DavoFreshQoSFreshDaveQos? DaveJRQOS? None have the same ring to it as the original but I sure we will grow to like it.
Rename your fork or create a new fork in your repo. Give due credit and the date the fork and further improvements was made in the Readme.md and the files.A general question to the forum at large - what's the right way to fork and rename but still give credit to the original author who did the hard work without looking like a weasel? I didn't intend to rename it at all, but I probably need to PM thelonelycoder to understand how different he prefers it for AMTM logic.
Ideas welcome. Anything from 1QoS (too short) to ASUSWRT-Merlin-QoS (too long).
I'm learning quickly that I enjoy the learning and the coding. Dealing with you all (i.e. users just like me) is less fun.![]()
I was thinking along the lines of @Jack Yaz style, QoS_MerlinRename your fork or create a new fork in your repo. Give due credit and the date the fork and further improvements was made in the Readme.md and the files.
As for the name, make it memorable and follow the KISS rule. My suggestion: Bandwidth and the longer version being: Bandwidth - Adaptive QoS improvements
My concern with this is people may confuse the actual "standard QOS" within Merlin with the new DaveQos or vice versa when trying to troubleshoot.I was thinking along the lines of @Jack Yaz style, QoS_Merlin
QoSDaveMy concern with this is people may confuse the actual "standard QOS" within Merlin with the new DaveQos or vice versa when trying to troubleshoot.
right on DQOS is simple.. well end up getting lazy n callin is DQ for short.. make me want an icecream@dave14305 testing your fork DQOS, Thanks for doing it![]()
first time of trying qos and this script, so its a good learning exerciseright on DQOS is simple.. well end up getting lazy n callin is DQ for short.. make me want an icecreamIve cleared freshes version for testing.. left only the https/gaming and unidentified. rest im using the web ui. seems to work quite well that way; the web ui is the best
@dave14305
I've been experiencing a certain problem for freshjr and your latest masterpiece as well, don't know if it's related to script or not but i know you certainly can help
Whenever i restart my router , it makes a normal understanding of applying qos after 5 min delay, and replies after 5 minutes that no modifications are necessary, also good to mention that it initially cancels and than apply again for 5 minutes and after 5 minutes, it logs as no modification necessary, all my clients show full bandwidth as no qos is applied, so to counter this problem, I've to manually apply settings again in qos gui page after every reboot, i can replicate the issue thousand times
Here's my log
Jun 6 23:58:19 avahi-daemon[3838]: Loading new alias name RT-AC88U.
Jun 6 23:58:19 avahi-daemon[3838]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.0.2.
Jun 6 23:58:19 avahi-daemon[3838]: New relevant interface br0.IPv4 for mDNS.
Jun 6 23:58:19 avahi-daemon[3838]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Jun 6 23:58:19 avahi-daemon[3838]: New relevant interface lo.IPv4 for mDNS.
Jun 6 23:58:19 avahi-daemon[3838]: Network interface enumeration completed.
Jun 6 23:58:19 avahi-daemon[3838]: Registering new address record for 192.168.0.2 on br0.IPv4.
Jun 6 23:58:19 avahi-daemon[3838]: Registering new address record for 192.168.0.1 on br0.IPv4.
Jun 6 23:58:19 avahi-daemon[3838]: Registering new address record for 127.0.1.1 on lo.IPv4.
Jun 6 23:58:19 avahi-daemon[3838]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 6 23:58:19 A.QoS: qos rule is less than 22
Jun 6 23:58:19 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Jun 6 23:58:20 avahi-daemon[3838]: Server startup complete. Host name is RT-AC88U-5940.local. Local service cookie is 1078764329.
Jun 6 23:58:20 avahi-daemon[3838]: Alias name "RT-AC88U" successfully established.
Jun 6 23:58:20 A.QoS: qos_count=2, qos_check=1
Jun 6 23:58:21 Samba_Server: daemon is started
Jun 6 23:58:21 wsdd2[3988]: starting.
Jun 6 23:58:22 miniupnpd[3993]: HTTP listening on port 36819
Jun 6 23:58:22 miniupnpd[3993]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 6 23:58:24 A.QoS: qos rule is less than 22
Jun 6 23:58:24 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
Jun 6 23:58:25 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Jun 6 23:58:25 custom_script: Running /jffs/scripts/nat-start
Jun 6 23:58:26 Skynet: [*] Lock File Detected (start skynetloc=/tmp/mnt/HDD/skynet) (pid=744) - Exiting (cpid=4119)
Jun 6 23:58:29 adaptive QOS: Delayed Start Canceled
Jun 6 23:58:30 adaptive QOS: Applying - Iptable Down Rules
Jun 6 23:58:31 adaptive QOS: Applying - Iptable Up Rules (ppp0)
Jun 6 23:58:31 adaptive QOS: TC Modification Delayed Start (5min)
Jun 7 00:00:00 (unbound_rpz.sh): 6653 Attempting to Download 1 of 1 from https://urlhaus.abuse.ch/downloads/rpz/.
Jun 7 00:00:00 Skynet: [*] Lock File Detected (start skynetloc=/tmp/mnt/HDD/skynet) (pid=744) - Exiting (cpid=6656)
Jun 7 00:00:01 Skynet: Mounting Skynet Web Page As user3.asp
Jun 7 00:00:02 (unbound_rpz.sh): 6653 Reload unbound for zone named rpz.urlhaus.abuse.ch
Jun 7 00:00:04 Skynet: [#] 293495 IPs (+0) -- 1547 Ranges Banned (+0) || 0 Inbound -- 0 Outbound Connections Blocked! [start] [146s]
Jun 7 00:00:05 adaptive QOS: Delayed Start Canceled
Jun 7 00:00:06 adaptive QOS: Applying - Iptable Down Rules
Jun 7 00:00:06 adaptive QOS: Applying - Iptable Up Rules (ppp0)
Jun 7 00:00:06 adaptive QOS: TC Modification Delayed Start (5min)
Jun 7 00:05:07 adaptive QOS: No modifications necessary
Please help!!!
Which firmware version now? If you’re still on 17, how did you install the script (what commands?).Please help!!!
I'm on 17 and i just installed it with your given commandWhich firmware version now? If you’re still on 17, how did you install the script (what commands?).
curl "https://raw.githubusercontent.com/dave14305/FreshJR_QOS/develop/FreshJR_QOS.sh" -o /jffs/scripts/FreshJR_QOS --create-dirs && curl "https://raw.githubusercontent.com/dave14305/FreshJR_QOS/develop/FreshJR_QoS_Stats.asp" -o /jffs/scripts/www_FreshJR_QoS_Stats.asp && sh /jffs/scripts/FreshJR_QOS -install
I'm issuing adaptive QOS and secondly my guess is that issue might be due to other scripts, I'm using skynet, unbound @Martineau , ntpmerlin, spdmerlin etcsomething is wrong cuz after a restart it NEEDS to apply changes for the script to be active. Ar eyou using adaptive qos or traditional? freshjr soon to be DQos only works with adaptive qos.
Welcome To SNBForums
