Clean installed 384.11_2.384.11_2 should be available on mirror sites now.
Has the dcd crash been fixed? I am asking this because there are no dcd crashes with this new fw.
The fields do toggle on or off depending on the setting, at least on my router/browser.![]()
I'll be presumptuous, and answer for him ... there's no way for him to know, that part is closed source. I've had it go away for a version in the past only to come back with the next one, so I wouldn't hold my breath.Clean installed 384.11_2.
He's stated his views on DNScrypt a number of times (here, here, and here, for examples). I'd bet lunch the answer is still no. It's not an official IETF standard, and he considers the protocol obsolete.@RMerlin Is there any possibility to include Dnscrypt directly into the firmware just like the DOT in 384.11?
OpenDNS still doesn't support DOT and the country in which I love in OpenDNS is significantly faster than both cloudflare and Google DNS. Since my ISP uses Transparent DNS proxy server (almost all ISPs in India), I am forced to use either DNScrypt or DOT protocol.
Question
is in this version implemented
- Fixed DDoS vulnerability.
- Fixed AiCloud vulnerability.
- Fixed command injection vulnerability.
- Fixed buffer overflow vulnerability.
from ASUS RT-AC88U new Firmware version 3.0.0.4.384.45717 ?
Question
Still 45149. I was hoping to maybe get newer GPLs this week but it didn't happen, so I got tired of waiting. Currently building the 384.11_2 images.
You can use Adguard DoT alot of its dns endpoints bounce off of opendns.@RMerlin Is there any possibility to include Dnscrypt directly into the firmware just like the DOT in 384.11?
Cloudflare has no DNSSEC issues. Works better than most including Quad9.As stated above, DNS Privacy overrides.
But;
What you have done is fine, in case of DNS Privacy not working for some reason, (unlikely), you would default to ISP server/s.
Bear in mind these may not be dnssec friendly, I see you have dnssec enabled.
If you want to default to Cloudflare then select ‘no’ & enter the Cloudflare server/s in wan, & IPv6. That gets rid of any possible dnssec issues.
Yea I like this Merlin is on "FIRE"I see there is also a new alpha 384.12 with change log here:
https://github.com/RMerl/asuswrt-merlin.ng/blob/master/Changelog-NG.txt
hopefully this will still be merged with the new GPLs when available.
Welcome To SNBForums
