ROG Rapture GT-AC5300 (Owners)
I own a Rt-Ac5300, is it worth a change to this GT one?
How better is the signal range and strenght?
Tks
Currently wsarahan.
If you own a RT-AC5300, stay with it for now. The code, even production is loaded with issues yet. Give it a year to work out. Also please note that MerlinWRT is not currently supported on on the GT.
Just to let you know that Asus are aware of the stability issues with 15564 and will release an updated version in the next week or so.
There is a beta version 15967 floating around that adds VPN Fusion, Alexa and IFTTT - do not know how stable it is though.
Hey fellas,
trying to get OpenVPN with NordVPN to work... says it's connected, but no websites pulling up. Followed step-by-step procedure NordVPN is providing for Asus routers.
Using the desktop OpenVPN app with NordVPN i have no issues.
I use the same server through the GT, and I can not connect to any websites.
Anyone else having issues with getting OpenVPN to work?
What version do I have?
3.0.0.4.382_12184-g4a5d7783
is it 12184?
New Firmware:
https://www.asuswebstorage.com/navigate/s/C67CD5B9BA4941A98725C9668AE0B81AY
Changelog update:
Notice: Suggest factory reset by applying update.
Security Fix
- Apply patch for CVE-2017-9417, CVE-2017-5891 and CVE-2017-5892
- Fix security issue OnSec-VUZ-106-09001 and OnSec-VUZ-106-09006
- Update foolproof checking for http access from WAN, this will allow https remote access only.
- Fix security issue for facebook, twitter and picassa photo upload function
Add
- HDD Hibernation
- URL filter black/white list
- Allow specific IP address for SSH/Telnet/WebGUI login
- Bandwidth limiter on guest network
- URL filter support https website
- VPN Fusion
- LAN link-rate on Network map
Fix
- ASUSWRT GUI issue
- WTFast GUI logout issue
- Protect server crash related issue
- QoS related issues (adptive QoS / Bandwidth limiter)
- IPTV related issue
- OVPN permission issue
- VPN related issues
- Memory leak issue
- 802.1x related issues
- AiCloud related issues
- Traffic Analyzer bug fix
- Fix 2.4g interoperability issue
- Fix auto channel select not working issue
- Fix retrieve nvram problem
Modify
- Update smart sync API
- Compatibility improvement with USB-N53
- web history enable/disable mechanism
- Add OpenVPN HMAC Authentication option
- Encrypt feedback account related information
Unfortunately, my IPVanish ovpn settings still do not connect me to the internet. I am unable to load anything on the internet. Has anyone been able to get their VPN settings working through the router?
Ok so after a little more fiddling, L2TP works with IP Vanish and my speeds are 103.19 Mbps down and 20.25 Mbps up. My advertised speeds are 100 Mbps down and 20 Mbps up. Not sure the encryption level of L2TP, but it is working so I am happy.
1.1.0 introduces API changes, so it's not a drop-in replacement like 1.0.2 was for 1.0.0. Since Asus only went from 1.0.0 to 1.0.2 because I did the necessary legwork (and I also pointed out 1.0.0 was going EOL last year), I suspect they aren't gonna move to 1.1.0 on their own, and I can't do that move either due to the closed-source components linked against 1.0.x. Plus, believe it or not, but they use THREE different OpenSSL versions in their firmware, probably either for fear of breaking things, or due to arcane issues they encountered when moving everything to 1.0.2. The Broadcom modem driver for instance is linked against 1.0.0, and their Download Master stuff is linked against a third one (don't remember which version).
FWIW - recently felt much pain with OpenSSL 1.1 vs. 1.0.x...
Preparing to move a buildroot from debian 8.1 to debian 9.1 - and from xgene (arm) back to amd64 - much of this is due to the impending return of our build-box - so in a lab setup, tried to rebuild the toolchain with 9.1, just for kicks...
Quite a few errors - some functions in OpenSSL have been deprecated for some time, and 1.1 they basically killed them off - so quite a bit of debug, not just for our BSP, but for the reference BSP's - lede built ok, openwrt - not so much, but using the libssl-dev1.0 package got that working for OpenSSL issues... anyways, looking at dropping openwrt as a reference, as lede pretty much does the same thing but newer...
Outside of the OpenSSL thing with 1.1 - gcc 6.3 is a bit more strict, so a bit of cleanup work needs to be done there.
Yes, I'm having issues with openvpn as well. Let's see if those new firmwares fix the issue. Didn't have the chance to try any of them yet.
Sent from my SM-G955U1 using Tapatalk
I tried 15984 and 15967 and neither one allow me to use open vpn. I could get it to work on my rt3100 but I no longer have that since I “upgraded”.
So it's not me or my VPN-Provider, it's this friggin' router?! Common ASUS, get it together.
Isn't this your flagship?
New Firmware:
Changelog update:
Security Fix
Add
- HDD Hibernation
- VPN Fusion
Fix
- ASUSWRT GUI issue
- Memory leak issue
Modify
OpenVPN shows connected, but checking my IP it's not the one of the VPN-Server, but my actual one.
What the hell?
None of the official or beta firmwares work with openvpn from my experience. L2TP works but I get an assload of errors in the log with it it. The selling point for me was the VPN being able to route certain device and not all. I’m happy to see that built in now BUT openvpn doesn’t work so I’m still waiting. By the time this is all fixed I’ll be buying a new router I’m sure.
I returned my Synology 2600 because the beta firmware is stable but all the features still are not there. I’ll take the stability for now I guess.
Thanks MarkSW,
I loaded it up tonight. So far, I see no fix for the network map being only able to change about 10 devices only. Hopefully something later. Most likely see something after a 24 hour burn in period in the logs.
Sure.. Server, and client.. But client was back on the current firmware although I had to back off the client because I also use this router as a Verizon Fios Router, and none of my TV services would work. (DVR, Mobile Stream)
Still getting the paid app error after factory reset and reconfigure..
Aug 18 00:55:48 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (9-4-35)!
Aug 18 00:55:49 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:55:51 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:55:52 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:10 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:11 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:17 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:21 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:22 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:22 kernel: ERR[update_qos_data_by_ip:3436] Failed to find udb entry by skb dst-IP!
Aug 18 00:56:23 kernel: ERR[update_qos_data_by_ip:3436] Failed to find udb entry by skb dst-IP!
Aug 18 00:56:23 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:56:24 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:15 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:16 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:17 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:18 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:19 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:20 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Aug 18 00:57:52 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Ouch.. I get them about every 10 -20 minutes. But not spamming like that...
On new production code about 23.5 hours now. See the following in the log. Multiple errors and some over and over.....
Aug 22 21:41:16 crond[796]: time disparity of 273760 minutes detected
Aug 22 21:42:37 hour monitor: ntp sync fail, will retry after 120 sec
Aug 22 22:00:52 disk_monitor: Got SIGALRM...
Aug 22 22:08:51 kernel: br0: received packet on eth6 with own address as source address
Aug 22 23:00:52 disk_monitor: Got SIGALRM...
Aug 23 04:27:45 kernel: br0: received packet on eth8 with own address as source address
Aug 23 13:18:05 kernel: br0: received packet on eth6 with own address as source address
Aug 23 16:21:01 kernel: br0: received packet on eth6 with own address as source address
Aug 23 16:21:03 kernel: br0: received packet on eth8 with own address as source address
Aug 23 18:35:42 miniupnpd[2140]: upnp_event_process_notify: connect(192.168.1.195:2869): Connection timed out
Aug 23 18:38:10 kernel: br0: received packet on eth6 with own address as source address
Aug 23 21:05:06 kernel: br0: received packet on eth6 with own address as source address
Aug 23 21:06:17 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (25-4-132)!
Aug 23 21:06:17 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Again, I have nothing on port 6 nor 8. I only have a 16 port switch plugged into the router off port 7. The NTP has server has been moved to multiple NTP public servers now. I started seeing that error a few codes test ago.
I tried to use the feedback sent in via the TAB in the router. Looked like it was going but got this error instead....
Failed to send your feedback. Please check your Internet connection and try again.
The system failed to connect to the mail server(possibly caused by your ISP blocked SMTP port 25). You can send an email directly to : ( router_feedback@asus.com ) Simply copy the contents below and paste it as your e-mail contents.
Email sent again to Asus techs.
