Kamoj Kamoj Add-on 5.1 Beta testing poll
Do you want to beta test Kamoj add-on v5.1b1?
  • No, I don't trust 3rd party software
    Votes: 0 0.0%
  • No, I don't use the Voxel firmware
    Votes: 0 0.0%
  • No, I don't like your add-on
    Votes: 0 0.0%
  • Total voters
    207
Source of problems seems to be the bug fixes in new-wall (both Voxel and Kamoj), in conjunction with an old bug fix
in kamoj openvpn-client. I never knew what the real problem was, so I have a fix in openvpn-client that might not work
as it should anymore.
as for the issue of jrbmw, this cannot be explained by the changes in netwall.
If I see the contents of his ip route, then your code should have extracted the wan-gateway-ip and wan-interface-name without issues and should have added the default route based on those to things to table novpn.
(in my opinion, there should be more routes added to novpn, hence I used a different approach. But still for most users, your version should work.)
Also your bugfix for openvpn-client should have nothing to do with it and is still required to properly cleanup, as far as I can tell.
But, I suspect that ppl might expect that bypassed devices are not affected by the killswitch. i.e. that if you add a device to the bypass list, that then for that device traffic is allowed to flow from br0 to brwan (or ppp0).
this part is easily solved by editing /etc/init.d/openvpn-client and changing
  if [ "$killswitch_onoff" = "1" ]; then
        echo '#!/bin/sh' >"$tmpfirewall"
        iptables="iptables -I FORWARD -i br0 -o ${WAN_IF} -m state --state NEW -j REJECT"
        echo -e "$iptables" >>"$tmpfirewall"
        chmod +x "$tmpfirewall"
    else
into
        echo 'no_vpn_file="/tmp/addons/no_vpn_file"' >>"$tmpfirewall"
        echo 'if [ -s "$no_vpn_file" ]; then' >>"$tmpfirewall"
        echo '  sort -r <"$no_vpn_file" | while read -r excludeip excludemac; do' >>"$tmpfirewall"
        echo '    iptables -I FORWARD -i br0 -s ${excludeip} -j br0_fwd' >>"$tmpfirewall"
        echo '  done' >>"$tmpfirewall"
        echo 'fi'  >>"$tmpfirewall"
    else
edit: for the people that also use aegis, this simple fix also seems to bypasses aegis protection (only for clients that bypass vpn).
apparently the firewall-start-openvpnkillswitch.sh is apparently later executed than firewall-start.sh...
Needs some more thinking...
the other issue (/tmp/openvpn/firewall-start-openvpnkillswitch.sh not being recreated at boot while killswitch is on), that is something for @kamoj to look at.
You lose the password etc if you have a usb device with the configurations inserted when rebooting.
That is by Voxel firmware design. If you use the kamoj built-in configuration id/password is not lost.
So rename the usb directory "openvpn-client" to something else, please.
Kill switch may need to be rewritten after the new net-wall.
Let's hope for a tip from @R. Gerrits again!
Thank you. I thought that was the case with the OpenVPN username/password but wasn't sure. And thanks to you and all involved with this...perhaps there may still be a few bugs to fix but Voxel/Kamaj has made a huge difference in the usability of my R9000.!
@kamoj
Noticed a small issue here. The reporting of CPU frequency is wrong. The first 3 are reporting in KHz while it should be in MHz. I don't think the CPU of the router does 600 KHz speed for example :)
Core 0: 1.725 GHz (100.0 %) Core 1: 1.725 GHz (100.0 %) (384KHz 600KHz 800KHz 1.000MHz 1.400MHz 1.725MHz)
Correct, when I go to the menu for VPNBypass menu doesn't show a list of devices of what is going through the VPN and what is not.
Running:
Nighthawk(R) X4S R7800
Router Firmware Version (Voxel) V1.0.2.77SF
Kamoj Add-on V5.3b5
Tested with Voxel v1.0.2.76sf and Kamoj v5.3b4......doesent bypass
Tested with Voxel v1.02.77sf and Kamoj v 5.3b4 and Kamoj 5.3b5 ....doesent bypass
Tested with Voxel v1.0.2.76sf and Kamoj v5.3b5......doesent bypass
Can anyone confirm bypass on ovpn works ?
Anyone noticed the download links for the add on have gone? If anyone's got a copy of the latest b5 version downloaded, can you PM it over to me. Cheers.
Exciting I guess you on to something. I think we found a leak that something big is going on and maybe a new release is coming. Have no sources to confirm this but....
I guess we have to wait for the man to confirm. But I feel its something good.
Dear,
I've tryed to access to http://ge.tt/... to download a the preview of 5.3 but I'm able only to visualize the FAQ.txt and not to download the add-on.
Can anyone help me?
Thanks in advance.
Regards
stefano
Changes in kamoj-addon beta version 5.3b6
- AdGuard Home: Added 2 DNSCrypt servers + MVPS filter default ON/activated.
- AdGuard Home: Changed default statistics life time from 1 to 7 days.
- AdGuard Home: Changed update interval for filters from 24h to 12h.
- Router Information: Corrected available CPU scaling frequencies. (@microchip)
- Bandwidth Usage: Added date for when counters were started/reset. (@Droidrat)
- Bandwidth Usage: Some bug-fixes
- DNSCrypt: Disabled if Stubby is enabled at boot.
- OpenVPN Client: Speeded up start when DNSCrypt is not used
- OpenVPN Client: Enable killswitch also for ppp0 (@R. Gerrits)
- OpenVPN Client: Don't delete existing directory if also on USB (@blueliner)
- OpenVPN Client: Start Killswitch also when OpenVPN Client does not start (@blueliner)
- OpenVPN Client: Added option: No Killswitch for Bypass devices (@R. Gerrits)
(Let OpenVPN bypassing devices override the killswitch)
NOTA BENE: This also bypasses Aegis protection (only for clients that bypass vpn).
The problem is that Aegis (@HELLO_wORLD) uses the Voxel standard firewall-start.sh.
- VPN Bypassing: Bug fixed: Bypassing not working when default route missing. (@masta_orc @R. Gerrits)
- Wireguard Client: Don't delete existing directory if also on USB
- speedtest.sh : Now working with ppp0
- Settings: Added: "Router Analytics / Data Collection / Phone Home" section (@kamoj @NetBytes @HELLO_wORLD @R. Gerrits)
- Settings: Added: Enable: Router Analytics Data Collection form (Advanced : Firmware Update)
- Settings: Added: Disable: Collection of RAE Router Analytics (Amazon Cloudfront) data
- Settings: Added: Disable: Streamboost QoS Data Collection service
- Settings: Added: Disable: Traffic Meter service
- Settings: Added: Disable: USB Printer drivers
- Installer: Some fixes
- FAQ.txt updated
Wow, that is really a lot of changes/fixes in a short time. 5.3b6 installed without a hitch for me and the VPN/Bypass (using no killswitch for bypassed devices) seems to be working. Will post again if there is anything else to update...but this is looking great.
Thanks,
BL
Nice :)
However, about aegis:
To fix this, rename the Aegis file and run net-wall restart :
\mv /opt/scripts/firewall-start.sh /opt/scripts/firewall-start-xaegis.sh && net-wall restart
With that quick fix, aegis will regenerate firewall-start.sh (but not remove created firewall-start-xaegis.sh.
So this should work, but aegis would not be able to clean its rules when called from firewall-start-xaegis.sh.
The principle of multiple firewall-start-xxx.sh is great but as you said not enabled on vanilla @Voxel ’s firmware.
I will have aegis changing a little @Voxel ’s net-wall when @kamoj is not installed to detect firewall-start-xxx.sh the same way as the add-on allows.
In parallel, it might be good for @Voxel to update his net-wall to use multiples firewall-start.sh so it would be harmonized and work the same way with or without @kamoj add-on.
It net-wall this:
if [ -x /opt/scripts/firewall-start.sh ]; then
Needs to be replaced by that:
ls --color=never /opt/scripts/firewall-start*.sh | while read FWS; do [ -x "$FWS" ] && "$FWS"; done
This is the substitution I will have aegis make when @kamoj ’s addon will not be detected.
PS: I am working hard on aegis. I simplified the code and improved the design. I am redoing the whole status section to allow easy HTML output. :)
NB:
The substitution in net-wall would have to take care of this part too:
        elif [ -x /root/firewall-start.sh ]; then
        fi
So this block:
        # Run own script with own iptables rules providing backward compatibility
        fi
By that one:
        for FWS in $(ls --color=never /opt/scripts/firewall-start*.sh); do [ -x "$FWS" ] && { "$FWS"; FWS_FOUND=1; }; done
        [ -z $FWS_FOUND ] && [ -x /root/firewall-start.sh ] && /root/firewall-start.sh
  • Like
Reactions: KW.
Nice :)
Also, I just noticed that kamoj's addon does a "sort -r" so it then still executes firewall-start-xaegis.sh before all the other scripts, so that workaround also doesn't work.)
(one would assume that sorting in reverse order, would also put firewall-start.sh at the end, but it doesn't)
I think the best solution is that @kamoj changes "sort -r" into "sort -u -c"
Then first all the scripts firewall-start-*.sh are exectuted in normal alfabetical order.
and after that firewall-start.sh is executed.
(apparently a hyphen is earlier in the "alphabet" then a dot.)
This works as long as we keep the standard that all additional scripts have a hyphen after firewall-start.
See this example:
root@R7800:~$ find /opt/scripts/ -type f -name "firewall-start*.sh" -exec test -x{} \; -print | sort -u -c
/opt/scripts/firewall-start-adguardhome-tun0.sh
/opt/scripts/firewall-start-adguardhome.sh
/opt/scripts/firewall-start-bwusage.sh
/opt/scripts/firewall-start-bypassvpnports.sh
/opt/scripts/firewall-start-openvpnkillswitch.sh
/opt/scripts/firewall-startlog.sh
(firewall-startlog.sh is an example that would be executed after firewall-start.sh, because it doesn't have a hyphen)
  • Like
Reactions: KW.
hmm, apparently that does work with the sort binary in entware, but not with the sort binary in the firmware...
root@R7800:~$ find /opt/scripts/ -type f -name "firewall-start*.sh" -exec test -x{} \; -print | /usr/bin/sort -u -c
/usr/bin/sort: -:2: disorder: /opt/scripts/firewall-start-adguardhome-tun0.sh
then an alternative solution:
keep the original Voxel code in net-wall, but just before add a line:
find /opt/scripts/ -type f -name "firewall-start*.sh" -exec test -x{} \; -print | grep -vF "/opt/scripts/firewall-start.sh" | sort | xargs -n1 sh
(do we need the sort command, or is the output of find already always sorted??)
This would execute all firewall-start*.sh scripts, except firewall-start.sh.
And then firewall-start.sh would be executed by the Voxel code.
  • Like
Reactions: KW.
Why not keep simple?
That:
works well, and could replace the @kamoj code in his net-wall. Ultimately being in both @Voxel and @kamoj net-wall
It works with and without Entware, it is simple and short, fast and also sorts well with firewall-start.sh at the end (so I don’t even have to change so much in aegis for that).
