[Fork] Asuswrt-Merlin on Broadcom MIPS RT-N series
Installed on RT-N16
ce7cb4d2d33e8f3f8ebf1680e3c2232d RT-N16_3.0.0.4_376_2678-gb2dcaa5-m6b.trx
Again, downloaded from 2 different ftps and compared md5 sum. Also, I have installed it and so far is stable and has all the features.
Thanks!
MD5 Sum
Ok, so is pointless to download multiple and verify. I belive is a bit risky to flash without a way to verify the integrity of the download. Please post the md5 along with the file for verication.
- mod6b1, 23.09.2014
- Based on Merlin 376.47 final (ASUS 3.0.0.4.376_2678) source
- add WiFi Tx power adjust
- in QIS add Russia providers button
- mod7, 07.10.2014
- Based on Merlin 376.48 alpha3 (ASUS 3.0.0.4.376_2769) source
- renew WiFi driver for all models for latest from GPL 376.2678 (RT-N16), 376.2671 (RT-N14UHP)
- add swap file management in Administration page
- show AiCloud 2.0 installation on USB Application page (required external web kit - avaible later)
I have really wanted to try this firmware, but I have n14u, could be compatible? mediatek...
Hello
Hi!
First of all I want to thank you for this awesome firmware. It works way better on the 2.4ghz band (i have an average download speed from p2p via wifi of 10.5mb/s) than the official fw.
The only thing that is missing is the 5Ghz band. Am I doing something wrong or the firmware isn`t supposed to work on 5ghz?
I have an Asus RT-N53 A1 router.
Thanks again!
Hi!
Thanks again!
What version of mod you use?
I currently use mod7, but i also used mod6, 5 and 2 and had same issues with 5ghz band.
LE: I posted a ss for you to see that the router says the 5ghz radio is disabled while it is not.
please post screenshot Tools -> Sysinfo
Features
2.4G update mssid usbX1 switchctrl manual_stb aicloudipk rrsut pwrctrl ipv6 PARENTAL2 dualwan pptpd ssh cifs jffs printer modem appnet diskutility vpnc repeater ruisp nfsd user_low_rssi
is 5G present?
The 5g is present, also it lets me change settings for it and enable/disable radio but nothing happenes...
LE: Oh, and i can only choose control channel 0 or auto on the 5ghz settings
I understand why no 5G in RT-N53!!!
5G in RT-N53 by additional internal USB dongle. and I remove all USB support from RT-N53.
I return USB support and recompile.
mod7 working on RT-N16
Working good so far.
I was thinking that the swap feature was also for swap partitions. Can you put a setting to activate or deactivate swap in all devices (swapon -a).
Thanks!
Thanks!
if you know how make swap partition then you can add swapon -a command to /jffs/scripts/post-mount
