L&LD
Part of the Furniture
Thank you or I will do a factory reset after an upgrade.
Yes, after flashing the firmware you want.
Look in my signature for the M&M Config link if you do decide to do a full reset.
Take out USB if any, reboot, and try again.Hi, i know it's a nooby question but how to upgrade to 384.11_2 ? It isn't accepting the .trx file. I have 384.11 at the moment
What router do you have? Is it a TM-1900? That model isn't supported here.Hi, i know it's a nooby question but how to upgrade to 384.11_2 ? It isn't accepting the .trx file. I have 384.11 at the moment
If he already has 384.11 then there is no way it's a TM-1900.
Been there, done that!Sorry my mistake! I have an AC86U and accidentally downloaded the firmware for AC68U.. Noobie mistakes. Now i have the newest firmware on my router - thank you!
Your device is a netgear unit not Asus unit. Reading the forum rules/stickies would have lead you to this thread.I had to go down to firmware 384.10_2 because on my nighthawk r7000 network devices would not work on anything newer. Any ideas or settings i should check after updating ? I did try resetting the entire router to scratch and starting over a few times as well as a few reboots, that didn't help.
Thank you. Btw is NVRAM: 51922 / 65536 bytes normal?Yes, after flashing the firmware you want.
Both normal.Thank you. Btw is NVRAM: 51922 / 65536 bytes normal?
And I also get: nvram: consolidating space! in the log
Thank you,Both normal.
I get kernel: [BLOCKED - INBOUND] IN=eth0 OUT all the time?
The ip starts with 81.22. which is russian but how to clear so that I dont get it full in the log
Yes im using Skynet. I will check this thanksAre you using Skynet? You need to disable logging, I think.![]()
Jun 4 16:40:01 rc_service: httpd 311:notify_rc restart_dnsfilter
Jun 4 16:40:02 miniupnpd[25332]: shutting down MiniUPnPd
Jun 4 16:40:02 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Jun 4 16:40:03 miniupnpd[25443]: HTTP listening on port 33686
Jun 4 16:40:03 miniupnpd[25443]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 4 16:41:07 rc_service: httpd 311:notify_rc restart_wlcscan
Jun 4 18:26:27 miniupnpd[25443]: upnp_event_process_notify: connect(192.168.2.99:2869): Connection timed out
Jun 4 18:26:27 miniupnpd[25443]: upnpevents_processfds: 0x2c1e8, remove subscriber uuid:4f81e4dd-4ea3-41b3-8400-01bf92a97c65 after an ERROR cb: http://192.168.2.99:2869/upnp/eventing/vddfzgnmkr
That is normal for inactive connections on upnpd. The upnpd will clear out the connection if it is inactive for too long, this is a good thing and is normal behavior, unless you are on a device that is active but this is happening. If you notice the time difference between when it connects and loses connection is like a few hours. Which tells me it is probably a device that was used for a couple of hours and then turned off.I got these errors today, anyone have idea what could that be and why they appear ?
Code:Jun 4 16:40:01 rc_service: httpd 311:notify_rc restart_dnsfilter Jun 4 16:40:02 miniupnpd[25332]: shutting down MiniUPnPd Jun 4 16:40:02 nat: apply nat rules (/tmp/nat_rules_eth0_eth0) Jun 4 16:40:03 miniupnpd[25443]: HTTP listening on port 33686 Jun 4 16:40:03 miniupnpd[25443]: Listening for NAT-PMP/PCP traffic on port 5351 Jun 4 16:41:07 rc_service: httpd 311:notify_rc restart_wlcscan Jun 4 18:26:27 miniupnpd[25443]: upnp_event_process_notify: connect(192.168.2.99:2869): Connection timed out Jun 4 18:26:27 miniupnpd[25443]: upnp_event_process_notify: connect(192.168.2.99:2869): Connection timed out Jun 4 18:26:27 miniupnpd[25443]: upnpevents_processfds: 0x2c1e8, remove subscriber uuid:4f81e4dd-4ea3-41b3-8400-01bf92a97c65 after an ERROR cb: http://192.168.2.99:2869/upnp/eventing/vddfzgnmkr
Welcome To SNBForums
