Beta [FORK] [DSL] [TESTERS] GNUton's Alpha/Beta Merlin builds
Has 388 been removed? Both betas appear to be gone and it's back to 386.
They’re not—it’s just that the 386.9 is showing as the most recent release. Scroll down a bit and you’ll see the 388.1 beta 2, which remains the latest release for 388 thus far.
On the XT8, not just with the current beta but the last 1-2 versions also, when I login the page only partially loads, I have to refresh once or twice for the web interface to fully load. After that the web interface is fairly responsive. This could just be me and be fixed with a device reset, but I don’t want to go through the trouble of setting up the router and nodes again.
Haha! Spend a half hour once vs. 5 minutes 20 times each? But it may be something else.
I'm of the mindset that when trying something "new" like that a clean slate better tells me what I want to know.
beta3 crashed.. Log shows multiple
Jan 11 05:08:52 kernel: Flushing net_device wds0.0.1.
Jan 11 05:17:14 kernel: eth1 (Int switch port: 1) (Logical Port: 1) (phyId: 9) Link DOWN.
after 6 days using beta_3 on DSL AX82U, I note that gui is so so slow and need refresh & refresh to access.
Out of curiosity, ssh in and see what "top" has to say about what the unit's so busy about at the moments this is happening.
latest stable version downloaded 388.1-gnuton1. somme reactivity of gui. thanks @GNUton.
Seeing multiple out of space Dnsmasq messages on xt8 running 388.1 release. Posted the full error messages in the Merlin 388.1 thread @GNUton ...
Here's some more detail of the errors:
Jan 24 16:23:19 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:24:19 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:25:19 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:25:44 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:26:03 bsd: bsd: Sending act Frame to 92:ad:82:b4:61:ab with transition target eth4 ssid 04:42:1a:34:83:20
Jan 24 16:26:04 bsd: bsd: STA:92:ad:82:b4:61:ab no response
Jan 24 16:26:04 bsd: bsd: Sending act Frame to 92:ad:82:b4:61:ab with transition target eth4 ssid 04:42:1a:34:83:20
Jan 24 16:26:05 bsd: bsd: STA:92:ad:82:b4:61:ab no response
Jan 24 16:26:44 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:27:44 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:28:12 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:29:12 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:30:12 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:31:12 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:32:12 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:32:55 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:33:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:34:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:35:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:36:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:37:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:37:44 bsd: bsd: Sending act Frame to 92:ad:82:b4:61:ab with transition target eth4 ssid 04:42:1a:34:83:20
Jan 24 16:37:45 bsd: bsd: STA:92:ad:82:b4:61:ab no response
Jan 24 16:37:45 bsd: bsd: Sending act Frame to 92:ad:82:b4:61:ab with transition target eth4 ssid 04:42:1a:34:83:20
Jan 24 16:37:46 bsd: bsd: STA:92:ad:82:b4:61:ab no response
Jan 24 16:38:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 16:38:06 bsd: bsd: Sending act Frame to 92:ad:82:b4:61:ab with transition target eth5 ssid 04:42:1a:34:83:24
Jan 24 16:38:08 bsd: bsd: STA:92:ad:82:b4:61:ab no response
Jan 24 16:38:08 bsd: bsd: Sending act Frame to 92:ad:82:b4:61:ab with transition target eth5 ssid 04:42:1a:34:83:24
Jan 24 16:38:09 bsd: bsd: STA:92:ad:82:b4:61:ab no response
Jan 24 17:10:08 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:10:45 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:10:59 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:11:00 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:11:03 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:11:09 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:12:09 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:12:31 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:12:49 dnsmasq-dhcp[16270]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Jan 24 17:13:15 bsd: bsd: Sending act Frame to 28:16:a8:64:24:1b with transition target eth5 ssid 04:42:1a:34:83:24
Jan 24 17:13:16 bsd: bsd: STA:28:16:a8:64:24:1b no response
Jan 24 17:13:16 bsd: bsd: Sending act Fra
Dumb question, is the XT8 FW on here compatible with the XT9? Or XT9 is not supported on Merlin at all?
@JWoo somebody was saying there was memory leak in the previous stable and in the end it has been proved there was no.But feel free to test it. The memory will consolidate around a certain mem usage without blowing.
I think 388.1_0-gnuton1 may have a leak, unless it's a ram stored log that just grows a lot. If it's a leak it's either very slow to grow, or it's caused by QoS (cake), or the QoS - WAN/LAN Bandwidth Monitor, and perhaps only if you change settings a lot or turn the latter on/off a lot.
After 75 days my DSL-AX82U was down to ~50MB free if the Bandwidth Monitor was on, ~130MB with it off.
After a reboot it's now ~130MB with the monitor on, 199 MB with it off which is around what I remember from the last boot, and previous builds.
I have not tried 388.2_2 builds yet, waiting to see more feedback.
