Hey guys/gals. Is there any hope that somebody will create a firmware to give us back the Radio Tx Power Adjustment capability for this router? I just bought it, and I'm pretty disappointed that I can't lower the radio signal power on either the 2.4 or 5Ghz bands. I'm pretty sure that the reason so many ASUS routers are dying after only a year or less is because the radio power is almost full-blast all the time, and it's rough on the internal circuits to be at max output 24-7. I don't need that much broadcast power. My neighbors are going to hate my guts if/when I bring this thing into service. I have had a D-Link Dir 655 Extreme N Router for about 8 years, and it's still running flawlessly using G-Only @ 20Mhz with a 20Mbps ISP. I'm getting Google Fiber soon and thought the RT-866U B1 would do the trick, but now I'm thinking that I might have to give it away or send it back. Is there any AC router as good as this one but has a TX power adjustment for both bands that actually works when you adjust it? Thanks in advance. P.S. I updated the firmware from ASUS for this router and then put the RT-AC68U Merlin Firmware on it, and it has been flawless while I was getting it all set up to deploy. Merlin is the man!
