[Release] FreshJR Adaptive QOS (Improvements / Custom Rules / and Inner workings)
Hello, it would be very hard to ask them to upload a video to youtube on how to install the scripts, since I am a novice and even though I read I can not understand how it is installed. Thanks in advance.
regards!!!
regards!!!
I'll try to do that .
Installation got simpler with the beta releases 2 pages back
In the meantime you download putty, pscp, and the two script files. You paste 2 lines into command prompt and 5 lines into putty. That's it .
Which step did you get lost on?
regards!!!
pm me if you need teamviewr help
Ufff, I was more confused with what you just mentioned now if I'm totally lost. Sorry, I am a complete novice but I would like to try your QOS system.
Login isiyouy router user name and password is the one u login to the router with
Also how do I set up traffic on a set protocol eg 27015 (UDP) as gaming and 27015 (TCP) Downloads, since this is for steam, I know what you said about not creating that filter type, but I'm referring to a specific case, where such a thing would be needed.
No biggie if any one else needs help installing the script just pm mem
Installed this no problem onto my 86U, after reading the first page,to activate it,just toggle on/off. thats it?
But leave the QOS off completely?
First page is outdated. All links say OLD and they are not compatible with current firmware.
This is at the end of first post
(Look for v382.2 or FakeTC Beta1 in last few pages of thread for current versions)
First page will be updated, when current release leaves BETA.
If you found and installed one the two newest releases, then all you need to do is turn ON adaptive QOS with manual bandwidth limits. There should be status output in the System Log
Jan 26 01:15:52 admin: Adaptive QOS: Enabled FreshJR FakeTC
Look's like I should have time tomorrow. I am planning to publish the requested rules if all goes well.
Fresh which is better the regular script or the beta tc?
They do the same thing so go ahead and jump on the beta.
Fresh i am getting this log here if you can look at it
Feb 6 19:58:47 rc_service: httpd 371:notify_rc restart_qos;restart_firewall
Feb 6 19:58:50 kernel: *** ERROR: [tdts_shell_ioctl_sig_op_load:95] tdts_core_rule_parsing_trf_load() fail!
Feb 6 19:58:51 kernel: *** ERROR: [tdts_shell_ioctl_sig_op_load:95] tdts_core_rule_parsing_trf_load() fail!
Feb 6 19:58:54 miniupnpd[11743]: shutting down MiniUPnPd
Feb 6 19:58:54 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 6 19:58:55 kernel: ERR[parse_qos_conf:932] Can't set new QoS conf while QoS is started!
Feb 6 19:58:55 kernel: ERR[ioctl_iqos_op_config:3592] parse qos_conf error!!
Feb 6 19:58:55 kernel: ioctl_iqos_op_config() fail!
Feb 6 19:58:55 kernel: ERR[qos_start:3344] QoS is already started!
Feb 6 19:58:55 kernel: ioctl_iqos_op_switch(1) fail!
Feb 6 19:58:55 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Feb 6 19:58:55 miniupnpd[12169]: HTTP listening on port 55617
Feb 6 19:58:55 miniupnpd[12169]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 6 19:58:58 kernel: ERR[parse_qos_conf:932] Can't set new QoS conf while QoS is started!
Feb 6 19:58:58 kernel: ERR[ioctl_iqos_op_config:3592] parse qos_conf error!!
Feb 6 19:58:58 kernel: ioctl_iqos_op_config() fail!
Feb 6 19:58:58 kernel: ERR[qos_start:3344] QoS is already started!
Feb 6 19:58:58 kernel: ioctl_iqos_op_switch(1) fail!
Feb 6 20:00:54 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Feb 6 20:01:09 rc_service: httpd 371:notify_rc restart_qos;restart_firewall
Feb 6 20:01:27 kernel: ERR[parse_qos_conf:932] Can't set new QoS conf while QoS is started!
Feb 6 20:01:28 kernel: ERR[ioctl_iqos_op_config:3592] parse qos_conf error!!
Feb 6 20:01:28 kernel: ioctl_iqos_op_config() fail!
Feb 6 20:01:28 kernel: ERR[qos_start:3344] QoS is already started!
Feb 6 20:01:28 kernel: ioctl_iqos_op_switch(1) fail!
Feb 6 20:01:32 miniupnpd[12169]: shutting down MiniUPnPd
Feb 6 20:01:32 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Feb 6 20:01:32 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Feb 6 20:01:32 miniupnpd[24068]: HTTP listening on port 41618
Feb 6 20:01:32 miniupnpd[24068]: Listening for NAT-PMP/PCP traffic on port 5351
Also fresh about the tcp and udp rules I need them for steam.
