Monitoring Web Usage with Asuswrt-Merlin
Hello Again
being out of ideas i wanted to verify if for any chance there was a difference for webmon in John' fork or Merlin' firmware
So i installed latest Merlin firmware on my RT-N66u , I did a factory reset, NVRAm restore with John' script and.... webmon still not working ... nothing comes out from /proc/webmon_recent_domains .
Realy not any idea what could be wrong beause other people use WebMon on RT-N66U so it must me something related to my configuration but no idea what it could be
I even tried to reset Merlin Fw to it's default NVRAM valuse, and then just manualy configuring basic WAN connection (so no JFFS at all to be sure that no other configuration or tool was running)
Then I manually launched any webmon needed command.. and the result is still the same.. webmon files are present and up to date under /proc but nothing comes out from them
Thanks in advance for any hint about what I could do
BR
ocraM
Hello Again
BR
ocraM
Did you turn off "NAT Acceleration" ? You need to turn it off and save, then reboot before turning on webmon
Hello
Thanks for you feedback
Yes , NAT acceleration is off since long time because I enabled "Per IP Monitoring" and it woks fine since many months.
Thanks alot anyway for your help
BR
ocraM
Two thoughts.....
What is the result of
nvram get wan0_ifname
Second....are you running dual stack? What happens if you disable IPv6?
Two thoughts.....
Hello, name is regular eth0
admin@RT-N66U:/tmp/home/root# nvram get wan0_ifname
eth0
Not sure if for dual stack you mean dual wan.. if so.. it is currently disabled. (was enabled long time ago just to test switch on 3g modem as failover)
IPv6 is DISABLED, but on the same config page I see Enable Router Advertisement and Enable DHCPv6 Server both as ENABLED
Thanks alot for your help
ocraM
P.S I switched back to 3.0.0.4.374.43_2-08j9527 because I need wifi features of that fork and nothing changed regarding webmon using Merlin fw.
By dual stack I meant IPv6+IPv4. This won't capture IPv6 traffic.....but, cross that off.
@john9527 and @ocram59 --
Most of this discussion is beyond my understanding... But I do see a couple differences in the iptables rules that ocram59 posted, versus the rules that are working for me (also N66u, Rmerlin 378.51). I don't know if this is significant, so I'll just throw it out here for your analysis.
What I have for webmon in iptables --list:
Chain web_monitor (1 references)
target  prot opt source  destination
        tcp  --  anywhere  anywhere  WEBMON --max_domains 2000 --max_searches 2000
What ocram59 posted as having for webmon in iptables --list (different chain name, and extra line starting with "LOG"):
Chain monitor (1 references)
LOG    all  --  anywhere  anywhere  state NEW LOG level info prefix `webmon'
What does that "LOG" line do, and could it have anything to do with the problem?
Hello
Thanks, it is really the best thing we could to to compare a working setup with mine
Chain name is different because I followed Joh "how to" in his fork release
Extra LOG line comes from the attempt to log in system log webmon entries
I got it in a post of this thread and I tried to see if for any chance it made a difference
Now I will try again to setup chain name as your and I will remove the extra log iptables entry to see if after a new full rest i can get it working
Thank alot
ocraM
I probably shouldn't have made the name change (I changed it in the instructions with my fork to be consistent with tomato, just in case I backport something from them in the future). Just make sure it's consistent....either all 'monitor' or all 'web_monitor'.
I will try it as soon as possible, anyway name seems to be consistent (maybe you remeber we talked about that in the other thread)
Here my firewall-start lines for webmon.. (without the extra log line that I added manually)
if [ -z "$(iptables -n -L FORWARD | grep 'monitor')" ]; then
  modprobe ipt_webmon
  iptables -t filter -N monitor
  iptables -t filter -I FORWARD -o eth0 -j monitor
  iptables -A monitor -p tcp -m webmon --max_domains 2000 --max_searches 2000
fi
I will try again with both names and see if it makes any difference
  modprobe ipt_webmon
fi
I changed chain name in the following way :
#Setup WebMon
if [ -z "$(iptables -n -L FORWARD | grep 'web_monitor')" ]; then
  modprobe ipt_webmon
  iptables -t filter -N web_monitor
  iptables -t filter -I FORWARD -o eth0 -j web_monitor
  iptables -A web_monitor -p tcp -m webmon --max_domains 2000 --max_searches 2000
fi
Still not working :-(
Current IP Tables --list
Chain INPUT (policy ACCEPT)
ACCEPT     udp  --  anywhere             anywhere            udp dpt:51413
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:51413
ACCEPT     tcp  --  192.168.50.0/24      anywhere            tcp dpt:ftp
DROP       tcp  --  anywhere             anywhere            tcp dpt:ftp
ACCEPT     all  --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:https
ACCEPT     udp  --  anywhere             anywhere            udp dpt:https
logdrop    all  --  anywhere             anywhere            state INVALID
ACCEPT     all  --  anywhere             anywhere            state RELATED,ESTABLISHED
ACCEPT     all  --  anywhere             anywhere            state NEW
ACCEPT     udp  --  anywhere             anywhere            udp spt:bootps dpt:bootpc
Chain FORWARD (policy DROP)
web_monitor  all  --  anywhere             anywhere
ipttolan   all  --  anywhere             anywhere
iptfromlan  all  --  anywhere             anywhere
TCPMSS     tcp  --  anywhere             anywhere            tcp flags:SYN,RST/SYN TCPMSS clamp to PMTU
DROP       icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere            tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
ACCEPT     tcp  --  anywhere             anywhere            tcp flags:FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
ACCEPT     icmp --  anywhere             anywhere            icmp echo-request limit: avg 1/sec burst 5
ACCEPT     all  --  anywhere             anywhere            ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (0 references)
Chain iptfromlan (1 references)
RETURN     all  --  anywhere             anywhere            account: network/netmask: 192.168.50.0/255.255.255.0 name: lan
Chain ipttolan (1 references)
Chain logaccept (0 references)
LOG        all  --  anywhere             anywhere            state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `ACCEPT '
Chain logdrop (5 references)
LOG        all  --  anywhere             anywhere            state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `DROP '
DROP       all  --  anywhere             anywhere
admin@RT-N66U:/jffs/scripts#
Let's see if this make a difference.
try changing the last line from
iptables -A web_monitor -p tcp....
to
iptables -I web_monitor -p tcp...
to
I changed it:
#Setup WebMon
  modprobe ipt_webmon
  iptables -I web_monitor -p tcp -m webmon --max_domains 2000 --max_searches 2000
fi
Here the resulting iptables --list
admin@RT-N66U:/tmp/home/root# iptables --list
Still nothing after some minutes and many web accesses from main clien
admin@RT-N66U:/tmp/home/root# cat /proc/webmon_recent_domains
I am not an iptables "expert" but I wonder why -A and -I did not change the web_monitor position in FORWARD chain
P.S Upgraded to 3.0.0.4_374.43_2-10j9527 right now
Hello
BR
ocraM
Thanks alot for your help.. very appreciated.
One way or another we will find the reason :)
Sorry I can't help more. Having NAT Acceleration turned off fixed the problem for me.
What happens if you turn off 'Per IP Monitoring'? Then make sure NAT Acceleration is also disabled.
Hello
A little progress here and an interesting case to study:
In my normal setup have eth0 with my WAN IP
I also have eth0:0 configured with an IP outside my LAN IP and used only to access Modem.
No need to say that I already tried to remove this configuration and nothing changed for webmon.
But here it is the interesting thing: If I browse towrds the Modem UI (located at 192.168.1.1 whilst my LAN is on 192.168.50.0/24) then... webmon correctly logs this domani !!!
Here my current ifconfig for eth0
eth0       Link encap:Ethernet  HWaddr 50:xx:xx:xx:xx:xx
           inet addr:169.xxx.xxx.xxx  Bcast:169.xxx.xxx.xxx  Mask:255.255.0.0
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:12061 errors:0 dropped:0 overruns:0 frame:0
           TX packets:12353 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:3980151 (3.7 MiB)  TX bytes:4103795 (3.9 MiB)
           Interrupt:4 Base address:0x2000
eth0:0     Link encap:Ethernet  HWaddr 50:xx:xx:xx:xx:xx
           inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
and here it is the webmon tracing access from my PC IP to Modem UI
1427071588      192.168.50.2    192.168.1.1
So we have the evidence that webmon is working and an hint that normal WEB traffic is not monitored because of some conflict in iptables.
I will continue to investigate
Hi
unfortunately nothing changes for webmon.
I tried it right now after disabling per ip monitoring and rebooting the router
I checked NAT acceleration before and after reboot and it was disabled
I have the same configuration for my modem....here's my ifconfig (you should clear your mac and ip address in your post)
eth0  Link encap:Ethernet  HWaddr D8:XX:XX:XX:XX:XX
  inet addr:68.xxx.xxx.xxx  Bcast:68.xxx.xxx.255  Mask:255.255.255.0
  RX packets:1559700 errors:0 dropped:0 overruns:0 frame:0
  TX packets:952553 errors:0 dropped:0 overruns:0 carrier:0
  RX bytes:703689198 (671.0 MiB)  TX bytes:647184768 (617.2 MiB)
  Interrupt:179 Base address:0x4000
eth0:0  Link encap:Ethernet  HWaddr D8:XX:XX:XX:XX:XX
  inet addr:192.168.100.2  Bcast:192.168.100.255  Mask:255.255.255.0
The only thing interesting in your ifconfig is that your eth0 address is in 169 subnet.....I wonder if it treats those differently????
Thanks for you hint (silly of me .... :-) )
Good that we have the same configuation for eth0
And for you does webmon tracks any kind of web acces to both "LANs"(eth0 and eth0:0)?
