This has already been resolved. The dns entry is manually inserted through the custom scripts, just leave the gui empty. It is because dnsmasq doesn't know to advertise itself on any other port than 53, so we have to tell it to advertise the router's IP( or 0.0.0.0 to use the address dnsmasq is hosted from) which adguardhome is serving dns at. So the script uses dnsmasq.postconf that adds a line to dnsmasq to deal with this issue.I just installed the 386.4 firmware on my AX88U.
I did a factory reset and install AdGuard, as some other mention, for some reason, if the DHCP DNS field is empty, the client computers won't be able to browse the internet. As soon as I put the router IP on the DHCP DNS field, all clients has connectivity.
Has the root cause of this has been identified?
Regards
Netstat -nlp | grep 443This issue start appearing after the minor update with enabling Https check. Previous version didnt have this issue.
I think found the problem after mention 443. I have pixelserv-tls enable. Disabling got it to work now.When I enable the "encryption" checkmark, it would redirect me to the https version of the page. This time it give me that error. Netsat no command in router.
@AX11000:/tmp/home/root# Netstat -nlp | grep 443
-sh: Netstat: not found
netstat it needs to be lowercaseI think found the problem after mention 443. I have pixelserv-tls enable. Disabling got it to work now.
That sounds about rightI think found the problem after mention 443. I have pixelserv-tls enable. Disabling got it to work now.
thank you for your prompt reply, I managed to change the port number but 2nd command to restart the service didn't work, I had to reboot the router to make it work.Edit /opt/etc/AdGuardHome/AdGuardHome.yaml change that number to the port you want.
Then run the command,
/opt/etc/init.d/61AdGuardHome restart
/opt/etc/init.d/S61AdGuardHomethank you for your prompt reply, I managed to change the port number but 2nd command to restart the service didn't work, I had to reboot the router to make it work.
# /opt/etc/init.d/61AdGuardHome restart
-sh: /opt/etc/init.d/61AdGuardHome: not found
*Disclaimer*While this is an ad-blocker just like Diversion, for all intensive purposes it shall be treated as an alternative and not a replacement. Diversion will continue to function as is.*Disclaimer*
Correct. @thelonelycoder provides two of the Primary Addon Code Bases for asuswrt-merlin, Diversion (which is an adblocker) and AMTM (the swiss army knife of asuswrt-merlin). AMTM provides access to packages/scripts for users of Asuswrt-Merlin in a user friendly way. Asuswrt-Merlin-AdGuardHome-Installer is an installer that makes bringing AdGuardHome support to Asuswrt-Merlin possible, AMTM offers it as a package on the long list of packages it provides easy of access to.Sorry for asking a noob question. I am just starting on router based adblocker (from pihole). I was thinking of diversion, and on their website they show "What's new in amtm 3.2.3 - NEW: Adds support for Asuswrt-Merlin-AdGuardHome-Installer by SomeWhereOverTheRainBow". Its bit confusing give the first thread. As I understand this is new feature to amtm, and nothing to do with actual diversion codebase, right?
Thank you.. that helps a lot to understand the relationships.Correct. @thelonelycoder provides two of the Primary Code Bases for asuswrt-merlin, Diversion (which is an adblocker) and AMTM (the swiss army knife of asuswrt-merlin). AMTM provides access to packages/scripts for users of Asuswrt-Merlin in a user friendly way. Asuswrt-Merlin-AdGuardHome-Installer is an installer that makes bringing AdGuardHome support to Asuswrt-Merlin possible, AMTM offers it as a package on the long list of packages it provides easy of access to.
On your Asuswrt-Merlin journey, there are three adblocking methods that can be used on Asuswrt-Merlin that are currently supported by AMTM. The first and foremost best and easy to use is Diversion. The second is the Adblocker script provided by Unbound-Manager. The third is AdGuardHome which is provided by Asuswrt Merlin AdGuardHome Installer. When choosing which to use, only use one method. Don't try to combine methods.
Setting flags for package apache-utils to hold.
Info: Configuring AdGuardHome...
=> Do you want to redirect all DNS resolutions on your network through to AdGuardHome? [y/n]:
Author: SomeWhereOverTheRainBow
https://www.snbforums.com/threads/new-release-asuswrt-merlin-adguardhome-installer.76506/#post-733310
_____________________________________________
Continue? [1=Yes e=Exit] 1
fatal error: out of memory allocating heap arena map
runtime stack:
runtime.throw(0x90c989, 0x27)
runtime/panic.go:1117 +0x54 fp=0x7fdf520f10 sp=0x7fdf520ee0 pc=0x444a4
Mem: 218184K used, 222140K free, 1668K shrd, 204K buff, 27872K cached
CPU: 0.0% usr 4.0% sys 0.0% nic 96.0% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 2.44 1.79 0.85 2/136 6592
Looks like it didn't even install because your router is low on memory. Not really anything I can do. You can try starting over. I would first use the uninstall option which removes Adguard.@SomeWhereOverTheRainBow need bit of a help here.. as my adblock option I tried adguardmy ssh session was interrupted at this stage
Code:Setting flags for package apache-utils to hold. Info: Configuring AdGuardHome... => Do you want to redirect all DNS resolutions on your network through to AdGuardHome? [y/n]:
After that any attempt of launching ad guard installer fails due to out of memory.
Code:Author: SomeWhereOverTheRainBow https://www.snbforums.com/threads/new-release-asuswrt-merlin-adguardhome-installer.76506/#post-733310 _____________________________________________ Continue? [1=Yes e=Exit] 1 fatal error: out of memory allocating heap arena map runtime stack: runtime.throw(0x90c989, 0x27) runtime/panic.go:1117 +0x54 fp=0x7fdf520f10 sp=0x7fdf520ee0 pc=0x444a4
per top i don't think my router is anywhere near full
Code:Mem: 218184K used, 222140K free, 1668K shrd, 204K buff, 27872K cached CPU: 0.0% usr 4.0% sys 0.0% nic 96.0% idle 0.0% io 0.0% irq 0.0% sirq Load average: 2.44 1.79 0.85 2/136 6592
Any option to just remove adguard and retry installer? or should I just wipe the disk and startover?
Run the command free and post the output.@SomeWhereOverTheRainBow need bit of a help here.. as my adblock option I tried adguardmy ssh session was interrupted at this stage
If that fails, the next step is the famous L&LD guides....Did you try a reboot?
well, we noobs will be noobs.. I missed to enable swap in amtm before going ahead with adguard. A quick swap of USB3 flashdrive (previous attempt of creating swap was quite longer which made me realize RT-AC86U has a USB3 port) and a 2GB swap creation later, AdGuard is up and running.. it was a very simple and painless experience.If that fails, the next step is the famous L&LD guides....
Welcome To SNBForums
