[Release] Asuswrt-Merlin 380.65 is now available
Hi, I found new bug in webui/openvpn - after adding CRL certificate, it is impossible to delete it:) It is after save rewritten by system.
Ok, workaround, left only dash there,save, and it will be deleted..
More background: I added some time ago CRL , but today got information that "error=CRL has expired:" So, I decided to remove it, than maybe recreate or something. But it is impossible. Information about crl even after removing is recreated by webui after save. Even leaving there dash or something doesnt help, when I search logs, there is "CRL: cannot read CRL from file crl.pem". Restart does not help...
I had to create completely new openvpn server 2, and server 1 left disabled...
With my router RT-N66U http://192.168.1.1:8200 doesn't work and often DLNA service go down. I seen errors about files in folder for not complete downloads. is it possible to modify interface to allow to configure more complex dlna path? (now it is possibile to configure a root folder and i would configure only "donwload complete" path)
Ac68u
Updated the smart 505n firmware to 2.5.0.11 to catchup with Merlin's amazing firmware.
Seems the firmware has gotten faster then the response from some dsl modems which could be a issue for some.
In my case a firmware update from my provider caught the modem up to the router so this is no longer a issue.
Feb 14 08:14:14 rc_service: httpds 450:notify_rc reboot
Feb 14 08:14:15 miniupnpd[907]: Failed to get IP for interface ppp0
Feb 14 08:14:15 miniupnpd[907]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Feb 14 08:14:17 wan: finish adding multi routes
Feb 14 08:14:18 iTunes: daemon is stopped
Feb 14 08:14:18 FTP Server: daemon is stopped
Feb 14 08:14:18 Samba Server: smb daemon is stopped
Feb 14 08:14:18 kernel: gro disabled
Feb 14 08:14:19 Timemachine: daemon is stopped
Feb 14 08:14:19 WEBDAV Server: daemon is stopped
Feb 14 08:14:19 NAT Tunnel: AAE Service is stopped
Aug  1 10:00:13 kernel: klogd started: BusyBox v1.25.1 (2017-02-03 00:18:59 EST)
Aug  1 10:00:13 kernel: Linux version 2.6.36.4brcmarm (merlin@ubuntu-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #2 SMP PREEMPT Fri Feb 3 00:27:49 EST 2017
Aug  1 10:00:13 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug  1 10:00:13 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 10:00:13 kernel: Machine: Northstar Prototype
Aug  1 10:00:13 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 10:00:13 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 10:00:13 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60416
Aug  1 10:00:13 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 10:00:13 kernel: Memory: 255488k/255488k available, 6656k reserved, 0K highmem
Aug  1 10:00:13 kernel: Virtual kernel memory layout:
Aug  1 10:00:13 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 10:00:13 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 10:00:13 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 10:00:13 kernel:     vmalloc : 0xd0800000 - 0xf0000000   ( 504 MB)
Aug  1 10:00:13 kernel:     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
Aug  1 10:00:13 kernel:     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Aug  1 10:00:13 kernel:       .init : 0xc0008000 - 0xc003d000   ( 212 kB)
Aug  1 10:00:13 kernel:       .text : 0xc003d000 - 0xc03a9000   (3504 kB)
Aug  1 10:00:13 kernel:       .data : 0xc03c0000 - 0xc03e32a0   ( 141 kB)
Aug  1 10:00:13 kernel: * Invalid signature of oopsbuf: FF-FF-FE-FB-FF-FF-FF-FF (len 4294967295)
Aug  1 10:00:13 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Aug  1 10:00:13 kernel: Mount-cache hash table entries: 512
Aug  1 10:00:13 kernel: CPU1: Booted secondary processor
Aug  1 10:00:13 kernel: Found a AMD NAND flash:
Aug  1 10:00:13 kernel: Total size:  128MB
Aug  1 10:00:13 kernel: Block size:  128KB
Aug  1 10:00:13 kernel: Page Size:   2048B
Aug  1 10:00:13 kernel: OOB Size:    64B
Aug  1 10:00:13 kernel: Sector size: 512B
Aug  1 10:00:13 kernel: Spare size:  16B
Aug  1 10:00:13 kernel: ECC level:   8 (8-bit)
Aug  1 10:00:13 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Aug  1 10:00:13 kernel: bio: create slab <bio-0> at 0
Aug  1 10:00:13 kernel: PCI: no core
Aug  1 10:00:13 kernel: PCI: Fixing up bus 0
Aug  1 10:00:13 kernel: PCI: Fixing up bus 1
Aug  1 10:00:13 kernel: PCI: Fixing up bus 2
Aug  1 10:00:14 WAN(0) Connection: Fail to connect with some issues.
Aug  1 10:00:14 WAN(1) Connection: ISP's DHCP did not function properly.
Aug  1 10:00:20 custom config: Appending content of /jffs/configs/dnsmasq.conf.add.
Aug  1 10:00:21 RT-AC68U: start httpd - SSL
Aug  1 10:00:21 syslog: Generating SSL certificate...
Aug  1 10:00:21 hour monitor: daemon is starting
Aug  1 10:00:21 hour monitor: daemon terminates
Aug  1 10:00:21 disk monitor: be idle
Aug  1 10:00:21 kernel: gro enabled with interval 2
Aug  1 10:00:23 Samba Server: daemon is started
Aug  1 10:00:24 jffs2: valid logs(1)
Aug  1 10:00:25 pppd[519]: pppd 2.4.7 started by felix, uid 0
Aug  1 10:00:25 pppd[519]: Connected to 78:da:6e:de:d2:60 via interface vlan2
Aug  1 10:00:25 pppd[519]: Connect: ppp0 <--> vlan2
Aug  1 10:00:25 pppd[519]: PAP authentication succeeded
Aug  1 10:00:25 pppd[519]: peer from calling number 78:DA:6E:DE:D2:60 authorized
Aug  1 10:00:25 pppd[519]: local  IP address 203.x.x.123
Aug  1 10:00:25 pppd[519]: remote IP address 10.x.x.119
Aug  1 10:00:25 rc_service: ip-up 536:notify_rc start_firewall
Aug  1 10:00:25 wan: finish adding multi routes
Aug  1 10:00:26 rc_service: ip-up 536:notify_rc stop_upnp
Aug  1 10:00:26 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 10:00:27 rc_service: udhcpc 569:notify_rc start_firewall
Aug  1 10:00:27 rc_service: waitting "start_firewall" via ip-up ...
Aug  1 10:00:27 syslog: module ledtrig-usbdev not found in modules.dep
Aug  1 10:00:27 syslog: module leds-usb not found in modules.dep
Aug  1 10:00:27 kernel: SCSI subsystem initialized
Aug  1 10:00:27 kernel: csw_retry 100
Aug  1 10:00:29 WAN(0) Connection: WAN was restored.
Aug  1 10:00:29 WAN(1) Connection: WAN was restored.
Aug  1 10:00:29 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan2)!
Aug  1 10:00:30 custom script: Running /jffs/scripts/nat-start
Aug  1 10:00:30 felix: firewall Applying nat-start rules
Aug  1 10:00:31 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 10:00:31 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 10:00:31 custom script: Running /jffs/scripts/firewall-start (args: ppp0)
Aug  1 10:00:31 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan2)!
Aug  1 10:00:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan2)!
Aug  1 10:00:32 custom script: Running /jffs/scripts/nat-start
Aug  1 10:00:32 felix: firewall Applying nat-start rules
Aug  1 10:00:33 custom script: Running /jffs/scripts/firewall-start (args: ppp0)
Aug  1 10:00:33 wan: finish adding multi routes
Aug  1 10:00:34 rc_service: ip-up 536:notify_rc start_upnp
Aug  1 10:00:34 rc_service: waitting "stop_upnp" via ip-up ...
Aug  1 10:00:34 dhcp client: bound 60.227.254.211 via 60.227.255.254 during 3600 seconds.
Aug  1 10:00:35 miniupnpd[872]: HTTP listening on port 47070
Aug  1 10:00:35 miniupnpd[872]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 10:00:35 ddns update: ez-ipupdate: starting...
Aug  1 10:00:35 ddns update: connected to dynamicdns.park-your-domain.com (104.219.249.25) on port 80.
Aug  1 10:00:36 ddns update: request successful
Aug  1 10:00:36 ddns update: asusddns_update: 0
Aug  1 10:00:37 ddns: ddns update ok
Aug  1 10:00:37 rc_service: zcip 873:notify_rc start_firewall
Aug  1 10:00:37 zcip client: configured 169.254.65.176
Aug  1 10:00:38 miniupnpd[872]: shutting down MiniUPnPd
Aug  1 10:00:38 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan2)!
Aug  1 10:00:38 custom script: Running /jffs/scripts/nat-start
Aug  1 10:00:38 ntp: start NTP update
Aug  1 10:00:38 felix: firewall Applying nat-start rules
Feb 14 08:20:43 rc_service: ntp 877:notify_rc restart_upnp
I copied the log of the issue. Not sure if anything interesting.
It happened again this morning. Internet very slow.
Logged into portal, everything looks fine.
Then I changed the dualwan mode from LB to failover, then the network map shows secondly wan interface did not get IP from ISP.
So I disabled the dualwan mode, only using single WAN. Then it takes 90 seconds to restart service. Lost wireless. After 90 seconds, still no wireless. Same as last time, reboot the router using mobile app.
I have to power cycle to take it back.
Seems like, something works not quite normal in this version. I am looking to roll back to previous 64_2 version.
Well if you like your client list and printers to continue working, you may as well skip 7266.
Sorry Merlin, you probably won't be merging the ASUS GPL for a bit longer ;)
Asus RT-N66W working in router mode. No DHCP, no WAN connection - all real routing is performed by RT-AC66U connected upper.
No USB devices, just connection of several clients via WiFi and Ethernet.
Every morning 5.0 GHz band is down. Also I cannot connect to web-interface of N66W. AC66U works OK.
The only solution is reboot.
Anybody expects the similar problems on 380.65?
Also sometimes the device loses connection to upper AC-66U with the following in logs:
And the most surprising: the time settings are the same at both routers, but time in log of N66W is incorrect.
i have the exact same thing happening on rt-ac56r, 2.4 ghz is up and working fine, 5 ghz keeps dissappearing every 20 sec or so. cant connect to web ui on 2.4ghz til i reboot it. any suggestion what firmware i should switch to till this gets fixed?
just switched 380.64_2 will report back here if i have any issues, thanks for the help blinkyz!
do you know whats the best setting that i should use for the 5Ghz for for the fastest file transfer speeds?
I downgraded to 64_2 early today after completed lost wireless signal twice when rebooting services.
RT-AC68U
mine has been stable so far after flashing with 380.64_2
edit: spoke to soon 5ghz keeps disconnecting every couple of minutes
If no one reports this problem to ASUS, it will never be fixed.
I have had no issues with wifi on my 56 and this firmware. I have 2.4 shutoff and only use 5 ghz and no drops or disconnects or anything and have about 8 devices using it at once.
tho I only use it as an router with adblocking everything else is turned off or not running. and no issues with this version.
i changed some setting last night in wireless/professional a so far no disconnects, i changed WMM APSD to disable , and others but i dont remember which ones (just copy my settings) make sure you make the changes on the 5GHz
