[Release] Asuswrt-Merlin 384.9 is now available
Tried that before posting... it's the same problem
I only ever compiled the firmware once as a learning opportunity (didn't trust my work enough to flash it). I used the Fitz instructions linked here:
MerlinWRT - compile instructions?
In your case, instead of checking out mainline, you'd be checking out the 384.9-mainline tag. If you've already got all this covered, someone else might have first-hand knowledge of your error.
Thank you, Dave!
I'll do some investigatin' over the weekend and post back here if I find anything useful.
Fitz's guide is basically the same as my set-up, so I'll start with checking the makefiles.
The thing is that I've successfully compiled-n-flashed it a while ago, so the question is 'what has changed?!?!?'...
Thank you, Dave!
I _may_ have figured out the problemo'... I was using git to reset to former state after making clean (git reset HEAD --hard & equivalents). This seems to work but my guess is that the fact that git doesn't roll back file modification timestamps to repo cloning/check-out time generates the 'boo-boo'.
I'll investigate more when I'll have time for it, but whoever encounters the same problem, either build from a downloaded archive, or if cloning the repo don't force a hard git reset .
...perhaps a solution would be to use the git checkout hooks ... or something...
