Reboot,flash,reboot
if its not working
Remove usb drive hooked , reboot, flash,reboot
You got it, a simple reboot and it started uploading the firmware. Thanks!
Reboot,flash,reboot
if its not working
I just found out about DNSCrypt and found it to be very usefull, is it possible to use this feature in Asus Merlin? Or will future Merlin support it?
On my own AC66U I performed this procedure to silence the SSL warnings in Firefox (with an earlier build):
https://gathering.tweakers.net/forum/list_message/46761677#46761677
Today I tried this on a family member's AC68U as well. Firefox does not import that certificate. It fails silently. When I generate the certificate on my own router instead (via ssh) it is not accepted as well. The certificate I use at home for some time now (and created with an earlier build) is accepted by Firefox.
How can I debug this?
It sure is a nice post. Thanks a lot for posting that over there!That is a nice post .
The only thing I know, is that Firefox is sometimes a PITA with certificates. I assume that it works OK in IE/Chrome/Edge with the MMC method?
On the other hand, with the latest version my HE IPv6 tunnel is not stable, the connection on the clients drops frequently. More people with this behavior with the latest version on HE?
For easy installation you can use this script: https://github.com/rallegade/Install-script-asus-ac87u
Verzonden vanaf mijn iPhone met Tapatalk
Thank you, i have left the setting on auto but unchecked the "include DFS channels" box. Will see how it goes. The channel was 104 but now has changed to 40.
HI!
How to limit the speed guest wifi? It's possible with a script to do it?
Thanks guys!
My Samsung TV UE40H6200AK link is broken 2.4 and 5 MHz DLNA working time is only 15-20 minutes and the gap (((((((
Asus 87U- Firmware:380.61
I completely forgot about the MMC method since I primarily use Firefox, but hope to give this another try today.
MMC accepts the certificate. Firefox does not.
Same for the AC56U I installed for a family member today.
Only the older certificate for my own AC66U is accepted by Firefox.
I guess we have a same issue. Downgrading to 58.0 should fix it.HI!
Thanks guys!
Thank you wait can correct the errorI guess we have a same issue. Downgrading to 58.0 should fix it.
Thank you for testing this.I have created a new certificate on my AC-RT68U and the import in Firefox is flawless.
Anyone on RT-3200? I'm still on 380.59. Working great. Should I update to this version? Or no reason too if its working fine? If there are performance enhancements then I would def update.
On this firmware? (380.61)
I have the 3200 and while .59 was good for me, this version is much improved. My 2.4 problems have gone away with .61.
Welcome To SNBForums
