R9000
Thank you very much for your help and support!
I had a problem for 2 consecutive days. I think the problem is PIA, caused by DNS and service itself, but I've found out that with Adguard off at least OpenVPN connected again, after sometime. I don't know why, maybe it is not related.
A reboot didn't solve the problem, and after some hours the problem solved partially by itself. Partially because I noticed a DNS leak by OpenVpn and Pia. It shows the DNS I've configured manually in the main section of the router, not the country DNS of the VPN as usual. I will check again and I will tell you if there will be the problem again. I want to try to start from scratch, as soon Voxel will release an update too, then I will let you know about the problem.
Thanks again!
Thanks again!
Thank you for heads up.
You are right, PIA changed source of configuration files - again
I'll probably release a new add-on this weekend for that fix.
From the add-on you can use DNSCrypt or Stubby or Adguard Home to use other DNS services.
For using different DNS for "some device":
https://www.snbforums.com/threads/s...rol-in-my-build-of-firmware.54815/post-463011
