[Release] Asuswrt-Merlin 380.67 is now available
I have been testing the fq_codel and will stick to cable (docsis) option...
however while testing i came across something that might be adjusted... each time the overhead present is changed and applied the drop down menu goes back to "Select preset" it would be nice if the page would remember the selected option... you know... just a nice thing to have
thanks!
It's a preset selector, not a setting. All it does is fill up the two fields next to it - you can then change the content of these two fields if you want to do further adjustments. There is no value stored on the router relative to that dropdown menu.
Just like the game/service presets on the Port Forward page.
Looks like the QTN radio tripped itself up somehow and then rebooted. When I was running on 380.65 and 380.66_6 I was going for extended periods of time without issue but now 380.67 had this happen. :-(
The Quantenna firmware hasn't changed in well over a year, so this has nothing to do with 380.67.
@RMerlin, Is it possible to add a new feature such as "WAN uptime" under system log>general log, and under tools as well?
I might eventually add it, it's just not a high priority (and it's not as trivial as it might seem. Asus' wanduck code is a complete disaster, I can't make out head nor tail out of it anymore - same reason why I still haven't gotten around to implementing a user-configurable script to the WPS button).
I hope in the future builds that we get alternative packet schedulers like HFSC for qos.
I just had 5 crash/reboots on my 87u in a row with this message :(
Aug  1 02:00:12 kernel: _ Reboot message ... _______________________________________________________
Aug  1 02:00:12 kernel: <1>Unable to handle kernel NULL pointer derefere�U�at virtual address 00000001
Aug  1 02:00:12 kernel: <1>pgd = c0004000
Aug  1 02:00:12 kernel: <1>[00000001] *pgd=00000000
Aug  1 02:00:12 kernel: <0>Internal error: Oops: 17 [#1] PREEMPT SMP
Aug  1 02:00:12 kernel: <0>last sysfs file: /sys/module/bw_forward/parameters/dev_wan
Aug  1 02:00:12 kernel: <4>module: module:  ebtables     bf7fe000     15643
Aug  1 02:00:12 kernel: <4>module:  ct_notification     bf7ec000     1684
Aug  1 02:00:12 kernel: <4>module:  bw_forward     bf7cc000     93980
Aug  1 02:00:12 kernel: <4>module:  IDP     bf740000     529190
Aug  1 02:00:12 kernel: <4>module:  nf_nat_sip     bf739000     5031
Aug  1 02:00:12 kernel: <4>module:  nf_conntrack_sip     bf730000     15713
Aug  1 02:00:12 kernel: <4>module:  nf_nat_h323     bf729000     4761
Aug  1 02:00:12 kernel: <4>module:  nf_conntrack_h323     bf71b000     3track_rtsp     bf70f000     4067
Aug  1 02:00:12 kernel: <4>module:  nf_nat_ftp     bf709000     1144
Aug  1 02:00:12 kernel: <4>module:  nf_conntrack_ftp     ble_mangle     bf6fc000     934
Aug  1 02:00:12 kernel: <4>module:  xt_length     bf6f6000     769
Aug  1 02:00:12 kernel: <129
Aug  1 02:00:12 kernel: <4>module:  qmi_wwan     bf6dd06d6000     7252
Aug  1 02:00:12 kernel: <4>module:  cdc_ncmis_host     bf6c7000     4936
Aug  1 02:00:12 kernel: <4>module:  cdc_ether     bf6c1000     3187
Aug  1 02:00:12 kernel: <4>module:  asix     bf6b9000     10832
Aug  1 02:00:12 kernel: 367
Aug  1 02:00:12 kernel: <4>module:  usblp     bf6a2000     10321
Aug  1 02:00:12 kernel: <4>module:  ohci_hcd     bf6hci_hcd     bf678000     51124
Aug  1 02:00:12 kernel: <4>modu4>module:  tntfs     bf5e0000     4544     52776
Aug  1 02:00:12 kernel: <4>module:  ext4     bf552000     221674
Aug  1 02:00:12 kernel: <4>module:  jbd2     bf53f000     48993
Aug  1 02:00:12 kernel: <4>module:  crc16     :  usb_storage     bf4f0000     34290
Aug  1 02:00:12 kernel: <4>module:  sg     bf4e5000     19855
Aug  1 02:00:12 kernel: <4>module:  sd_mod     bf4d9000     21 tunnel4     bf4a0000     1808
Aug  1 02:00:12 kernel: <4>module:  usbcore     bf47d000     101810
Aug  1 02:00:12 kernel: <4>module:  ip6t_LOG     bf476000     4494
Aug  1 02:00:12 kernel: <4>module:  ip6table_filter    odule:  nf_nat_pptp     bf442000     1602
Aug  1 02:00:12 kernel: <4>module:  nf_conntrack_pptp     bf43c000     3355
Aug  1 02:00:12 kernel: <4>module:  nf_nat_proto_gre     bf436000     887
Aug  1 02:00:12 kernel: <4>module:  nf_conntrack_proto_gre     bf430000     3296
Aug  1 02:00:12 kernel: <4>module:  wl     bf032000     3938142
Aug  1 02:00:12 kernel: <4>module:  igs     bf02a000     11887
Aug  1 02:00:12 kernel: <4>module:  emf     bf021000     15225
Aug  1 02:00:12 kernel: <4>module:  linked in: ebtable_nat ebtables ct_notification bw_forward(P) Ip nf_nat_h323 nf_conntrack_h323 _nat_ftp nf_conntrack_ftp ip6tab cdc_ether asix usbnet mii usblpplus tntfs(P) tfat(P) ext2 ext4 jbd2 crc16 ext3 jbd mbcache usb_ sit scsi_mod tunnel4 usbcore ip6t_LOG ip6table_filter jffs2 zlib_deflate nf_nat_pptp nf_conntrack_pptp nf_nat_proto_gre nf_conn(P) et(P) ctf(P) [last unloaded:rm #2)
Aug  1 02:00:12 kernel: <4>PC is at ip_conntrack_ at 0xcd09fdfe
Aug  1 02:00:12 kernel: <4>pc : [<c0227e4782a140
Aug  1 02:00:12 kernel: <4>r7 : 00000006  r6 : 000000  r1 : c782a168  r0 : c03c3c54
Aug  1 02:00:12 kernel: <4>Flags: nZcv  IRQs on  FIQ(0xc03c3830 to 0xc03c4000)
Aug  1 02:00:12 kernel: <0>38000 00000002 00000001 00000000
Aug  1 02:00:12 kernel: <00 00000000 00000000 5c9e7050 00
Aug  1 02:00:12 kernel: <0>38e0: 00000000 00000000 0000000 00000000 00000000 00000000 000
Aug  1 02:00:12 kernel: <0>3920: 00000000 00000000 000 00000000 00000000 00000000 00000000 00000000 00000000
Aug  1 02:00:12 kernel: <0>39c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000000 00000000 00000000
Aug  1 02:00:12 kernel: <0>3a000000 00000000 00000000 0000 ^Ccb03c540 c03c3a90 00000000 0000d7c8 bf001a5c
Aug  1 02:00:12 kernel: <0>3a60: 00000000 c03c3a94 00000000 cb0670f0 c03e6604 cb067120 cfbca480 cac46d20
Aug  1 02:00:12 kernel: <0>3a80: 00000049 c0389dc8 c80f3180 00000110 00000630 0502a8c0 c782a250 cf9f6200
Aug  1 02:00:12 kernel: <0>3aa0: cfa1db800000 2723d7c8 00000011 00000000
Aug  1 02:00:12 kernel: <0>3ac0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug  1 02:00:12 kernel: <0>3ae0: 00000000 00000000 00000000 00000088 00 00002723 cb0670f0
Aug  1 02:00:12 kernel: <0>3b20: cb0670f0 c03e6604 c8215820 c80f3100 014
Aug  1 02:00:12 kernel: <0>3b40: cb038460 c0227c94 a17f700 00000030 57f
Aug  1 02:00:12 kernel: JFFS2 notice: (356) check_node_data: wrong data CRC in data node at 0x03322ea8: read 0xad1cdc43, calculated 0xf979a161.
Aug  1 02:00:12 kernel: d272e 00000528 000004f8 c037a230 00000500 00000011
Aug  1 02:00:12 kernel: <0>3b80: fb5e04a1 cb17f8c0 00000000 cb1d1f80 c03c3bb4 c0060000003
Aug  1 02:00:12 kernel: <0>3bc0: cb17f8c0 c0226e41fabc cb1d1f00 00000000
Aug  1 02:00:12 kernel: <0>3be0: c03de4dc c022cf38 00000001 0000000 00000001 c0423ed8 cb0af000 000120 bd6a389d cc3c8d10 f37d298 11c16000 c0418cbc c03c2000 c003283f7c c037ca0c
Aug  1 02:00:12 kernel: <0>3cc0: c0283f7c c0377ab0 00000000 cec600e0 000
Aug  1 02:00:12 kernel: <0>3ce0: c03c3d1c 00000000 c0420788 c0224168 00000000 c03c3d1c c0283f7c fffffe71
Aug  1 02:00:12 kernel: <0>3d00: c042304148cc c03c2000 cb2a5000 bf7e0f4c
Aug  1 02:00:12 kernel: <0>3d20: c0423f90 cec600e0 cb0 cec16000 fffffe71
Aug  1 02:00:12 kernel: <0>3d40: 000 fffffe71 ce0432d0 20b158bd cb17000 cec16000 00000000
Aug  1 02:00:12 kernel: <0>3d80: 03c3e0c
Aug  1 02:00:12 kernel: <0>3da0: c0420788 800000046540 c7a5e12c cac46568
Aug  1 02:00:12 kernel: <0>3dc0:03c3e0c c03c2000 0000000a
Aug  1 02:00:12 kernel: <0>3e00 cac46540
Aug  1 02:00:12 kernel: <0>3e20: c03c2000 cefe40: 80000000 c037e954 cfa1d800 00 c03c2000 c782a124 00000000
Aug  1 02:00:12 kernel: <0>3e80: cac46604 00000000 c782a110100 c01f8e30 00000000 c821651c
Aug  1 02:00:12 kernel: <0>3ec0: c8216514 c8216508 c782a124 00000001 c821651c 00000040 0000012a c82164a0
Aug  1 02:00:12 kernel: <0>3ee0: c82164a8 c03c4080 00006fe9 c037b8e4 cfa1dcac c03c2000 c006703c 000000
Aug  1 02:00:12 kernel: ____________________________________________________________________________
Is this still an ipv6 bug in the kernel?
Just a feature I liked from John's Asus firmware fork. If it's to hard to add I understand.
The problem is if I implement a default mode, another user will ask that the default mode be to sort by MAC. Then, someone else will ask that the default mode be configurable. This will result in what I call "feature creap", something I want to avoid. Storing the selected sort mode in a cookie was the compromise I chose.
Outside the scope of this project, and not really realistic to do as Adaptive QoS is closed source.
In case it hasn't been mentioned elsewhere, this update seems to have broken AiCloud, prompting an "Unable to Connect" screen. Running the server on a non-standard port, forwarding is set up correctly, OpenVPN server still works, as well as WAN access to a NAS server. Reverted to the previous version (380.66_6), and AiCloud works again.
Router is AC87U.
WOW! :p
ahh gotcha ill ask asus about it see if they might help not going to hold my breath for the off chance they mange to patch it in. I hope some is able to find a way to patch it in some how would be intresting to see if its better than htb at tackeling buffer bloat.
Help dlna not working. Dlna is not show in the network helpppp please
Your post doesnt help with trouble shooting, you need to post more detail, like router model, and where its not displaying, eg in windows or its an issue with a device etc, it helps with the abilty for others to replicate the problem and limits our ability to help you.
Hi.
In what case should I enable the ATM in WAN packet overhead?
I set my QoS to fq_codel and the preset to Cable (DOCSIS)
I Have Cablemodem with 25/5 Mbps connection.
Thanks.
Hi.
Thanks.
atm is for adsl cable doesnt need it since it doeant use asycronos transfer mode.
When running a ping test to see the right over head value, should i use my mtu of 1500 or just 64 byte, i want to be sure if ive done it correctly or i just made a major bobo in testing, which would by all means literally suck since id have to go back and re do my tests, my methodolgy was to see if i could keep the latency as low as possible while a download from steam was running, i kept an eye to the latency value, i ran the ping to see the latency it would get initally while after about the 7th ping id let the download run i set the pings to 99 attemts to get a better idea of the results. I just want to be sure im doing it proppely since it seems the preset might not be excatly correct for my case.
@RMerlin Any chance of seeing @john9527 's IPSet updates in the next .68 beta? Been testing them for the last week and its rock solid.
Asus doesn't even allow sortable or editable fields yet, so default sort mode is way down the list of priorities I'm afraid...
@RMerlin Hi ,
I'm a french newbie and my english is poor , be adviced !
config: RT-AC66U
i found a bug with last firmware :
i have connected a 4g phone to usb and set it as primary WAN , secondary Wan is up by ADSL .
With official ASUS FW , it's OK .
but with the last Merlin-FW
380.67 (16-July-2017)
Merged with GPL 380_7743 code, with binary blobs from 7378 for N66U
my router seems to reboot , as soon as i want download something , or test with service like Fast.com
can you explain me, how can i help , send some logs or others...
Thank you !
