Hi, I'm very new to ASUS-Merlin, as I just installed it on my ASUS RT-AC87U this past weekend.
How can I learn about installing a script onto my router, that will copy one attached USB Device (USB1) to a second attached USB Device (USB2)? I want the router to do this automatically at 3 am, daily. I plan on using XCopy from a Windows 10 computer to update USB1 with the client's local files as soon as a network connection is established at bootup.
This is a sample of the xcopy script that I will be using from client to USB1. I want the script from USB1 to USB2 to have the same or similar parameters.
Any help anyone can provide to me would be great. Thank you.
/D:m-d-y Copies files changed on or after the specified date. If no date is given, copies only those files whose source time is newer than the destination time.
/E Copies directories and subdirectories, including empty ones. Same as /S /E. May be used to modify /T.
/C Continues copying even if errors occur.
/Q Does not display file names while copying.
/H Copies hidden and system files also.
/R Overwrites read-only files.
/K Copies attributes. Normal Xcopy will reset read-only attributes.
/Y Suppresses prompting to confirm you want to overwrite an existing destination file.
