Blind@Spot
Hi, Why this router not on the official site list? I recently bought it.
AC66U_B1
AC66U_B1
it is really good for me.... Could you send a feedback to me by administrator -> Feedback in WebUI ? And contain system log, wifi log.It will bring down my whole network, not only internet, i.e. can't ping/connect other device on my network for 30secs~1mins when reboot
The problem is more serious right now, if I keeps the ac68u power on then after a while it will start interrupt my network again, currently only a network cam connect to the aimesh by wifi, all others hardwired to the cisco siwtch or the draytek router, no device connect to the ac68u lan port, wan port is hardwired to the switch or router for backhaul .
My environment look like this:
and when the ac68u act weird:
ping from my pc 11.100, 11.1 is the draytek router, 11.3 is the ac68u as AP, I try power on only 1 ac68u per test but it still happen, all the 3 ac68u will interrupt my network alone
yes it currently on LAN port, but I tried both WAN and LAN port on the main and the node, no different.it is really good for me.... Could you send a feedback to me by administrator -> Feedback in WebUI ? And contain system log, wifi log.
The AiMesh main use LAN port to connect with cisco sg-200-26. is't correct ?
one more thing, all the Aimesh main/node don't have internet connection as our network only allow some specific device have internet connectionm dunno will this trigger something.
I will send the feedback later tonight, I am trying to restore the network first![]()
Discuss it here. Thread title changed.When asus releases the gt-ac5300 mesh firmware officially will it be discussed in this thread as well? Or will it can't its own thread?
Seems this problem related to DHCP, I change one of the PC to static IP and it won't be affect after that
I have upgraded the firmware to 384 10007 on both master (main) and slave (node).
Both are AC68U.
It would be very nice if the upgrade process, when you have the same router models for master and slave(s), could be automated so that all routers in the mesh-system are upgraded in a single process (one click).
No, I still can't figure out what's going on, but at least set the pc to static IP will prevent interrupt/disconnect, I found this because I am trying to capture some packet for analysis and before that I set a static IP first.You mean DHCP caused the entire network problem
Hum... I still have the same issue that I had on the betas.
My setup:
Modem <-- ethernet cable --> RT-AC68U as router <-- ethernet cable --> RT-AC68U as node <-- ethernet cable --> PC
Issue:
Although the backhaul is configured as ethernet my max speed is still only around 350Mbps:
If I setup the node as the old bridge mode I get the full 1Gbps... Isn't it supposed to achieve the full ethernet port speed?
My setup:
Issue:
My setup:
Issue:
I also have powerline, it totally depends on your powerline or wifi is faster, but I prefer power line because I am using dual band model and also the 5G wifi signal is too weak in my case.Hi. I posted this yesterday in the other thread which has now been closed, so posting here also in case anyone is able to help answer.
I've just received my RT-AC5300. I will see how I go with performance/coverage, but suspect I will benefit from using Aimesh with another router. A few questions....
Thanks so much!
- Any idea when the official firmware will be released?
- How buggy is the current BETA and what are main issues currently known?
- Which router do people recommend for the node?Is it best to use another Tri-band router so as not to sacrifice features of main router?
- I use some AV1200 power line adapters in the house also - Am I best to allow the node to connect to the main router via wifi or via one of the Powerline adapters?
Welcome To SNBForums
