UNREPLIED
udp 192.168.1.65:1500 89.179.14.50:63145 UNREPLIED
udp 192.168.1.157:49272 119.252.169.31:123 UNREPLIED
udp 192.168.1.65:1500 93.42.106.92:1637 UNREPLIED
udp 192.168.1.65:1500 2.133.198.145:19756 UNREPLIED
udp 192.168.1.65:1500 174.54.143.94:44246 UNREPLIED
udp 192.168.1.65:52245 192.168.0.200:161 UNREPLIED
udp 192.168.1.65:1500 178.67.8.245:40356 UNREPLIED
udp 192.168.1.65:1500 178.221.178.208:22094 UNREPLIED
udp 192.168.1.65:1500 95.26.195.89:41719 UNREPLIED
udp 192.168.1.65:1500 178.206.13.166:49001 UNREPLIED
udp 192.168.1.16:40334 202.65.114.202:123 UNREPLIED
udp 192.168.1.16:59558 202.150.160.150:123 UNREPLIED
udp 192.168.1.65:1500 124.83.0.70:47183 UNREPLIED
udp 192.168.1.65:1500 124.83.0.70:6642 UNREPLIED
udp 192.168.1.65:1500 88.185.58.141:43705 UNREPLIED
udp 192.168.1.115:55609 202.43.117.10:123 UNREPLIED
udp 192.168.1.157:47934 180.211.88.5:123 UNREPLIED
udp 192.168.1.65:1500 46.63.188.90:21322 UNREPLIED
udp 192.168.1.65:1500 90.29.178.208:36037 UNREPLIED
udp 192.168.1.157:36479 202.65.114.202:123 UNREPLIED
udp 192.168.1.65:1500 78.16.80.216:51413 UNREPLIED
udp 192.168.1.65:1500 124.83.0.70:45874 UNREPLIED
udp 192.168.1.65:1500 46.39.239.171:51413 UNREPLIED
udp 192.168.1.115:39662 203.89.24.34:123 UNREPLIED
udp 192.168.1.65:52245 192.168.0.119:161 UNREPLIED
udp 192.168.1.65:1500 206.116.65.212:57442 UNREPLIED
udp 192.168.1.65:52245 192.168.0.130:161 UNREPLIED
udp 192.168.1.65:1500 122.118.63.195:13791 UNREPLIED
udp 192.168.1.16:36209 119.82.243.189:123 UNREPLIED
udp 192.168.1.65:1500 100.32.9.137:6890 UNREPLIED
udp 192.168.1.65:1500 86.124.181.149:62649 UNREPLIED
udp 192.168.1.65:1500 124.83.0.70:28267 UNREPLIED
udp 192.168.1.65:52245 192.168.0.161:161 UNREPLIED
udp 192.168.1.65:1500 110.22.143.94:34431 UNREPLIED
udp 192.168.1.65:1500 86.61.114.208:48592 UNREPLIED
udp 192.168.1.16:40447 180.211.88.50:123 UNREPLIED
udp 192.168.1.115:54060 114.141.48.158:123 UNREPLIED
udp 192.168.1.65:1500 82.229.205.52:6881 UNREPLIED
udp 192.168.1.65:1500 72.71.155.23:24714 UNREPLIED
udp 192.168.1.65:1500 2.133.198.145:20929 UNREPLIED
udp 192.168.1.65:1500 124.83.0.70:52626 UNREPLIED
udp 192.168.1.163:44664 206.53.159.128:3478 UNREPLIED
udp 192.168.1.65:1500 82.140.233.93:46540 UNREPLIED
udp 192.168.1.163:42580 206.53.159.128:3478 UNREPLIED
udp 192.168.1.157:35874 203.114.224.252:123 UNREPLIED
udp 192.168.1.65:1500 80.217.58.141:38174 UNREPLIED
udp 192.168.1.65:1500 200.74.115.66:1040 UNREPLIED
udp 192.168.1.65:1500 78.26.155.40:50742 UNREPLIED
UPDATE
even though security are set as wpa-auto-personal (and its working) but on inSSIDer it is recognise as wpa2-personal
here you are... tools -> sysinfo
attachment.php
thanks.
are info on screenshot and physical connections indetical?
problems with wifi may be in that binary blobs for rt-n14uhp from GPL 374.4422 and may be some incompatibles with 376 GPL.
please also post screenshot or paste info from Tools-> Sysinfo -> CPU
like this:
CPU Model Broadcom BCM5357 chip rev 2 pkg 10 (for my RT-N15U)
according to this info I try use another binary blobs for rt-n14uhp.
yes, informations are identical to physical connection
CPU
CPU Model Broadcom BCM5357 chip rev 2 pkg 8
CPU Frequency 530 MHz
CPU Load Average (1, 5, 15 mins) 0.02, 0.01, 0.00
here's the screenshot
attachment.php
