AndreyPopov
CPU Model Broadcom BCM5357 chip rev 2 pkg 8
CPU Frequency 530 MHz
CPU is same like in RT-N10U (300MHz)
I try compile RT-N14UHP firmware with RT-N10U binary blobs 374.5517
CPU
please try this firmware RT-N14UHP_3.0.0.4_376_2061-gdea2a5b-m5-rtn14uhp-rtn10u.trx in mod4c1 folder.
I've tried the latest update you've provide, problem still exist, even worse, all security type doesnt work as it should be
wpa2-personal and wpa-auto-personal unable to connect to internet
are mean this https://github.com/RMerl/asuswrt-merlin/tree/sdk5100 ???Can you make a SDK5 build
Hello, my ISP provided native IPV6 support by dual stack, however, my RT-N15U does not show any indication that it has the IPV6 address. A previous firmware (3.0.0.4.374.168) can let me link to IPV6 network, but all the firmware after that show nothing, I was wondering that if you can test the IPV6 function on RT-N15U. Thank you.![]()
Hello! Does IPSEC support means L2TP/IPSEC client connection (to vpngate.net) can be setup?
For RT-N12 D1 you mentioned it is tested but with some WiFi problem, what kind of issues are they?
Other then that range seem about the same, think the router I got maybe defective though. The signal will drop from full to 1 range is about 50 ft it seems
Welcome To SNBForums
