shubham0saroha
can someone please tell me that how to install latest kamoj add-on in the simplest way.
thank you
thank you
Hi Possible bug issue I will try and explain as best possible
Issue takes about 12/13 days to show up and was present in kamoj-addon beta version 5.4b10 and the previous beta I had installed which was presumably 9
I have a 900 down 100 up connection
I use AdGuard with standard settings. I use no other feature of the addon
For approx 12 days everything working fine
Then upload and download speeds slowed to a crawl
Reboot failed to fix
Uninstalled addon - failed to fix
Reset router to factory defaults and tried a config backup - failed to fix
Reset to defaults again and then manually set up without using config file and all working OK. Speeds back to normal
Installed Addon again and was last using beta 5.4b10
all worked fine for approx 12 days then speeds slowed again to a crawl again
Uninstalled addon - rebooted - failed to fix
I had created a new backup config file after the last issue and after router reset this installed no fine
I am currently running router without addon and will see what happens to speeds after 12 days or so
Lots of things to try such as reducing DNS log data time to see if router was getting overrun (although there was no obvious issues when looking at router stats page)
I will need to wait until I have run router without addon - It may not even be the addon
I see a previous post about speeds when using DNSCrypt Proxy v2 - Possibly some kind of connection ?
@ern, I hope you didn't use a saved backup config file to 're-upload' your config? If so, you effectively undid the reset to factory defaults you performed.
...upload speed drops tremendously to about 0.5 when in fact in reality it should stick around 500. Router GUI becomes more unresponsive and I get a drop out on connection to internet. Opening web pages is pain and running shell commands through putty is painfully slow.
Almost feels like when Kamoj just updated to 5.4, when QoS was interfering (apparently)?
I experience the same issue and reported it (poorly) as post 46, but an intense month at work pulled me away from further testing. Any time I upgrade Voxel firmware or kamoj add-on versions, my upload speeds drop below 1Mbps. This has been the case since I moved from b7 to b10, and continued through b12.
At the time of my post, I thought activating DNSCrypt caused the issue, but based on Kamoj's advice I tested further and learned that my multiple reboots during setup were the actual problem. I can't upgrade Voxel fw or the kamoj add on without an nvram wipe, but I can set up all desired options so long as I perform the wipe and don't reboot after each step. Two days before vacation, so I plan to test this properly next week and report back.
Now my process is:
- nvram wipe via ssh (nvram default && nvram commit && mtd erase netgear && reboot) immediately before kamoj upgrade or immediately following Voxel upgrade
- standard set-up through GUI (admin password, SSID, wifi password, router function, enable smart connect, enable telnet)
- set ssh key via telnet (from USB drive), reboot (optional)
- copy and install kamoj add-on via ssh, reboot, no further reboots after this point
- disable QoS
- disable Traffic Meter
- enable DNSCrypt Proxy v2 and custom blacklist via kamoj GUI
- enable OpenVPN Client (Surfshark) via kamoj GUI
- enable tunneling via NOVPN tags in LAN setup GUI
If I skip the nvram wipe, the rest of the process doesn't work and my upload speeds choke.
Please read the readme.txt again.
##### reboot MUST be performed #####
And are you sure your speed drop if you only update Voxel firmware?
(I suggest you do according to instructions before installing new Voxel firmware:
(From readme.txt)
"5). Uninstall previous version of kamoj-addon (if any) - IMPORTANT!
Also I suggest you try to disable QoS and Traffic Meter from the Voxel/Netgear GUI, not the kamoj settings.
So far, so good on my R9000 with 5.4b13 (and Voxel 1.0.4.46). Only issue I have seen is getting the following if I try to make a change on the Hidden Menus --> Fan Control Temperature page (which I assume is normal?):
400 Bad Request
This server does not support the operation requested by your client.
I have seen a few ping failures on Cloudflare but it hasn't affected anything.
VPN Bypass has been working without issue.
BL
I apologize as I asked this question then life happened and couldn't get back to dig into the answer. In kamoj's most excellent add in there's options for grouping the antennas. Which is great but I can't find which antennas belong to which group. If I'm gonna play with the option I'd like to know what I'm doing. I know, what a killjoy....
Is there some map somewhere laying out the antenna groupings?
R9000 running Komoj v5.4b7 with Voxel v1.0.4.45.2HF currently without Adguard or any DNS Filter/Encryption. Surfshark VPN and some VPN bypassing. Together with R7800 in AP mode running Komoj v5.4b6 with Voxel V1.0.2.80.5SF.
Apart from an occasional VPN Inactivity timeout (--ping-restart) it is running well
The problem started after installing the R9000 (early September) and setting up Surfshark on it. I had previously been using Surfshark for a couple of months on my R7800 as the main router.
Has happened with all versions of Voxel (from v1.0.4.43 to 1.0.4.45.2 (apart from 1.0.4.45.1 which I did not install) and your addons from 5.3b30 to 5.4b7 (apart from 5.4b4 which I did not install). I usually update the addon within a day of updates being released.
ISP is a mobile (cell) provider (since just before installing the R9000) and the download/upload speed is usually 15 to 25mb for both (usually better via VPN than not). However at certain times of the day (usually evenings) this drops substantially.
Initially seemed OK then kept dropping the connection briefly. Varied from 1 or 2 times per day up to 7 to 10 times. There does not appear to be any set pattern or regular interval. However, I will try and monitor it and let you know if a pattern appears. Initially thought it was a problem with Surfshark settings so changed the config file to tie in with the push settings received. The following settings were added or changed in the config to try to improve things.
#ping 60
#ping-restart 180
#ping-timer-rem
keepalive 60 360
connect-retry 1
cipher AES-256-GCM
There appeared to be a reduction in number of restarts following these changes as most days it is only 1 or 2. However that may be coincidental
Killswitch is on, no killswitch for Bypass, Restart at connection failure and Turbo are on
Further info:
The push settings received on starting VPN are:
Thu Nov 5 07:06:17 2020 PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 162.252.172.57,dhcp-option DNS 149.154.159.92,redirect-gateway def1,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,block-outside-dns,route-gateway 10.8.8.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.8.8.8 255.255.255.0,peer-id 6,cipher AES-256-GCM'
Thu Nov 5 07:06:17 2020 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:7: block-outside-dns (2.4.9)
The following is an extract from current session log sowing 2 restarts since the current session started (on 2020-11-04 at 06:01:31)
“Wed Nov 4 22:00:35 2020 [uk-lon-v032.prod.surfshark.com] Inactivity timeout (--ping-restart), restarting
Wed Nov 4 22:00:35 2020 SIGUSR1[soft,ping-restart] received, process restarting
Wed Nov 4 22:00:35 2020 Restart pause, 1 second(s) (note - changed from 5 seconds to reduce down time)
Thu Nov 5 07:00:42 2020 TLS: tls_process: killed expiring key
Thu Nov 5 07:00:43 2020 VERIFY OK: depth=1, C=VG, O=Surfshark, CN=Surfshark Intermediate CA
Thu Nov 5 07:00:43 2020 VERIFY KU OK
Thu Nov 5 07:00:43 2020 Validating certificate extended key usage
Thu Nov 5 07:00:43 2020 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Nov 5 07:00:43 2020 VERIFY EKU OK
Thu Nov 5 07:00:43 2020 VERIFY OK: depth=0, CN=uk-lon-v032.prod.surfshark.com
Thu Nov 5 07:00:43 2020 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Thu Nov 5 07:00:43 2020 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Thu Nov 5 07:00:43 2020 Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Thu Nov 5 07:06:15 2020 [uk-lon-v032.prod.surfshark.com] Inactivity timeout (--ping-restart), restarting
Thu Nov 5 07:06:15 2020 SIGUSR1[soft,ping-restart] received, process restarting
Thu Nov 5 07:06:15 2020 Restart pause, 1 second(s)”
I hope that helps
If you need anything further (eg full session log or other logs) I can provide them. I do not currently save logs so information is currently only available from the last reboot.
PS I am hoping Surfshark start to support wireguard on the router, at present they only have wireguard on their apps for PC/Android etc.
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 41 |
Welcome To SNBForums
