Hi all,
I just bought an ASUS PCE-AC66 PCIe card to go along with my AC66U router.
Now the question is, how do I go about configuring it to connect using dual-band mode, so that I can get the full advertised 1750Mbps? At the moment, the ASUS utility shows my network as two separate networks (2.4 and 5GHz). Both have the same SSID, but it appears I can connect only to the one or the other.
When I connect to the 5Ghz I get connected at a speed around 450Mbps and on the 2.4Ghz channel, it connects around 100Mbps (but goes upto 350Mbps). Both the channels show full signal strength.
How is dual-band operation supposed to work? I couldn't find any option in the router's config page. I'm running Merlin's latest beta.
